billderou(at)yahoo.com Guest
Posted: Wed Jul 05, 2006 8:28 am Post subject: Windscreen sanding tool |
This may seem a bit trivial, however ....
The plans call for a 7" radius at the windscreen to front fuselage intersection. I found inexpensive rubber sanding blocks have a rounded handle about 6" radius. Just install the sandpaper on the top side instead of the flat side. It does a good job of creating a uniform radius fillet.
Who knows? Maybe this is where the 7" radius originated.
Bill DeRouchey
40029/N939SB
Fly in 2 weeks
