Seat question
Mauledriver(at)nc.rr.com
PostPosted: Wed Oct 21, 2015 5:54 pm    Post subject: Seat question Reply with quote
I did one of the rail mods some time ago and it's worth it's weight in
gold now that I'm getting on to 5 years of flying and maintaining.
However, I still labored at the T-handle removal and re-installation. I
had read about how the stops could be modified for easy removal but I
forgot about that and instead returned to the idea of nut plates on the
T-handles.
However, I ended up doing something slightly different. I used nutserts
in the T-handle.
The only concern I observed after I did the first one is that nutsert
are not finished flush on the inserted face. It would work this way but
there would be a roughly 1/64" space between the T-handler and the seat
frame.
Turns out that if you install them 'backwards', they leave a flush fit
for the T-handle to mate with the seat frame. It also leaves a nicely
finished face on the outside edge... not that one ever really sees that
edge.
Now the T-handles can be removed and re-installed with a single powered
screwdriver using a single hand. That combined with the rail
modification (trim the plastic, not the aluminum) makes the whole
operation much easier than stock.
BTW, this was all done during the process of installing the PlaneAround
90degree retrofit door latch. Not only do I feel safer, but this
product fixed my entire door installation that includes the IFLYRV10
flush billet door handles and lock. There was excessive friction in the
setup and I never could completely latch the doors from the outside.
Now it all works!
Up to now, my RV10 passenger safety briefing consisted of "This is a
fantastic airplane, nothing to worry about but under no circumstances
are you to touch the doors - I open and close all doors at all times".
Now I can say, " remember this isn't car and it's not a car door so no
slamming, just pull it down and close the latch, Thank You"
Bill "Door Victory at Last - but I need to refinish the )(*&$#(at)$(at)#*^
things again" Watson
glastar(at)gmx.net
PostPosted: Wed Oct 21, 2015 9:54 pm    Post subject: Seat question Reply with quote
T-handles.
Bill,
do you have some pictures of that modification?
Thanks Werner
flying-nut(at)cfl.rr.com
PostPosted: Thu Oct 22, 2015 2:38 am    Post subject: Seat question Reply with quote
I had read about how the stops could be modified for easy removal but
I forgot about that and instead returned to the idea of nut plates on
the T-handles.
nutserts in the T-handle.
I drilled and tapped the T-handles.
Linn
rv10free2fly(at)yahoo.com
PostPosted: Thu Oct 22, 2015 4:29 am    Post subject: Seat question Reply with quote
Any pictures of your seat modifications please Bill?
Warm regards
Patrick
On 22 Oct 2015, at 12:20, Bill Watson <Mauledriver(at)nc.rr.com> wrote:
I did one of the rail mods some time ago and it's worth it's weight in gold now that I'm getting on to 5 years of flying and maintaining. However, I still labored at the T-handle removal and re-installation. I had read about how the stops could be modified for easy removal but I forgot about that and instead returned to the idea of nut plates on the T-handles.
However, I ended up doing something slightly different. I used nutserts in the T-handle.
The only concern I observed after I did the first one is that nutsert are not finished flush on the inserted face. It would work this way but there would be a roughly 1/64" space between the T-handler and the seat frame.
Turns out that if you install them 'backwards', they leave a flush fit for the T-handle to mate with the seat frame. It also leaves a nicely finished face on the outside edge... not that one ever really sees that edge.
Now the T-handles can be removed and re-installed with a single powered screwdriver using a single hand. That combined with the rail modification (trim the plastic, not the aluminum) makes the whole operation much easier than stock.
BTW, this was all done during the process of installing the PlaneAround 90degree retrofit door latch. Not only do I feel safer, but this product fixed my entire door installation that includes the IFLYRV10 flush billet door handles and lock. There was excessive friction in the setup and I never could completely latch the doors from the outside. Now it all works!
Up to now, my RV10 passenger safety briefing consisted of "This is a fantastic airplane, nothing to worry about but under no circumstances are you to touch the doors - I open and close all doors at all times". Now I can say, " remember this isn't car and it's not a car door so no slamming, just pull it down and close the latch, Thank You"
Bill "Door Victory at Last - but I need to refinish the )(*&$#(at)$(at)#*^ things again" Watson
PostPosted: Thu Oct 22, 2015 9:32 am    Post subject: Seat question Reply with quote
Here is a photo and description of the T-handle mod My Kitlog - T-Handle Seat Mod
I don't have any photos of the rail mod which I did a few years ago per postings here or on Vans Airforce.  Some have ground away part of the aluminum rail.  The alternative I took was to cut out part of the front of the plastic runners.  A little bit of aluminum may have to be removed as well but I don't think so.  Sorry I don't exactly recall.  In either case, it allow the seat to slide out without have to touch the flap actuation cover... or the carpet that it may be covered with
It's all back together now but if I can take a meaningful pic, I will.
Bill "Finally happy with seat removal and installation but it's still a back breaker" Watson
On 10/22/2015 8:25 AM, Patrick Pulis wrote:
--> RV10-List message posted by: Patrick Pulis <rv10free2fly(at)yahoo.com.au> (rv10free2fly(at)yahoo.com.au)
Warm regards
Patrick
On 22 Oct 2015, at 12:20, Bill Watson <Mauledriver(at)nc.rr.com> (Mauledriver(at)nc.rr.com) wrote:
--> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com> (Mauledriver(at)nc.rr.com)
Checked by AVG - www.avg.com
Tim Olson
PostPosted: Thu Oct 22, 2015 11:00 am    Post subject: Seat question Reply with quote
Hey Bill,
Regarding the Nutserts, is there any worry about the nutserts
pulling through the hole? It seems to me that if they slid
out, the whole thing falls apart, and they wouldn't be as strong
as having something on the outer face to hold that bolt that
can't pull through. But I haven't installed any in years.
The ones I did were aluminum and didn't seem ultra strong.
Also, if they are aluminum, then maybe just going up a size in
bolt would work, and drill and tap the holes in the T-Handle
bracket? A risky proposition for cost if it gets messed
up, is the bigger worry. Plus the threads would eventually
wear a lot after many removals. I think ideally, someone
would make a nutsert with integral external hex flange/locknut.
That would take care of all worries.
Seat Mod
<http://www.mykitlog.com/users/display_log.php?user=mauledriver&project=224&category=7984&log=216267&row=1>
schmoboy
PostPosted: Thu Oct 22, 2015 12:51 pm    Post subject: Seat question Reply with quote
Note that if you do the mod to make the rear rail stop removable, i.e.
nutplates for it's attach bolts, then there's no reason to ever have to
remove the t-handles.
I did that mod plus the removal of the front portion of the of the
delrin (or whatever it is) under the slide. Seats come out in a couple
minutes.
-Sean #40303 (trying to figure out why XM weather quit receiving)
Tim Olson <mailto:Tim(at)MyRV10.com>
October 22, 2015 at 1:55 PM
Hey Bill,
Bob Turner
PostPosted: Thu Oct 22, 2015 1:15 pm    Post subject: Re: Seat question Reply with quote
Since the load is nearly all shear, I would think this is okay if you only torque the bolts to the lower, shear load spec; this is unlikely to pull the insert thru. I note that you have to go to a shorter length bolt (or washers under the bolt head) so that the threaded area now carries part or maybe all of the shear load, instead of 100% on the shank as in the original design. Again, not quite as strong as the original design. I think you should try to get at least some of the shank into the hole in the latch piece. In a typical crash (moving forward) the seat belt will carry the imposed loads, so the latch is really not that important. Unless you spin around 180 degres and then suddenly stop. I have no idea if even the original design can carry your weight plus the seat times 10(?)(g).
Bob Turner
RV-10 QB
EdKranz
PostPosted: Thu Oct 22, 2015 1:32 pm    Post subject: Seat question Reply with quote
This is what I did. Seat out in about 2 minutes. Just need a socket on an extension to get to the bolts between the sidewall and the seat. Works great!
On Thu, Oct 22, 2015 at 3:48 PM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
[quote]--> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
Note that if you do the mod to make the rear rail stop removable, i.e. nutplates for it's attach bolts, then there's no reason to ever have to remove the t-handles.
I did that mod plus the removal of the front portion of the of the delrin (or whatever it is) under the slide.  Seats come out in a couple minutes.
Ed Kranz
RV10
Finishing
www.edandcolleen.com
PostPosted: Fri Oct 23, 2015 5:50 am    Post subject: Seat question Reply with quote
The load being in shear was my thinking. Given that, getting a flush
fit between the seat rail and T-pin, and being able to torque the bolts
to spec is the main (perhaps only) concern relative to an traumatic
event. This approach satisfies both needs.
The trick to getting the flush fit however is putting the Nutserts in
'backward' which allows a flush fit between the seat rail and T-pin
assembly. On one hand, the compressed Nutsert is now just pressed into
it's hole rather than have an expanded portion on the backside of a
thinner piece of material. On the other hand the lip of the Nutsert is
now resisting the pull of the bolt.
The solution involving nutplating the stop block seems ideal and it's
what I would have done in the initial build. It's taken me years to
tire of seat removal so slowly I've 1) trimmed the Delrin rail and 2)
finally Nutserted the bolts.
I thought about drilling out for tapping an AN4 bolt or something but
didn't get to the point of thinking that approach through. Doing what I
did is low risk - I can still put a long bolt, washer and nut on it if
I want (?!!), not.
I may have the threaded portion of the bolt going thru the joint but I
may be able to remedy that with the right length bolt and/or washers.
There's a nice gap between the joint face and where the threads start on
the Nutsert.
On 10/22/2015 5:15 PM, Bob Turner wrote:
Since the load is nearly all shear, I would think this is okay if you only torque the bolts to the lower, shear load spec; this is unlikely to pull the insert thru. But if it does happen, eventually the bolt threads will bottom out and the bolt will have no pre-load. I note that you have to go to a shorter length bolt (or washers under the bolt head) so that the threaded area now carries part of the shear load, instead of 100% on the shank as in the original design. Again, not quite as strong as the original design. I think you should try to get at least some of the shank into the hole in the latch piece. In a typical crash (moving forward) the seat belt will carry the imposed loads, so the latch is really not that important. Unless you spin around 180 degres and then suddenly stop. I have no idea if even the original design can carry your weight plus the seat times 10(?)(g).
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=448198#448198
