Tail wheel stop
JohnFrance
PostPosted: Mon Aug 10, 2015 12:37 am    Post subject: Tail wheel stop Reply with quote
Hello to all,
Does anyone have a plan of the tail-wheel stop that bolts onto the Tail Wheel Fork XTW 07 to avoid damaging the cables and rudder horns if the aircraft is pushed backwards?
If someone can send me a copy I would appreciate it.
Europa mono Nr 192
rparigoris
PostPosted: Mon Aug 10, 2015 4:41 am    Post subject: Tail wheel stop Reply with quote
Hi John
I fabricated one out of 7000 Aluminium:
http://www.europaowners.org/main.php?g2_itemId=27732
Side note is I didn't like the binding/grinding that was going on because of the cable angles so turned some conical spacers that work great. Info contained on the same link.
Ron Parigoris
