1james.baldwin(at)gmail.c Guest
Posted: Sun Aug 09, 2015 11:56 am Post subject: Rocket-List Digest: 4 Msgs - 08/08/15 |
If you install the P model of the EMag you will have no problem with the ignition element of starting your IO540. My O360 starts instantly once I installed the PMag. Additionally, you'll get a self contained generator which will supply voltage to the ignition if the ship power fails. I saw the 6 cylinder version of the PMag at Oshkosh and Brad said they are close to a ship date. JBB
On Sun, Aug 9, 2015 at 12:03 AM, Rocket-List Digest Server <rocket-list(at)matronics.com (rocket-list(at)matronics.com)> wrote:
[quote]*
Today's complete Rocket-List Digest can also be found in either of the
two Web Links listed below. The .html file includes the Digest formatted
and Message Navigation. The .txt file includes the plain ASCII version
of the Rocket-List Digest and can be viewed with a generic text editor
HTML Version:
  http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2015-08-08&Archive=Rocket
Text Version:
  http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2015-08-08&Archive=Rocket
              Rocket-List Digest Archive
           Total Messages Posted Sat 08/08/15: 4
Today's Message Index:
   1. 06:27 PM - Starting problem (Jim Stone)
   2. 07:09 PM - Re: Starting problem (Scot Stambaugh)
   3. 08:29 PM - Re: Starting problem (Vern Little)
   4. 08:42 PM - Re: Starting problem (Jones15183(at)aol.com (Jones15183(at)aol.com))
________________________________Â Message 1Â _____________________________________
Time: 06:27:58 PM PST US
From: Jim Stone <jrstone54(at)att.net (jrstone54(at)att.net)>
Subject: Starting problem
I'm looking for ideas to improve my start up both cold and hot.
I have an IO 540 C4 B5 with a non impulse mag on the upper plugs and Electro
Air Electronic ignition (latest version on the lower plugs), and all aviatio
n plugs.
I removed the slick impulse Mag a year ago after the Slick Rep advised me to
 "get it off that engine before it comes apart and stops your engine".
I have been starting with just the ElectroAir and realized it is not my star
ting technique as much as it is a lack of spark. ElectroAir told me that th
e system has to measure a pretty fast cranking speed for what seems like a l
ong time before it produces a spark. This cranking pulls the battery voltag
e down and if the voltage to the ElectroAir controller falls below 11 volts,
 it no longer produces a spark. Of course I have no indication of no spark o
ther than the obvious no start result. So with some luck the batteries hold
 up long enough tilI I get the mixture right, if not, recharge and try late
r.
I'm considering the slick start but it requires a different mag from Slick a
nd a coupler which all together cost 2k.. Seems like a big price to pay for
 better start performance, but I'm considering it.
Does anyone have a proven solution?
TIA,
Jim Stone
Louisville Kentucky
HR 11
________________________________Â Message 2Â _____________________________________
Time: 07:09:50 PM PST US
From: Scot Stambaugh <f1rocket(at)yahoo.com (f1rocket(at)yahoo.com)>
Subject: Re: Starting problem
I have a dual Lightspeed system and have never had any problem.
Electronic Ignition for Aircraft
| =C2- |
| =C2- |Â | =C2- | =C2- | =C2- | =C2- | =C2- |
| Electronic Ignition for AircraftSport Aviation, February 1995 In 1994 Kla
usSavier entered five races, won them all and had no failures. ELECTRONIC I
GNITION FOR AIRCRAFT By Klaus Savier E... |
|Â |
| View on www.lightspeedengine... | Preview by Yahoo |
|Â |
| =C2- |
I also use the B&C Lightweight starter that doesn't seem to cause a signifi
cant voltage drop in the system.
B & C LIGHTWEIGHT STARTERS FOR LYCOMING from Aircraft Spruce
| =C2- |
| B & C LIGHTWEIGHT STARTERS FOR LYCOMING from...Other Customers Have Also
Viewed: CONT. 0-200 HEAT BOX CESSNA 150 STYLE HEAT BOX $173.95Â |
|Â |
| View on www.aircraftspruce.com | Preview by Yahoo |
|Â |
| =C2- |
 And just to make the issue more challenging, my engine is a high-compressi
on model with Lycon's 10.5:1 pistons.
The only time it doesn't start by the 3 rotation is if I don't prime for a
full 11 seconds, which is when the fuel pressure stabilizes.
Hope this helps.
Scot Stambaugh=C2-
   On Saturday, August 8, 2015 7:32 PM, Jim Stone <jrstone54(at)att.net (jrstone54(at)att.net)> wro
te:
oAir Electronic ignition (latest version on the lower plugs), and all aviat
ion plugs.
o "get it off that engine before it comes apart and stops your engine".
rting technique as much as it is a lack of spark. =C2-ElectroAir told me
that the system has to measure a pretty fast cranking speed for what seems
like a long time before it produces a spark. =C2-This cranking pulls the
battery voltage down and if the voltage to the ElectroAir controller falls
below 11 volts, it no longer produces a spark. =C2-Of course I have no in
dication of no spark other than the obvious no start result. =C2-So with
some luck the batteries hold up long enough tilI =C2-I get the mixture ri
ght, if not, recharge and try later.
and a coupler which all together cost 2k.. =C2-Seems like a big price to
pay for better start performance, but I'm considering it.
TIA,
Jim Stone
Louisville Kentucky=C2-
HR 11
________________________________Â Message 3Â _____________________________________
Time: 08:29:39 PM PST US
From: Vern Little <voltar(at)vx-aviation.com (voltar(at)vx-aviation.com)>
You could add a holdover battery, as illustrated on the IGN page of this doc
ument: http://54.162.78.90/redmine/attachments/download/94/VFR%20Aircraft%20
Electrical%20System%20Rev%205.pdf
Vern
HR-II C-GVRL
Vernon R. Little | President, Vx Aviation
> On Aug 8, 2015, at 6:27 PM, Jim Stone <jrstone54(at)att.net (jrstone54(at)att.net)> wrote:
roAir Electronic ignition (latest version on the lower plugs), and all aviat
ion plugs.
arting technique as much as it is a lack of spark. ElectroAir told me that t
he system has to measure a pretty fast cranking speed for what seems like a l
r.
 and a coupler which all together cost 2k.. Seems like a big price to pay f
> TIA,
> Jim Stone
> Louisville Kentucky
> HR 11
3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3
D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
________________________________Â Message 4Â _____________________________________
Time: 08:42:38 PM PST US
From: Jones15183(at)aol.com (Jones15183(at)aol.com)
Hi Jim, former F! Rocker owner. Can you explain your complete starting
procedure. I had Electroair and an Impulse mag. I never had a hot or cold
start problem. You talk about getting the mixture right. Shouldn"t be
fooling with mixture control in process of eng. starting. Let me hear from you
on you about your complete starting process. Billy Waters McGregor,tx.
In a message dated 8/8/2015 10:29:54 P.M. Central Daylight Time,
voltar(at)vx-aviation.com (voltar(at)vx-aviation.com) writes:
document:
http://54.162.78.90/redmine/attachments/download/94/VFR%20Aircraft%20Electrical%20System%20Rev%205.pdf
Vern
HR-II C-GVRL
On Aug 8, 2015, at 6:27 PM, Jim Stone <_jrstone54(at)att.net_
ElectroAir Electronic ignition (latest version on the lower plugs), and all
aviation plugs.
to "get it off that engine before it comes apart and stops your engine".
starting technique as much as it is a lack of spark. ElectroAir told me that
the system has to measure a pretty fast cranking speed for what seems like
a long time before it produces a spark. This cranking pulls the battery
voltage down and if the voltage to the ElectroAir controller falls below 11
volts, it no longer produces a spark. Of course I have no indication of no
spark other than the obvious no start result. So with some luck the
batteries hold up long enough tilIÂ I get the mixture right, if not, recharge and
try later.
TIA,
Jim Stone
_Louisville Kentucky_ (x-apple-data-detectors://0/1)
HRÂ 11
D============================================
 t-List"">http://www.matronics.com/Navigator?Rocket-List
//forums.matronics.com
D=============================================
3D======
et-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Rocket-List
| - The Matronics Rocket-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Rocket-List |
smokyray(at)rocketmail.co Guest
Posted: Sun Aug 09, 2015 12:31 pm Post subject: Rocket-List Digest: 4 Msgs - 08/08/15 |
Hey JBB,
I wasn't aware that Brad at EMAG Air had broken the code for an IO540 PMag.( I had a PMag on my RVX post HR2, great product)
The IO540 has a different accessory case gear drive for the mag that requires all electronic ignition systems (so far) to use a crank sensor mounted on the prop flange. The normal PMag setup is an accessory case gear drive installation which until reading your email wasn't in existence.
If this is accurate it's great news indeed.
V/R
Smokey
On Aug 9, 2015, at 14:56, James Baldwin <1james.baldwin(at)gmail.com (1james.baldwin(at)gmail.com)> wrote:
[quote]If you install the P model of the EMag you will have no problem with the ignition element of starting your IO540. My O360 starts instantly once I installed the PMag. Additionally, you'll get a self contained generator which will supply voltage to the ignition if the ship power fails. I saw the 6 cylinder version of the PMag at Oshkosh and Brad said they are close to a ship date. JBB
HTML Version:
Text Version:
________________________________ Message 1 _____________________________________
n plugs.
r.
TIA,
Jim Stone
Louisville Kentucky
HR 11
________________________________ Message 2 _____________________________________
| =C2- |
| =C2- | | =C2- | =C2- | =C2- | =C2- | =C2- |
| =C2- |
| =C2- |
Viewed: CONT. 0-200 HEAT BOX CESSNA 150 STYLE HEAT BOX $173.95 |
| =C2- |
Hope this helps.
Scot Stambaugh=C2-
te:
ion plugs.
TIA,
Jim Stone
HR 11
________________________________ Message 3 _____________________________________
Vern
HR-II C-GVRL
ion plugs.
r.
> TIA,
> Jim Stone
> Louisville Kentucky
> HR 11
________________________________ Message 4 _____________________________________
document:
Vern
HR-II C-GVRL
On Aug 8, 2015, at 6:27 PM, Jim Stone <_jrstone54(at)att.net (jrstone54(at)att.net)_
aviation plugs.
batteries hold up long enough tilI I get the mixture right, if not, recharge and
try later.
TIA,
Jim Stone
HR 11
3D======
Lee Logan
Posted: Sun Aug 09, 2015 12:38 pm Post subject: Rocket-List Digest: 4 Msgs - 08/08/15 |
Rob:  Yes to your inquiry, the problem is that they've been working on their 6-cylinder version for 6-7 years. It has been promised for delivery many times in the past, but the "signs" are that this time it may actually happen. Those showing an early interest were asked for down payments about two months ago. You might want to get in line soon if you want one.
Lee...
Posted: Sun Aug 09, 2015 12:49 pm Post subject: Rocket-List Digest: 4 Msgs - 08/08/15 |
Thanks Lee, I sold my HR2 4 years ago.
I do miss it sometimes but not like I miss the F16...
Cya!
Smokey
On Aug 9, 2015, at 15:38, Lee Logan <leeloganster(at)gmail.com (leeloganster(at)gmail.com)> wrote:
[quote]Rob: Yes to your inquiry, the problem is that they've been working on their 6-cylinder version for 6-7 years. It has been promised for delivery many times in the past, but the "signs" are that this time it may actually happen. Those showing an early interest were asked for down payments about two months ago. You might want to get in line soon if you want one.
Lee...
voltar(at)vx-aviation.com Guest
Posted: Sun Aug 09, 2015 1:04 pm Post subject: Rocket-List Digest: 4 Msgs - 08/08/15 |
.... So the solution is an unproven device that is not yet available? It sounds to me that this is a voltage droop problem which would also affect a P-MAG type ignition.
In my opinion, the simplest way is to fix the voltage droop: new main battery, better wiring or by using an ignition holdover battery (aka essential bus). The purpose of the new battery is to spin the starter at a high enough rpm with minimal voltage droop. The purpose of the holdover battery is to prevent low voltage kickback and to provide temporary ignition power in the event of a main bus failure.
======Vernon R. Little | President, Vx Aviation
On Aug 9, 2015, at 12:56 PM, James Baldwin <1james.baldwin(at)gmail.com (1james.baldwin(at)gmail.com)> wrote:
HTML Version:
Text Version:
n plugs.
r.
TIA,
Jim Stone
Louisville Kentucky
HR 11
| =C2- |
| =C2- |
| =C2- |
| =C2- |
Hope this helps.
Scot Stambaugh=C2-
te:
ion plugs.
TIA,
Jim Stone
HR 11
Vern
HR-II C-GVRL
ion plugs.
r.
> TIA,
> Jim Stone
> Louisville Kentucky
> HR 11
document:
Vern
HR-II C-GVRL
aviation plugs.
try later.
TIA,
Jim Stone
HR 11
3D======
