rossmickey(at)comcast.net Guest
Posted: Thu Jul 16, 2015 7:58 am Post subject: Radio Buzz |
I know that asking about the cause of a buzz in your radios is like asking a mechanic about a noise you hear when you are driving but since you are all here and know way more than me I will describe my situation and how I plan to proceed.
Set-up
RV-6A
GX-60 Com
SL-30 Com
SL-15 Intercom
Two COMANT VHF COMMUNICATIONS antenna mounted on the centerline of the belly (one below the seat, one below the baggage compartment)
I am getting significant static like noise when I connect either radio to the front antenna. I have switched the antennas with no change. The front antenna connection goes pretty much straight down to the floor with a short male-male piece of coax (which I have changed with no result) to connect the female ends of the antenna and radio coax. The antenna wire crosses a bunch of wires at a 90 degree angle and goes right next to where I have a temporary battery placed.
My conclusions:
The radios, antennas and cables are all ok so I must be picking up interference from either the wires or the battery.
Solution:
Move the battery and see if it helps (I would have last night but ran out of time)
What do you think?
Also, I get a very slight hum when I put my hand near (1 inch away) or touch the SL-30. It doesn’t bother me but I find it interesting that I just have to get near the radio for the noise to happen.
Thanks all,
Ross Mickey
N9PT
RV-6A
Posted: Thu Jul 16, 2015 2:20 pm Post subject: Radio Buzz |
More info…
My plane is not in a state that allows me to start the engine (wings are off) so this is occurring with just the master switch on. No strobes or landing lights on, just panel instruments on. The main change since I last used the radios is the installation of a Advanced Flight System 5600 EFIS but the only wiring from that which are near my antenna cable are the GPS, Comm Radio and Autopilot serial/ARINC wires.
Ross
Sent: Thursday, July 16, 2015 8:57 AM
To: 'aeroelectric-list(at)matronics.com'
Subject: Radio Buzz
Set-up
RV-6A
GX-60 Com
SL-30 Com
SL-15 Intercom
My conclusions:
Solution:
What do you think?
Thanks all,
Ross Mickey
N9PT
RV-6A
Joined: 28 Mar 2008 Posts: 1975 Location: Riley TWP Michigan
Posted: Thu Jul 16, 2015 2:53 pm Post subject: Re: Radio Buzz |
Is the temporary battery powering the avionics? Is the negative battery terminal grounded to the airframe?
Turn everything on, then measure the voltage between the negative battery terminal and the radio case. How many millivolts?
Joe
_________________ Joe Gores |
n1deltawhiskey(at)comcast Guest
Posted: Thu Jul 16, 2015 3:43 pm Post subject: Radio Buzz |
Ross,
What you are picking up is probably some sort of RFI or EMI. I doubt it will be coming from your battery unless you have some grounding issues, and may not even be coming from your wires.
That leaves the noise generators which includes all of your other avionics and electrical devices and systems including strobes, engine/ignition system, etc. And that is assuming there is no noise generated because of ground loops in your aircraft. So the process is to eliminate noise generators, one by one, assuming there is no noise in your antenna/cable/radio when tested with ALL other electrical equipment turned off. If your radio still generates noise when you put your hand near it, I would consider grounding the case.
Then, turn on one electrical device at a time to see if it generates any noise. With my GX-60, I noticed the Dynon D10A introduced some hum in the system when turned on. The strobe circuit also introduced some noise. Test each electrical system sequentially to find the biggest "offenders". This process will give you some idea of where to look to attempt to reduce noise in the com system.
I recently had my transponder checked and asked about noise in the radio system. He commented that some noise tended to "go with the territory".
Not necessarily related, I queried him about very loud feedback when attempting to transmit. Turns out that a setting in the GX-60 for the microphone was set to the maximum as shipped from the factory. The point here is to also check you GX-60 setup parameters. Some adjustments there might assist in correcting your issues.
Doug Windhorn
kboatright1(at)comcast.ne Guest
Posted: Thu Jul 16, 2015 4:16 pm Post subject: Radio Buzz |
http://www.warbirdinformationexchange.org/phpBB3/viewtopic.php?f=3&t=52024
Sent: Thursday, July 16, 2015 6:19 PM
Subject: RE: Radio Buzz
More info…
Ross
Subject: Radio Buzz
Set-up
RV-6A
GX-60 Com
SL-30 Com
SL-15 Intercom
My conclusions:
Solution:
What do you think?
Thanks all,
Ross Mickey
N9PT
RV-6A
Posted: Thu Jul 16, 2015 4:39 pm Post subject: Radio Buzz |
Ooops, cross post.
Do not archive.
From: kboatright1(at)comcast.net (kboatright1(at)comcast.net)
Sent: Thursday, July 16, 2015 8:15 PM
Subject: Re: RE: Radio Buzz
More info…
Ross
Subject: Radio Buzz
Set-up
RV-6A
GX-60 Com
SL-30 Com
SL-15 Intercom
My conclusions:
Solution:
What do you think?
Thanks all,
Ross Mickey
N9PT
RV-6A
deej(at)deej.net Guest
Posted: Thu Jul 16, 2015 5:21 pm Post subject: Radio Buzz |
On 7/16/2015 6:19 PM, Ross Home wrote:
| Quote: | My plane is not in a state that allows me to start the engine (wings are
Just a random thought, but is this inside your hangar? Is there
anything on in the hangar, like lights, a refrigerator, etc?
The noise might not be coming from anything in the plane.
-Dj
Dj Merrill - N1JOV - EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
Kellym
Posted: Thu Jul 16, 2015 9:19 pm Post subject: Radio Buzz |
Excellent thought. I had squelch break of sorts on my SL30 until I
realized it came and went with the light switch. One florescent tube was
causing its ballast to put out a bunch of RFI. New tube, noise gone.
On 7/16/2015 6:20 PM, Dj Merrill wrote:
-Dj
KCHD |
halbenjamin101(at)gmail.c Guest
Posted: Fri Jul 17, 2015 3:46 am Post subject: Radio Buzz |
I have a handheld radio in my hanger that I listen to while doing my preflight. Battery chargers for electronic devices often cause noise.
Hal Benjamin
RV4, Long Island, NY
| Quote: | On Jul 17, 2015, at 1:16 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
Excellent thought. I had squelch break of sorts on my SL30 until I realized it came and went with the light switch. One florescent tube was causing its ballast to put out a bunch of RFI. New tube, noise gone.
> -Dj
Posted: Fri Jul 17, 2015 6:32 am Post subject: Radio Buzz |
At 10:57 AM 7/16/2015, you wrote:
| Quote: | I know that asking about the cause of a buzz in your radios is like asking a mechanic about a noise you hear when you are driving but since you are all here and know way more than me I will describe my situation and how I plan to proceed.
Set-up
RV-6A
GX-60 Com
SL-30 Com
SL-15 Intercom
I am getting significant static like noise when I connect either radio to the front antenna. |
This sounds like a radiated noise issue which is almost
never an issue with grounding or other installation
errors . . . it's usually some device that is not
designed to live in harmony on airplanes.
Find a hand-held radio. Adjust to unused frequency
and open the squelch so you can hear the background
'hiss'. Then use it to 'probe' about the various
devices on the airplane.
Hand-held vhf transceivers and 9v transistor am radios
have been quite useful for probing noise sources of
all stripe.
Also, conduct a power-down study. Pull all fuses/breakers
that power up the ship's accessories. If noise is gone,
replace fuses one at a time until the noise comes back.
Bob . . . [quote][b]
Posted: Fri Jul 17, 2015 6:52 am Post subject: Radio Buzz |
I will try this.
What is puzzling is that the antenna connection that leads to the rear antenna is at the firewall about 18 inches and level with my GX-60. I can easily unhook the GX-60 cable from the front antenna (which is under the floor directly beneath the GX-60) and hook it to the rear antenna connection which is at the same height as the GX-60 and the noise goes away. All of the wires that the GX-60 cable passes are the same in either case except, when it is connected to the front antenna, it crosses these wires at a 90 degree angle instead of running parallel to them when it goes the rear antenna connection.
Like I said earlier, I switched the two antenna to see if one was bad with no change.
I am using a ground block for all grounding as suggested by Bob and the battery is attached to it.
This also occurred out of the hangar so it isn’t noise being generated outside of the airplane.
Thank you all
Ross
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Friday, July 17, 2015 7:30 AM
Subject: Re: Radio Buzz
Set-up
RV-6A
GX-60 Com
SL-30 Com
SL-15 Intercom
all stripe.
Bob . . . | Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 01234567
Kellym
Posted: Fri Jul 17, 2015 8:07 am Post subject: Radio Buzz |
Since you have ruled out external sources, it sort of points to the front antenna cable. I thought you said you had tried swapping cables.
Try removing antenna from airframe, connecting it directly to radio and see if there is noise.
I can't explain it, but I know of one case where noise was coming via ground, and isolating the antenna from ground cured the problem. Perhaps a ground loop between coax shield and the airframe ground.
On 7/17/2015 7:51 AM, Ross Home wrote:
I will try this.
Thank you all
Ross
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Robert L. Nuckolls, III
Set-up
RV-6A
GX-60 Com
SL-30 Com
SL-15 Intercom
all stripe.
Bob . . . 0 1 2 3 4 5 6 7
8 [b]
KCHD |
ARGOLDMAN(at)aol.com Guest
Posted: Fri Jul 17, 2015 10:04 am Post subject: Radio Buzz |
Bob's idea is probably right, but with two basically identical antennas I would vote for a problem with the problem antenna, probably the coax- connector-or connection to the antenna or a faulty antenna, if it is store bought. Connect your portable to each antenna to re re re varify that the front antenna is indeed the one that is giving the problem. Then do a continuity check to see if somewhere the cable has been kinked and is intermittently shorting (move as much of it as you can around.
If the noise is coming from inside of the aircraft, shutting all things off (with the exception of the errant radio and listening would probably be a good first test. If quiet, turn on each separate one (disconnect them via their fuses/CBs, not just their switches.
If it is coming from the hanger, merely reverse the location of the aircraft and the problem may go to the other antenna. A better test is to take the beast out of the hanger and try to duplicate the problem. My vote is the antenna or its lead/connectors, etc.
By the way. communication waves are vertically polarized your antennas are horizontally polarized. I dont know how much of a problem this is. That is for others to comment about
Rich
In a message dated 7/17/2015 9:34:07 A.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
Set-up
RV-6A
GX-60 Com
SL-30 Com
SL-15 Intercom
all stripe.
List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Fri Jul 17, 2015 10:05 am Post subject: Radio Buzz |
I just looked up your antenna-- forget the part of polarization in the last post..It is possible that you have an infant mortality.
Rich
Set-up
RV-6A
GX-60 Com
SL-30 Com
SL-15 Intercom
all stripe.
Posted: Fri Jul 17, 2015 10:46 am Post subject: Radio Buzz |
At 11:05 AM 7/17/2015, you wrote:
| Quote: | Since you have ruled out external sources, it sort of points to the front antenna cable. I thought you said you had tried swapping cables.
| Quote: | I will try this.
What is puzzling is that the antenna connection that leads to the rear antenna is at the firewall about 18 inches and level with my GX-60. I can easily unhook the GX-60 cable from the front antenna (which is under the floor directly beneath the GX-60) and hook it to the rear antenna connection which is at the same height as the GX-60 and the noise goes away. All of the wires that the GX-60 cable passes are the same in either case except, when it is connected to the front antenna, it crosses these wires at a 90 degree angle instead of running parallel to them when it goes the rear antenna connection. |
Routing of coax cables to antennas is NEVER
a component of received noise . . . in the
heavy iron we route coaxes where there is opportunity
and room. The whole idea behind the industry standard
practices for (1) limiting noise from antagonists,
(2) improving resistance to noise by judicious
design of potential victims and last (3) reducing
risk of over-whelming propagation path (mounting
an antenna under the cowl will probably pick up
ignition noise). When a noise coming in through
the receiver's antenna port is detected, placement
of the coax isn't even a distant finisher in the
quest for resolution.
Assuming you have paid due diligence to standard practices
for installing the two antennas then the fact that
the forward-most antenna seems to be the key propagation
port, then the noise source is most likely forward ON
the aircraft. If it were off the aircraft, both
antennas would hear it.
This problem has a lot in common with Col_Mustard-
did-it-in-the-library-with-a-rope . . . you gotta
gather all the clues available to you BEFORE picking
up hammers-n-saws . . . or screwdrivers.
Antennas don't go BAD in a manner that makes one
a source of noise while others are not. They either
work good . . . or they don't . . . but they're never
'noisy'. Start with a 'cold' panel and bring up
equipment one item at a time . . . then confirm
your preliminary findings with a sniffer receiver.
Only THEN will hammers, saws and screwdrivers
contribute to resolution of the problem.
Posted: Fri Jul 17, 2015 11:45 am Post subject: Radio Buzz |
Thanks so much, Bob. I will do as you suggest when I get back out to the hangar.
Just for my education. Since the location of the coax is not an issue, am I to understand that the interference I am experiencing is being picked up by the forward antenna itself?
In surfing the web about comm antenna, I read about the importance of having good electrical bonding of the antenna to the aircraft ground.
The electrical bonding of the antennas to the aircraft skin is best accomplished by direct metal-to metal contact of the antenna base to the aircraft skin. To accomplish this, the aircraft paint in the mounting area will need to be removed and the surface alodined to protect aluminum against corrosion. An alternate method for providing electrical bonding is through the mounting screws, which attach to a backing plate inside the aircraft skin. Remove any interior paint in the area where the backing plate is placed to assure a good ground. Coat this area with alodine to minimize corrosion. To test the electrical bonding of the blade to the aircraft, a reading of .003 ohms between the antenna base plate and ground should be achieved.
I am using the second method and will have to check if my installation meets the .003 ohm test. If the front antenna does not meet this, would this cause a buzz or just degrade the performance of the antenna?
Ross
Sent: Friday, July 17, 2015 11:45 AM
I will try this.
Bob . . . | Quote: | | [b]http://www.matronics.com/Navigator?AeroElectric-List | 01234567
Posted: Sun Jul 19, 2015 11:17 am Post subject: Radio Buzz |
I have identified that the buzz/static is coming from the new AFS 5600 EFIS I just installed. I have lessened the static sound some by re routing some wires. I also now can see that the rear antenna is being slightly affected also. All of the grounds look good going to a common ground block attached to the battery.
Now what do I do?
Ross Mickey
On Jul 17, 2015, at 12:43 PM, Ross Home <rossmickey(at)comcast.net (rossmickey(at)comcast.net)> wrote:
Ross
I will try this.
Bob . . . 01234567
[b] 8[/b][/b]
Posted: Sun Jul 19, 2015 11:26 am Post subject: Radio Buzz |
On 7/19/2015 3:15 PM, Ross Mickey (home) wrote:
| Quote: | I have identified that the buzz/static is coming from the new AFS 5600
Now what do I do?
First thing I'd do is contact AFS and see if they have any thoughts.
Others might have reported similar issues and they may have some ready
ideas to try.
-Dj
Kellym
Posted: Sun Jul 19, 2015 1:11 pm Post subject: Radio Buzz |
Turn the EFIS off with circuit breaker. See if the noise goes away. Then
call AFS/Dynon for advice if that proves to be the source of the noise.
Now what do I do?
Ross Mickey
> the hangar.
> the antenna?
> Ross
> *From:*owner-aeroelectric-list-server(at)matronics.com
> <mailto:owner-aeroelectric-list-server(at)matronics.com>
> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of
> *Robert L. Nuckolls, III
> *Sent:* Friday, July 17, 2015 11:45 AM
> *To:* aeroelectric-list(at)matronics.com
> <mailto:aeroelectric-list(at)matronics.com>
> *Subject:* Re: Radio Buzz
> swapping cables.
> airframe ground.
> I will try this.
> Bob . . .
> **http://www.matronics.com/Navigator?AeroElectric-List****
> ***http://forums.matronics.com*****
> ****http://www.matronics.com/contribution******
> *D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
> lectric-List"">http://www.matronics.com/Navigator?AeroElectric-List
> ot;">http://www.matronics.com/contribution
KCHD |
Posted: Sun Jul 19, 2015 2:06 pm Post subject: Re: Radio Buzz |
Is the AFS 5600 EFIS wired according to the installation manual? Usually shielded cables are grounded at the source end only, but not always. Can you identify one or more wires from the AFS 5600 EFIS that are causing the noise?
Is the squelch on the com radio adjusted too sensitive?
Joe
