727gs(at)db3broadband.com Guest
Posted: Sun Jul 05, 2015 7:53 pm Post subject: More Newby Questions |
In my effort to get the family CJ flying, I have a couple more questions.
-What is the torque for the spark plugs? I pulled, cleaned and tested them. Anyone know what the gap is supposed to be?
-How much oil is supposed to be in it? I drained the tank, nosecase, strainer, and oil cooler.
-Someone mentioned flapper valves between the fuel tanks and the header tank. The only valve like that I could find in my manuals was a check valve in the fuselage forward of the wing leading edge. Is that something I should remove and clean?
-What is the issue about fuel useage between the wing tanks? I've heard that mentioned a couple times.
Thanks in advance,
Steve near Chicago
draftsjust417(at)gmail.co Guest
Posted: Mon Jul 06, 2015 8:21 am Post subject: More Newby Questions |
Good morning Steve-
I've always had great success installing my stock Chinese sparkplugs at 240 inch-pounds, making sure to use Champion sparkplug thread lube and a new copper gasket/washer (Aircraft Spruce has them)upon each final installation.
Fyi,
Justin, N280NC
On Sun, Jul 5, 2015 at 7:49 PM, Steve Jones <727gs(at)db3broadband.com (727gs(at)db3broadband.com)> wrote:
Thanks in advance,
Steve near Chicago
et="_blank">http://www.matronics.com/Navigator?Yak-List
tp://forums.matronics.com
Posted: Mon Jul 06, 2015 8:44 am Post subject: More Newby Questions |
Steve,Absolutely no disrespect meant but your line of questions leads me to guess that your CJ is out of conditional (annual). If this is the fact I would highly recommend that you hire a competent CJ mechanic and look over his shoulder while he does the required inspection. He will have the knowledge and the proper tools to do the job. I honestly believe that doing this will save you money and heart ache (not to mention wallet ache) in the long run.
Doug Sapp
On Sun, Jul 5, 2015 at 8:49 PM, Steve Jones <727gs(at)db3broadband.com (727gs(at)db3broadband.com)> wrote:
Thanks in advance,
Steve near Chicago
Doug
You have to make up your mind about growing up and becoming a pilot. You can't do both.
clouddog22(at)gmail.com Guest
Posted: Mon Jul 06, 2015 8:46 am Post subject: More Newby Questions |
The CJ has fuel vents in the wing tanks located right behind fuel cap as observed from leading edge of wing. If you top off tanks, or fly out of trim, occasionally only one tank will feed and you could run out of fuel with one tank completely full. In flight, check your left and right tanks to insure proper feeding. Remember you might have to fly for at least 30 minutes before the gages come off the peg. If one is not feeding, then fly with the high fuel tank.... HIGH! (cross control flying). Some of us have added additional fuel vents in fuel caps or a more elaborate cockpit controlled venting system. This venting problem or lack of symmetrical fuel feed is NOT uncommon on the CJ.
P.S
Find the fuel vent port on bottom of wings, take off fuel caps and blow into the underwing vent. You should hear the air coming out of the fuel tanks to insure there is no blockage in the vent system. On Jul 6, 2015 11:23 AM, "Justin Drafts" <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:[quote]Good morning Steve-
Fyi,
Justin, N280NC
Thanks in advance,
Steve near Chicago
| [b]
jblake207(at)comcast.net Guest
Posted: Mon Jul 06, 2015 9:26 am Post subject: More Newby Questions |
Greg's description of the CJ fuel feeding issue is exactly correct. His remedy is also correct... simply cross control for a couple minutes and then usually they will each feed equally (or almost equally) throughout the remainder of the flight. It's a little annoying at first, but just one of those idiosyncrasies of the CJ that you slowly learn to love and accept. Sort of like your new bride leaving the toilet seat down.
The one thing I would add to Greg's post is that he mentioned the vent on the belly... Located nearer to the left wing slightly forward. If memory serves, there was a CJ that had an engine failure due to fuel starvation about 10 years ago... due to mud dobbers or some other type bug nesting in that vent. When I heard that I installed (wrapped) a small wire mesh screen over the vent opening just in case. So far, no bugs and no vent blockage. You might consider doing the same.
G'luck
JB
To: yak-list(at)matronics.com
Sent: Monday, July 6, 2015 11:43:59 AM
Subject: Re: More Newby Questions
P.S
| Quote: | Good morning Steve-
Fyi,
Justin, N280NC
Thanks in advance,
Steve near Chicago
Viperdoc
Posted: Mon Jul 06, 2015 7:21 pm Post subject: More Newby Questions |
25 ft lbs.
Doc
On Jul 6, 2015, at 11:18 AM, Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
Fyi,
Justin, N280NC
Thanks in advance,
Steve near Chicago
ist"">http://www.matronics.com/Navigator?Yak-List
_________________ Viperdoc |
Viperdoc
Posted: Mon Jul 06, 2015 7:24 pm Post subject: More Newby Questions |
Oops, sorry that was for the M14. Would assume the CJ would be similar.
Doc
Fyi,
Justin, N280NC
Thanks in advance,
Steve near Chicago
wlannon(at)shaw.ca Guest
Posted: Mon Jul 06, 2015 8:11 pm Post subject: More Newby Questions |
The generally accepted torque range for 14 mm spark plugs is 20 to 25 lb./ft. or 240 –300 lb./in. Anything above 25/300 is likely to cause excessive stretching, insulator cracking and plug failure.
Walt
Sent: Monday, July 06, 2015 8:18 PM
25 ft lbs.
Doc
[quote] Good morning Steve-
Fyi,
Justin, N280NC
Thanks in advance,
Steve near Chicago
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
Posted: Tue Jul 07, 2015 5:03 am Post subject: More Newby Questions |
Steve, I should have said when you blow thru the vent tube on the lower wing, make sure it is very low 10psi max or less!!! In addition, I would agree with Doug Sapps comments regarding finding a good CJ/ YAK mechanic to go thru the airplane with you or someone that is real familiar with it. On Jul 5, 2015 10:55 PM, "Steve Jones" <727gs(at)db3broadband.com (727gs(at)db3broadband.com)> wrote:[quote]
Thanks in advance,
Steve near Chicago
Posted: Tue Jul 07, 2015 7:20 am Post subject: More Newby Questions |
Doug,
I take no offense and you are correct. Like I said earlier, the airplane has been sitting a few years and is out of condition inspection. I've been asking around and there doesn't appear to be any CJ/Yak experts in the Chicago area. Lynn Hadler at Lake-in-the-Hills who used to take care of it retired last year and apparently moved to Tennesee. Dave Monroe and the Aerostar guys are training another guy on their airplanes to do their maintenance but he hasn't been around any CJ's. This side of offering you an airline ticket out to Chicago to look over my airplane, I have to investigate other options.
That being said, the CJ is is one of several airplanes we have built, restored and operate, ranging from gliders to aerobatic aircraft to other warbirds. I realize that that none of them is a CJ and I agree with your suggestion top have an experienced CJ guy to help out but I haven't had much luck there. I do have some former CJ owners helping out and the airplane doesn't look that complicated, just a little idiosyncratic. I was hoping to tap into all the experience and expertise on this forum to at least get it ferriable or round up enough advice and information to work with the local guys to do it here.
Are there any maintenance manuals or condition inspection guides that I may purchase or download? I do have a set of the blue parts books that came with the airplanes.
ANY advice is appreciated.
Sincerely,
Steve Jones
N76187
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
Sent: Monday, July 06, 2015 11:42 AM
Steve,
Doug Sapp
Thanks in advance,
Steve near Chicago
Doug
01234567890123
grabstein(at)gmail.com Guest
Posted: Tue Jul 07, 2015 7:54 am Post subject: More Newby Questions |
I'd suggest getting the maintenance manuals from the RPA if you don't already have them ...
http://flyredstar.org/catalog.php?cat=6&pid=40
Kurt "It" Howerton
N923YK
916-282-9231
http://cj6.scitechsys.com
http://www.baybombersquadron.com
On Tue, Jul 7, 2015 at 8:17 AM, Steve Jones <727gs(at)db3broadband.com (727gs(at)db3broadband.com)> wrote:
Doug,
Sincerely,
Steve Jones
N76187
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of doug sapp
Steve,
Doug Sapp
Thanks in advance,
Steve near Chicago
Doug
01234567890123
keithmckinley
Posted: Tue Jul 07, 2015 9:42 am Post subject: Re: More Newby Questions |
I happened to catch some of the comments on the fuel vent but not all. It's a really great place for insects to go live. Many people drill a hole(s) through the tip of the vent and slip a piece of thin safety wire thru to make it a little harder for certain insects to get in there.
Sorry if that's been mentioned already...
dabear
Joined: 21 Jan 2011 Posts: 92 Location: Warrenton, VA
Posted: Tue Jul 07, 2015 10:17 am Post subject: More Newby Questions |
Check the guys a finefield [sp?} aviation at lake in the hills. They worked on my Yak-52 a few years back (15+) and were great guys. They probably don’t know the CJ, but could work on things with help from remote experts. They do have round engine experience.
Bear
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Steve Jones
Sent: Tuesday, July 07, 2015 11:18 AM
Subject: RE: More Newby Questions
Doug,
Sincerely,
Steve Jones
N76187
Steve,
Doug Sapp
Thanks in advance,
Steve near Chicago
Doug
01234567890123456789 | Quote: | | tp://forums.matronics.com | 0 | Quote: | | tp://forums.matronics.com | 1 | Quote: | | tp://forums.matronics.com | 2 | Quote: | | tp://forums.matronics.com | 3
Posted: Tue Jul 07, 2015 10:22 am Post subject: More Newby Questions |
Actually there is supposed to be a small screen cap over the vent tube. It is normally held in place by safety wire or a cotter pin.
On Tue, Jul 7, 2015 at 10:42 AM, keithmckinley <cetopfed(at)gmail.com (cetopfed(at)gmail.com)> wrote:
| Quote: | --> Yak-List message posted by: "keithmckinley" <cetopfed(at)gmail.com (cetopfed(at)gmail.com)>
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=444522#444522
Doug
727gs(at)att.net Guest
Posted: Tue Jul 21, 2015 5:47 am Post subject: More Newby Questions |
I have a couple more quick questions.First off, is there going to be a Cj/Yak Forum at OSH?Second, is there anyone around that might be interested in checking me out in their CJ? Of course I'd cover any costs and expenses. I'd like to be ready to go when our airplane comes out of its condition inspection and it's been several years since I flew one.In fact, I'll be at OSH all week and then some. Anyone available up there?Thanks for your time,Steve JonesN76187Near Chicago
hess737(at)aol.com Guest
Posted: Tue Jul 21, 2015 5:53 am Post subject: More Newby Questions |
Steve
I have access to both a standard CJ and one with an M14P. You can reach me off list.
Richard HessC 404-964-4885
On Jul 21, 2015, at 9:44 AM, Stephen Jones <727gs(at)att.net (727gs(at)att.net)> wrote:
[quote]I have a couple more quick questions.
Steve Jones
N76187
Near Chicago
cs.com
