ADS-B In Plus
graybeard
PostPosted: Fri Jun 26, 2015 10:53 am    Post subject: ADS-B In Plus Reply with quote
Next question. I am looking at potential ADSB-In antenna locations. My comm. antenna will be just aft of the front spar on the left side with the X-ponder antenna just forward of the F-807 bulkhead and between the right F-813 and 814 seat ribs. Just makes the recommended 36 in. separation. For the ADSB-in, I am seriously looking at the left side forward of the F-808 bulkhead and outboard of the F-818 baggage rib with minimum 24 in. separation from the X-ponder antenna. I think there’s adequate ground clearance at that location. With a forward battery, I could make a bracket for the Dynon ADSB-470 receiver to mount back there. Makes for a really short antenna cable run, but I don’t know for sure if proximity to the A/P pitch servo creates any issues. So, good choice or better options? I also welcome any and all recommendations on routing antenna cables. I am trying to absorb everything I can get about avoiding RFI and any other kinds of I that might cause problems. Gives me a headache.
Stan Loer
RV8 QB
Site Admin
PostPosted: Sat Jun 27, 2015 9:59 am    Post subject: ADS-B In Plus Reply with quote
Stan Loer
RV8 QB
Hi Stan,
I've got the NavWorx certified ADSB in my RV-8. I mounted the Garmin GTX-327 transponder antenna right in the middle right behind the main spar. I mounted the NavWorx ADSB antenna right behind the elevator bellcrank. Everything seems to be working fine. Attached are some pictures.
Status: 182+ Hours TTSN - Version 2.0 Now Flying!
Status: 300+ Hours - Full Flyer Mode!
 Filesize:  113.69 KB
 Viewed:  5535 Time(s)
 Filesize:  153.13 KB
 Filesize:  92.96 KB
 Filesize:  94.46 KB
 Filesize:  121.13 KB
 Filesize:  116.15 KB
 Filesize:  129.2 KB
 Filesize:  112.69 KB
 Filesize:  111.69 KB
 Filesize:  97.84 KB
