donjohnston
Posted: Thu Jun 04, 2015 1:22 am Post subject: Alternator with no battery? |
Does anyone know what the impact of a loss of battery output (wire coming loose, solenoid failing, battery falling out of the plane, being stolen in flight by aliens, etc.) on the output of the alternator (with engine running at cruise power)?
It would seem to me that if the load is less than the output of the alternator, it should continue to put out power as long as the engine is running.
But I recall (years ago) that a friend was driving home from a trip at night and his battery had some type of failure. He said that it took a couple hours but eventually his headlights were so dim that he had to stop until the battery could be replaced.
Bob McC
Posted: Thu Jun 04, 2015 5:06 am Post subject: Alternator with no battery? |
That sounds a lot more like an alternator failure than a battery failure. When the alternator quit, or was no longer able to supply all the load, the battery took over the load until it was drained to a level insufficient to maintain sufficient voltage to power the vehicle and it stopped. A new battery would not "solve" this problem without some restoration or repair being done to the charging system as well.
Some running alternators will maintain system loads without a battery, but should the alternator be "stalled" with heavy loads it may or may not restart on load reduction depending on the particular components in question.
Bob McC
Quote: | Subject: Alternator with no battery?
Date: Thu, 4 Jun 2015 02:22:48 -0700
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com>
http://forums.matronics.com/viewtopic.php?p=442980#442980
_________________ Bob McC
Falco #908
(just starting) |
user9253
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Thu Jun 04, 2015 5:13 am Post subject: Re: Alternator with no battery? |
Many alternators will keep generating when the battery is disconnected. Your friend's experience sounds more like an alternator failure than a battery failure.
Joe
_________________ Joe Gores |
donjohnston
Posted: Thu Jun 04, 2015 6:37 pm Post subject: Re: Alternator with no battery? |
Sigh... Let me try this again:
wrmaxwell(at)bigpond.com Guest
Posted: Thu Jun 04, 2015 7:10 pm Post subject: Alternator with no battery? |
I had a friend, a fellow ham radio operator, who experienced one connection to the battery in his Mitsubishi Express van some years ago. The alternator did its stuff, trying to re-establish 14 volts or so at the battery terminal - and fried much of the onboard electronics, including his radio transceiver, in the process.
Bill
On 5/06/2015 12:37 PM, donjohnston wrote:
[quote] Quote: | --> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com> (don(at)velocity-xl.com)
http://forums.matronics.com/viewtopic.php?p=443059#443059
| [b]
jluckey(at)pacbell.net Guest
Posted: Thu Jun 04, 2015 9:10 pm Post subject: Alternator with no battery? |
Bill,
There is a commonly held belief that running an alternator without a battery can be risky because voltage regulation can be problematic. The battery acts as a big voltage stabilizer which allows the regulator to work properly. If the battery is somehow disconnected then that stabilization disappears and the regulator may not be able to handle it, causing a voltage run-away situation.
Once upon a time, I had to clean-up after one of these events. It was a 12-volt system on a boat. Someone had turned-off the main battery switch while the engine was running and the buss voltage went way above the normal 14 volts. The event took-out a VHF radio, a radar, and an automotive stereo.
Bill Maxwell's reply above describes a similar scenario in a car.
Anecdoteally...
BobN has suggested that some aircraft (I think he mentioned a Bonanza or Baron) can operate in an alternator-only, no-battery-in-the-circuit mode, but I don't have any knowledge of this. Perhaps the aircraft in question has a very exotic regulator. BobN can speak to this better than I.
I have had auto mechanics tell me that if you disconnect the battery while the engine is running - DON'T DO THAT! But if you do, it will void the warranty on the electronic components of the vehicle.
Design Notes:
I think of the battery/alternator system as being symbiotic. The alternator cannot make electricity without a little initial help from the battery and the battery acts as a voltage stabilizing force when high-current events occur. And, of course, batteries cannot sustain loads indefinitely by themselves. They work together as a team.
Whenever I design an electrical system, I make it so that if you open the battery contactor, the circuit also turns-off the alternator, so that you cannot deliberately take the battery out of the circuit with the alternator on. I consider an alternator running with no battery in the circuit to be an invalid state.
You will notice that the old red Cessna master/alternator rocker switch does exactly the same thing. It allows the pilot to turn the alternator field on and off independent of the battery master but when you turn-off the master it turns-off the alternator field thru the mechanical interlock built into the switch.
Now to your question - What happens if the battery somehow gets disconnected in flight due to master contactor failure, wire failure, aliens, etc?
I see two possibilities:
1. The regulator keeps on regulating and buss voltage remains stable.
2. The reguator can no longer keep the voltage stable and buss voltage goes up. If you have over-voltage protection, it trips and keeps your avionics from being fried but leaves you without power. (unless you have some kind of backup power source)
How your particular system will respond is anybody's guess. If you have over-voltage protection, you could test it with little risk to your avionics??? (preferable on the ground
There was discussion a while back here on the List about testing some of these hypotheses, but that would take some hefty test fixtures and some effort. I would like to play on that team if anyone is interested in a team effort.
-JeffL
On Thursday, June 4, 2015 8:18 PM, Bill Maxwell <wrmaxwell(at)bigpond.com> wrote:
Bill
Quote: | Quote: | --> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com> (don(at)velocity-xl.com)
ronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
matronics.com/">http://forums.matronics.com
ronics.com/contribution">http://www.matronics.com/contribution
dlj04(at)josephson.com Guest
Posted: Thu Jun 04, 2015 11:52 pm Post subject: Alternator with no battery? |
The OP asked not for analysis of the reported automotive failure, but
Quote: | Does anyone know what the impact of a loss of battery output (wire coming loose,
power)?
Quote: | It would seem to me that if the load is less than the output of the alternator,
In most cases it would, but there are other problems due to the high ripple component of some alternators Rotax for instance recommends a 22,000 uF capacitor specifically to smooth the ripple from their PM alternator in case the battery is not functioning. Homebuilders using low impedance capacitors with heavy screw terminals are on the right track. Some LSA manufacturers use tiny caps with thin wires, not a good recipe if you really want to get pulses of current at the full alternator rating into and out of the capacitor.
yellowduckduo(at)gmail.co Guest
Posted: Fri Jun 05, 2015 3:22 am Post subject: Alternator with no battery? |
An open battery contactor with an external regulator that is sensing
voltage at the battery is going to go high voltage and be expensive.
Different situation wih the sense wire on the alternator side of the
contactor or an internal regulator. No guarantees but I have seen those
continue to function fine when a flooded cell battery went open circuit.
Ken
donjohnston
Posted: Fri Jun 05, 2015 5:04 am Post subject: Alternator with no battery? |
Anecdoteally...
Actually, I designed several regulators
for Beech wherein the a requirement in the
RFQ was that the regulator, when paired with
the Bonanza and Baron alternators of the time,
would come alive self-excited . . . and run
self excited with no battery on line.
This was my first, second and third
regulator designs . . . had no idea if
anything 'special' was needed. As it
turn out, nothing really special. What
was NOT spec'd was the recovery profile
from a large load change . . . especially
a load dump. The overshoot would trip
the ov protection . . . but the transient
was still inside DO-160 qualification
levels.
What I discovered then was that the alternator
output was stable but subject to pretty
big, transient swings of voltage for large
changes in load. Like turning a 100+
watt landing light on/off . . . or perhaps
cycling an electrically driven, landing
gear pump.
Loss of battery in a stable load configuration
would probably go unnoticed and represent
no threat to system hardware. If the hardware
is DO-160 qualified, then transients of 20 volts
for one second and 40 volts for 100 milliseconds
are tolerated. It's the no-battery scenario
that drove selection of the test requirements
spelled out in DO-160. See
http://tinyurl.com/ybhvxal
I'll do some playing with no-battery
systems then next time I get on the bench.
Yeah . . . the same physics applies here.
In AUTOMOTIVE parlance, a "load dump" is
battery disconnect while alternator is under
heavy load . . . and the BATTERY is a substantial
part of that load. i.e. the battery is badly
discharged and the alternator is working hard
to replace stored energy. This generates the
same scenario as operating an airplane, alternator
only and turning off some heavy load.
Don't know about that 'void the warranty' thingy,
not sure how anyone would KNOW that it was a
deliberate disconnection. No doubt, some
dealerships are inclined to behaviors not
unlike some avionics techs of days gone by:
"Gee, I think a spike got it".
Most OEM equipment in cars is designed with
goals equal to or greater than DO160. I've
seen some specs for things like heated seat
controllers. An OEM brought one out to the BEECH
EMC building for testing services. The requirements
document from GM was about 1/2" thick!
I was at Cessna when the split-rocker master switch
was birthed. The functionality of the split-rocker
master has been emulated in most of the Z-figures
http://tinyurl.com/kdqwahq
This was a time when not all appliances were
vetted to DO-160 input voltage conditions . . .
and the alternators could not be counted on
to self-excite. Airplanes we delivered the
year before with generators would start up and
run very happily generator only. To this day,
so will Beechjets and Hawkers. This was very
EARLY in the switch from generators to alternators in
aircraft and we were certainly not designers
of engine drive power sources. So the split
rocker was a hedge against having to re-educate
pilots who knew less than we did!
True 99% of the time
No
It's not a guess. The physics is well known.
I've got some work to do at B&C this year and
I'm going to rebuilt their alternator test stand
with modern instrumentation and loads. I'll be
working on some products that will be tested for
these conditions.
I don't think we're going to learn anything new
but we can probably put some sense of scale and
order on the anecdotal tales based on a few
nuggets of physical fact and too little data
on circumstance . . . like that 'shorted battery'
thing in the NTSB report. I can assure you that
far too little is known about what brought that
airplane down. I have no foundation to argue about
the shorted battery . . . but I'm exceedingly
skeptical that battery failure was root cause
or even a major contributor. This was an automotive
conversion engine and the fact that the builder
had two batteries wired in parallel in the first
place raises some questions as to design goals
and understanding of the physics. A short in
one of two paralleled batteries would cause so
anomalous system readings but it doesn't bring
down the bus. Something else was going on.
Bob . . . [quote][b]
user9253
Posted: Fri Jun 05, 2015 6:09 am Post subject: Re: Alternator with no battery? |
Quote: | A short in one of two paralleled batteries would cause so anomalous system readings
but it doesn't bring down the bus. Something else was going on. |
Bob, this is very interesting. Can you explain the physics that apply when two batteries are connected in parallel and one of them shorts internally? I had always assumed that a low voltage on one battery would drag down the voltage of a parallel battery. Pilots who fly aircraft with two batteries need to know what symptoms will be and what action to take, if any.
Thanks, Joe
jmjones2000(at)mindspring Guest
Posted: Fri Jun 05, 2015 9:02 am Post subject: Alternator with no battery? |
Sounds like another good case for an OVM.
On Jun 5, 2015, at 05:02, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote] Anecdoteally...
levels.
gear pump.
No
these conditions.
donjohnston
Posted: Fri Jun 05, 2015 12:51 pm Post subject: Re: Alternator with no battery? |
This is very interesting. Thanks to everyone for participating.
So is it safe to say that the battery is providing a type of surge suppression (or power leveling or fluctuation dampening) function in this circuit?
And if it's correct that the absence of the battery could cause an over voltage situation, is there a way to mitigate that? Or is that scenario so unlikely that it's not worth protecting against?
Posted: Sat Jun 06, 2015 8:24 am Post subject: Alternator with no battery? |
On 6/6/15 12:00 AM, AeroElectric-List Digest Server wrote:
Quote: | Time: 01:53:19 PM PST US
Subject: Re: Alternator with no battery?
Yes.
There is a way to mitigate that, if you want. An overvoltage protection
circuit can take a runaway alternator/regulator offline in the case of
an open battery. This is probably a less likely possibility at least for
lead-acid batteries than the possibility of the OVP taking the
alternator offline at inconvenient times for other reasons. Systems
engineering is based on understanding and weighing all of the
foreseeable consequences -- more protection does not necessarily equate
to fewer failure experiences. As Bob has explained in the past, modern
aircraft loads are much more tolerant of overvoltage conditions than was
the case years ago.
Having had such an experience in my Mooney when the regulator ground
wire came loose, I can report that it was preferable to manually shed
loads known to be voltage-sensitive (no DME for you today!), add
additional loads like pitot heat and landing lights to bring the voltage
down. You can manage the situation, rather than pop the alternator
offline (particularly automatically, with no possibility for reset) and
trust the battery to supply the energy for the remainder of the flight.
David Josephson
Posted: Sun Jun 07, 2015 7:12 am Post subject: Alternator with no battery? |
It seems that the answer presented is that 'many' alternator
installations will continue to provide power but may be subject to being
'stalled' by heavy loads.
Specificity would seem to be required to take this further. The next
question would seem to be, "what components and configuration are you
curious about"?
So, I have (3) B&C LR3C-14 regulators controlling (2) B&C alternators.
Another question might be "Is there a difference between a battery
losing a cell (partial failure) and a 'broken battery cable' or (total
failure)"?
Bill "just following along out of curiosity" Watson
Checked by AVG - www.avg.com
