Hobbs meter
Looigi
PostPosted: Thu Jun 04, 2015 2:00 am    Post subject: Hobbs meter Reply with quote
Hello All,
Can anyone cast any light on fitting a Hobbs hour meter to a Yak 52?
Putting the indicator in is easy, but how is it turned on? I am looking for a method that records flight hours rather than engine hours so a simple oil pressure switch is probably not going to work.
Has anyone got any other suggestions please?
Many thanks
Chris
dsavarese0812(at)bellsout
PostPosted: Thu Jun 04, 2015 3:23 am    Post subject: Hobbs meter Reply with quote
My GPS (Garmin Aera 510) records flight hours based on the ground speed of the aircraft. I've forgotten what the ground speed "trigger" is, but I think it is something like 25 knots or MPH. If you do use a GPS, check the manual because I am pretty sure it logs flight time once you start down the runway and achieve a certain airspeed.  It stops counting once the speed drops below the "trigger" speed.
Dennis
To: yak-list(at)matronics.com
Sent: Thursday, June 4, 2015 5:00 AM
Subject: Hobbs meter
--> Yak-List message posted by: "Looigi" <cdoburton(at)gmail.com (cdoburton(at)gmail.com)>
Hello All,
Many thanks
Chris
http://forums.matronics.com/viewtopic.php?p=442982#442982
dougsappllc(at)gmail.com
PostPosted: Thu Jun 04, 2015 6:06 am    Post subject: Hobbs meter Reply with quote
Why not pull power off the gear up light?Doug
On Thu, Jun 4, 2015 at 4:19 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
[quote]My GPS (Garmin Aera 510) records flight hours based on the ground speed of the aircraft.  I've forgotten what the ground speed "trigger" is, but I think it is something like 25 knots or MPH.  If you do use a GPS, check the manual because I am pretty sure it logs flight time once you start down the runway and achieve a certain airspeed.  It stops counting once the speed drops below the "trigger" speed.
Dennis
From: Looigi <cdoburton(at)gmail.com (cdoburton(at)gmail.com)>
Hello All,
Many thanks
Chris
http://forums.matronics.comhttp://www.matronics.com/contribution
et="_blank">http://www.matronics.com/Navigator?Yak-List
jblake207(at)comcast.net
PostPosted: Thu Jun 04, 2015 6:26 am    Post subject: Hobbs meter Reply with quote
If the purpose is recording flight, then shouldn't that time begin when you pull out of the chalks and stop at engine shut down? BTW I use the GPS method Dennis described. JB
Sent from my Verizon Wireless 4G LTE DROID
doug sapp <dougsappllc(at)gmail.com> wrote:
[quote]Why not pull power off the gear up light?
Doug
On Thu, Jun 4, 2015 at 4:19 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net> wrote:
Dennis
Subject: Yak-List: Hobbs meter
Hello All,
Many thanks
Chris
et="_blank">http://www.matronics.com/Navigator?Yak-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution
_-============================================================ _-= - The Yak-List Email Forum - _-= Use the Matronics List Features Navigator to browse _-= the many List utilities such as List Un/Subscription, _-= Archive Search & Download, 7-Day Browse, Chat, FAQ, _-= Photoshare, and much much more: _-= _-= --> http://www.matronics.com/Navigator?Yak-List _-= _-============================================================ _-= - MATRONICS WEB FORUMS - _-= Same great content also available via the Web Forums! _-= _-= --> http://forums.matronics.com _-= _-============================================================ _-= - List Contribution Web Site - _-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-= --> http://www.matronics.com/contribution _-============================================================
jackpot
PostPosted: Thu Jun 04, 2015 8:44 am    Post subject: Hobbs meter Reply with quote
Flight time for your personal log log book is time out of the chocks, and time back into the chocks. Aircraft time for the airplane maintenance time and total Acft time is recorded from takeoff to landing.
Gary
CJ N22YK
On Jun 4, 2015, at 07:25, Jon Blake <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
[quote]If the purpose is recording flight, then shouldn't that time begin when you pull out of the chalks and stop at engine shut down? BTW I use the GPS method Dennis described. JB
Dennis
Hello All,
Many thanks
Chris
cs.com
¦·›~‰í²,ÞÙÊ%¢½4ÓM4}§r‹«‰êç{(º¸ž­8^a© ŠËD™¨¥Šî™K¶ŒjÚèž',.+-æ­º·¬5«â«h®Ú®Œ,zØ^™©ò.+-ºØ¥ŠØž²Ëœ…« ŠËTŸô®nÇ+Š›b¢p+r¯y'š­ÈC£ å¡§{ ¬®Œ,x(Z´P>-¢ÈZ­æ§vkœ†kœ†j+y¨kyøm¶Ÿÿà &jÚèž',r‰¿5«â«h­†¤.+-†Ûiÿü0Âf­®‰ârÇ(›óZ¾(¶ŠØjBâ²ßÚ0Ñ8ÒIaäT1$š™è+y«\¢{^žÖ¥²†¯j)ZnW¯‰«ayg›Šî寃çá¶Úýú+ºk&jÚèž',r‰¡¶Úýú+ºk&jÚèž',r‰¿h¸¬´*'¶¸›ºØ¨g›J+^N§“*.~Šò¢êàzw«¢ë,ºšh®Ó¶ÐëjY^.+-Ù¢¨kyøm¶Ÿÿà &jÚèž',r‰¿r‰í®&î¶*'†Ûiÿü0Âf­®‰ârÇ(›÷(žÚânëb¢Úý¿ß¢{¦·¿n‡rþf
