vincefrazier(at)gmail.com Guest
				 Posted: Wed Jun 03, 2015 5:31 am    Post subject: RV-List Digest: 1 Msgs - 06/02/15 |
				Good common sense tip!  Thanks Linn!
  	  | Quote: | 	 		        1. 02:37 PM - pouring from 'paint cans'  (Linn Walters)
  ________________________________  Message 1  _____________________________________
  Time: 02:37:57 PM PST US
  Subject: pouring from 'paint cans'
  I hope I'm not the only one that didn't know this trick .....
  I bought a quart of 2-part hi-temp epoxy that came in small 'paint'
  cans.  I was trying to figure a way to pour the resin (3.3 to 1 by
  weight mix) without having to clean out the 'groove' each time. What I
  ended up with was two pieces of blue painters tape in the shape of a 'V'
  that just covers the inner ring.  I have to clean the inner ring before
  each pour so the tape will stick to it.  I pour the thick part (the 1)
  first since it's more viscous than the other (3.3) and use a finger
  (wear your rubber gloves!) to wipe the outside residue into the paper
  cup on the scale.  The resin on the underside of the tape will drain
  back into the can, and you just have to remove and dispose of the tape.
  Linn
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
