pdelano(at)telus.net Guest
Posted: Fri May 15, 2015 4:59 pm Post subject: CH-750 vs CH-701 |
I have not asked this question of Zenith, and I know that is where the definitive answer needs to come from, but what is the list’s opinion of using a Ch-750 firewall forward on a Ch-701 with an O-200 Continental.
Perry Delano
dougsnash
Posted: Fri May 15, 2015 6:18 pm Post subject: CH-750 vs CH-701 |
A very simple answer Perry, DON'T
The 750 firewall is substantially different than the 701. Additionally, the 701 has a max recommended firewall weight of 200 lbs and the O-200 is around 240lbs. Can a O-200 be made to fly a 701? Sure but it is not going to come close to the performance of a 701 with a 912 installed. If price is a consideration, there are good used 912 engines to be found, it just takes a bit of scrounging.
Doug M
Sent from my iPad
On May 15, 2015, at 20:00, Perry Delano <pdelano(at)telus.net (pdelano(at)telus.net)> wrote:
[quote] <![endif]--> <![endif]-->
Perry Delano
h701801-List"">http://www.matronics.com/Navigator?Zenith701801-List
//forums.matronics.com
Posted: Sat May 16, 2015 6:39 pm Post subject: CH-750 vs CH-701 |
Hi Doug,As always thanks for the reality check. The thought hit me as I am a member of CH85 RAA and member of the builders group and we are building a 750 cruiser as a club plane and planning on an 0-200.Regards,PerrySent wirelessly from my BlackBerry device on the Bell network.Envoyé sans fil par mon terminal mobile BlackBerry sur le réseau de Bell.
Sender: owner-zenith701801-list-server(at)matronics.com
Date: Fri, 15 May 2015 21:17:48 -0500
To: zenith701801-list(at)matronics.com<zenith701801-list(at)matronics.com>
ReplyTo: zenith701801-list(at)matronics.com
Subject: Re: Zenith701801-List: CH-750 vs CH-701
The 750 firewall is substantially different than the 70= 1. Additionally, the 701 has a max recommended firewall weight of 200 l= bs and the O-200 is around 240lbs. Can a O-200 be made to fly a 701? &= nbsp;Sure but it is not going to come close to the performance of a 701 with= a 912 installed. If price is a consideration, there are good used 912= engines to be found, it just takes a bit of scrounging.
Doug M
Sent from my iPad
On May 15, 2015, at 20:0= 0, Perry Delano <pdelano(at)telus.net</= a>> wrote:
| Quote: | <![endif]--> <![endif]-->
I have not asked this question of Zenith, and I know that is where t= he definitive answer needs to come from, but what is the list=E2=80=99s opin= ion of using a Ch-750 firewall forward on a Ch-701 with an O-200 Continental= .
Perry Delano
D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=
=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D=
h701801-List"">http://www.matronics.com/Navigator?Zenith701801-List=
| = [quote][b]
dlorrzen701(at)earthlink. Guest
Posted: Sun May 17, 2015 6:07 am Post subject: CH-750 vs CH-701 |
Perry, I am in the final stages of building my 701 with C-85-12F. W&B looks great. My engine was 207 lb after putting a skytek starter and B&C alternator. My empty weight was 667 lbs. Hope to be inspected and flight testing soon. There are s lot of 701 examples with Continental engines and they fly just fine..keep it trim.
David L. Orr
Sent from my Verizon Wireless 4G LTE DROID
Perry Delano
john.marzulli(at)gmail.co Guest
Posted: Sun May 17, 2015 6:58 am Post subject: CH-750 vs CH-701 |
Good to hear you are almost done David!
Any pics?
On Sun, May 17, 2015 at 7:08 AM David L Orr <dlorrzen701(at)earthlink.net (dlorrzen701(at)earthlink.net)> wrote:
[quote]Perry, I am in the final stages of building my 701 with C-85-12F. W&B looks great. My engine was 207 lb after putting a skytek starter and B&C alternator. My empty weight was 667 lbs. Hope to be inspected and flight testing soon. There are s lot of 701 examples with Continental engines and they fly just fine..keep it trim.
David L. Orr
Â
Â
Perry Delano
ist" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
tp://forums.matronics.com
| [b]
