FWF Seal
spcialeffects
PostPosted: Thu May 14, 2015 11:37 am    Post subject: FWF Seal Reply with quote
Hi all. Could someone please tell me what this sealing material is called and possibly where i might buy some, Many thanks
http://www.europaowners.org/main.php?g2_itemId=79612
Burrilla
PostPosted: Thu May 14, 2015 12:14 pm    Post subject: FWF Seal Reply with quote
Looks like;
Silicone Baffle Seal
here: http://www.lasaero.com/site/products/article?id=T01VKIAZ1
alan
On 14 May 2015, at 20:37, spcialeffects <spcialeffects(at)aol.com (spcialeffects(at)aol.com)> wrote:
[quote]--> Europa-List message posted by: "spcialeffects" <spcialeffects(at)aol.com (spcialeffects(at)aol.com)>
http://forums.matronics.com/viewtopic.php?p=442108#442108
davidjoyce(at)doctors.org
PostPosted: Thu May 14, 2015 11:12 pm    Post subject: FWF Seal Reply with quote
If you are just looking for a sealant for holes in the firewall carrying cables or hoses, go to a plumbers merchant and get a heat resistant silicone, which is used to seal around boiler flues. Resistant to temps over 250C I believe.
Regards, David Joyce, GXSDJ
On 2015-05-14 20:37, spcialeffects wrote: [quote]
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.matronics.com/contribution
dpark748(at)icloud.com
PostPosted: Fri May 15, 2015 10:04 am    Post subject: FWF Seal Reply with quote
Demon Tweeks have itDave G-LDVO
On 14 May 2015, at 21:13, Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)> wrote:
[quote]Looks like;
alan
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
spcialeffects
PostPosted: Fri May 15, 2015 10:18 am    Post subject: Re: FWF Seal Reply with quote
Thanks for the replies. Burrilla- it certainly looks like the stuff. Is it fire proof?
David- Yes ive already got my 3M fire sealent for industrial boilers which expands the hotter it gets (was advised by ivor phillips on that one) But i liked the look of the installation in the link as i too am lucky enough to have the singleton fire wall which i am fitting instead of the alloy one, however the holes cut into it to get over the landing gear mounting frame are quite big and once over the mounting lugs i think this looks neater rather than filling it with the 3M mastic stuff
