jblake207(at)comcast.net Guest
Posted: Fri May 08, 2015 1:52 pm Post subject: Motor oil |
Need your opinions... I've always used Aeroshell 100 straight 50 weight oil. However, the local oil company where I've always bought my oil went out of business. Through another local company I can get the multi viscosity Phillips 20w50, but not sure about using it in a round motor, especially in the hot environment of the SE US. What say you? JB
Sent from my Verizon Wireless 4G LTE DROID
Posted: Fri May 08, 2015 2:06 pm Post subject: Motor oil |
Philips 25W-60 which is for radial engines.
From the Philips web site:
"X/C 25W-60 Aviation Oil is recommended for use in radial pistonengines and in other aviation piston engines originally designed torun on heavier-grade oils, such as Commercial Grade 120."
Dennis
To: yak-list(at)matronics.com
Sent: Friday, May 8, 2015 4:50 PM
Subject: Yak-List: Motor oil
freighttrain(at)mac.com Guest
Ernie
Posted: Fri May 08, 2015 2:16 pm Post subject: Motor oil |
My local Sams Club carries the Aeroshell 100. If you have one local ask
them to stock it.
Ernie
On Fri, May 8, 2015 at 6:07 PM, Dave Laird <freighttrain(at)mac.com> wrote:
| Quote: | Jon,
http://www.airplaneoil.com/AeroShell_w100_Oil_p/aero100w-qts.htm?gclid=COKD6YuSs8UCFQsJaQodyrIAKg
One way to get it...
If you go to the Phillips, I'd get 25W60...
It's made for radials.
Some people say the Phillips leaks out of the engine more than the
Aeroshell.
If you search the yak-list with the matronics search engine you'll get a
lot of opinions on this very subject from over many years!
Dave Laird
N63536 1983 CJ6A "Betty"
Sent from my iPhone.
*Sent from my Verizon Wireless 4G LTE DROID*
ky·èžÛ"Ã�ÃϢZ+ÓM4ÓGÚqç(º¸ž®w°r‹«‰êÓ…æ ¸¬´IšŠQh®éâ€�±ëaxÆÂ®‰ârÂâ²Ñ^jÛ«zÃZ¾(
¶ŠÃ¡ºèÂÇÂ…隟"â²ÛÂÅ X‰ë,¹ÈZ°¸¬µIÿJæìr¸©¶*' ·!Š÷’yªÜ„:0žZ w°ÚÈ èÂÇ‚…«E
á¢Ú,…ªÞjwf¹Èf¹Èf¢·š†·Ÿ†Ûiÿü0Âf®‰ârÇ(›óZ¾( ¶ŠØjBâ²Øm¶Ÿÿà &jÚèž',r‰¿5«â
«h†¤.+-ý£M $– NEC I©ž‚·šµÊ'µéÃj[(jö¢•¦åzøš¶ –y±h®é¬j Þ~ m§ÿߢ»¦²f®‰ârÇ(Å¡
m§ÿߢ»¦²f®‰ârÇ(›ö‹ŠËB¢{k‰»ÂЉÖy´¢µäájy2¢çè¯*.® §zº.²Ë©¦ŠÃ1«m ¶¥•ââ²Ã�
Å¡)Ú†·Ÿ†Ûiÿü0Âf®‰ârÇ(›÷(žÚânëb¢xm¶Ÿÿà &jÚèž',r‰¿r‰Ã®&î¶*'ý¯Ûýú'·úk{öèw/á¶i
_-============================================================
_-= - The Yak-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?Yak-List <http://www.matronics.com/Navigator?Yak-List>
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com <http://forums.matronics.com>
_-=
_-= - List Contribution Web Site -
_-= Thank you for your generous support!
_-= -Matt Dralle, List Admin.
_-= --> http://www.matronics.com/contribution <http://www.matronics.com/contribution>
Posted: Fri May 08, 2015 3:28 pm Post subject: Motor oil |
Actually, I would recommend 20-60.
From: owner-yak-list-server(at)matronics.com [owner-yak-list-server(at)matronics.com] on behalf of Jon Blake [jblake207(at)comcast.net]
Sent: Friday, May 08, 2015 5:50 PM
Subject: Motor oil
ky���"�휢Z+�M4�G�q�(����w�r����Ӆ�����I��Qh�锱�axÆï¿½ï¿½ï¿½r���^jÛ«z�Z�(������Ç�隟"�Û�X���,��Z����I�J��r���*'�!���y�܄:0�Zw�����ǂ��E��,���jwf��f��f��������i��0�f����r�(��Z�(���jB��m���� &j��',r��5�â�«h���.+-��M� $�NECI�������'���j[(j�����z����y�h��j�~m��ߢ���f����r�(�m��ߢ���f����r�(�����B�{k������y�����jy2���*.��z�.�˩���1�m�������)چ����i��0�f����r�(��(���n�b�xm���� &j��',r��r��&�*'�����'��k{��w/�i
Posted: Fri May 08, 2015 3:32 pm Post subject: Motor oil |
The main consideration with this kind of oil is the temperature extremes that you experience. Ernie's Aeroshell 100 is fine if you live in a stable climate with very little temperature change.
Otherwise Phillips 20-60W Radial Engine Oil is the way to go.
Mark
From: owner-yak-list-server(at)matronics.com [owner-yak-list-server(at)matronics.com] on behalf of Ernest Martinez [erniel29(at)gmail.com]
Sent: Friday, May 08, 2015 6:15 PM
To: yak-list
Subject: Re: Motor oil
My local Sams Club carries the Aeroshell 100. If you have one local ask them to stock it.
Ernie
On Fri, May 8, 2015 at 6:07 PM, Dave Laird <freighttrain(at)mac.com<mailto:freighttrain(at)mac.com>> wrote:
Jon,
Some people say the Phillips leaks out of the engine more than the Aeroshell.
If you search the yak-list with the matronics search engine you'll get a lot of opinions on this very subject from over many years!
Dave Laird
On May 8, 2015, at 4:50 PM, Jon Blake <jblake207(at)comcast.net<mailto:jblake207(at)comcast.net>> wrote:
ky·èžÛ"Ã�ÃϢZ+ÓM4ÓGÚqç(º¸ž®w°r‹«‰êÓ…æ ¸¬´IšŠQh®éâ€�±ëaxÆÂ®‰ârÂâ²Ñ^jÛ«zÃZ¾( ¶ŠÃ¡ºèÂÇÂ…隟"â²ÛÂÅ X‰ë,¹ÈZ°¸¬µIÿJæìr¸©¶*' ·!Š÷’yªÜ„:0žZ w°ÚÈ èÂÇ‚…«E á¢Ú,…ªÞjwf¹Èf¹Èf¢·š†·Ÿ†Ûiÿü0Âf®‰ârÇ(›óZ¾( ¶ŠØjBâ²Øm¶Ÿÿà &jÚèž',r‰¿5«â «h†¤.+-ý£M $– NEC I©ž‚·šµÊ'µéÃj[(jö¢•¦åzøš¶ –y±h®é¬j Þ~ m§ÿߢ»¦²f®‰ârÇ(Å¡ m§ÿߢ»¦²f®‰ârÇ(›ö‹ŠËB¢{k‰»ÂЉÖy´¢µäájy2¢çè¯*.® §zº.²Ë©¦ŠÃ1«m ¶¥•ââ²Ã� Å¡)Ú†·Ÿ†Ûiÿü0Âf®‰ârÇ(›÷(žÚânëb¢xm¶Ÿÿà &jÚèž',r‰¿r‰Ã®&î¶*'ý¯Ûýú'·úk{öèw/á¶i
���~��,���%��4�M4}�r�����{(����8^a� ��D�����K��j��',.+-æºï¿½ï¿½5�â�«h����,z�^���.+-�إ�؞�˜�� ��T��n�+��b�p+r�y'���C� å¡§{ ����,x(Z�P>-��Z��vk��k��j+y�ky�m���� &j��',r��5�â�«h���.+-��i��0�f����r�(��Z�(���jB���0�8�Ia�T1$���+y�\�{^�֥���j)ZnW���ayg���ơ������+�k&j��',r������+�k&j��',r��h���*'����ب�g�J+^N��*.~����zw���,��h�����jY^.+-٢��ky�m���� &j��',r��r��&�*'��i��0�f����r�(��(���n�b����ߢ{���n�r�f
wlannon(at)shaw.ca Guest
Posted: Fri May 08, 2015 8:08 pm Post subject: Motor oil |
The Phillips designation is actually X/C 25W60.
A quick description of the viscosity identification as some may be confused
by the different numbers: --
The original aviation designation for oil viscosity measurement was given in
Saybolt Universal Seconds or SUS. That is still in use by Shell, Exxon and
others for their traditional oils. E.G. Aeroshell 65, 80, 100 and 120.
Multi-grade aviation oils use the SAE (Society of Automotive Engineers)
designation system. E.G. Aeroshell 15W50, Phillips X/C 20W50 and 25W60.
Correlation:-- SUS 120 = SAE 60, SUS 100 = SAE 50, SUS 80 = SAE 40.
Walt
Viperdoc
Posted: Fri May 08, 2015 9:16 pm Post subject: Motor oil |
Been using Phillips for 10 years. No problems from it for me.
Doc
Sent from my iPad
On May 8, 2015, at 4:50 PM, Jon Blake <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
[quote]Need your opinions... I've always used Aeroshell 100 straight 50 weight oil. However, the local oil company where I've always bought my oil went out of business. Through another local company I can get the multi viscosity Phillips 20w50, but not sure about using it in a round motor, especially in the hot environment of the SE US. What say you? JB
ky·èžÛ"Ã�ÃϢZ+ÓM4ÓGÚqç(º¸ž®w°r‹«‰êÓ…æÂ�¸¬´IšŠQh®éâ€�±ëaxÆÂ®‰ârÂâ²Ñ^jÛ«zÃZ¾(¶ŠÃ¡ºèÂÇÂ…隟"â²ÛÂÅ X‰ë,¹ÈZ°¸¬µIÿJæìr¸©¶*'·!Š÷’yªÜ„:0žZw°ÚÈèÂÇ‚…«Eá¢Ú,…ªÞjwf¹Èf¹Èf¢·š†·Ÿ†Ûiÿü0Âf®‰ârÇ(›óZ¾(¶ŠØjBâ²Øm¶ŸÿÃ&jÚèž',r‰¿5«âÂ�«h†¤.+-ý£MÂ� $–NECI©ž‚·šµÊ'µéÃj[(jö¢•¦åzøš¶–y±h®é¬jÞ~m§ÿߢ»¦²f®‰ârÇ(Å¡m§ÿߢ»¦²f®‰ârÇ(›ö‹ŠËB¢{k‰»ÂЉÖy´¢µäájy2¢çè¯*.®§zº.²Ë©¦ŠÃ1«m¶¥•ââ²Ã�Å¡)Ú†·Ÿ†Ûiÿü0Âf®‰ârÇ(›÷(žÚânëb¢xm¶ŸÿÃ&jÚèž',r‰¿r‰Ã®&î¶*'ý¯Ûýú'·úk{öèw/á¶i
_________________ Viperdoc |
Viperdoc
Posted: Fri May 08, 2015 9:20 pm Post subject: Motor oil |
Good post Walt. I had forgotten all that. So much info so few brain bits.
Doc
Sent from my iPad
[quote] On May 8, 2015, at 11:07 PM, Walter Lannon <wlannon(at)shaw.ca> wrote:
A quick description of the viscosity identification as some may be confused by the different numbers: --
The original aviation designation for oil viscosity measurement was given in Saybolt Universal Seconds or SUS. That is still in use by Shell, Exxon and others for their traditional oils. E.G. Aeroshell 65, 80, 100 and 120. Multi-grade aviation oils use the SAE (Society of Automotive Engineers) designation system. E.G. Aeroshell 15W50, Phillips X/C 20W50 and 25W60.
Walt
Posted: Sat May 09, 2015 1:12 pm Post subject: Motor oil |
Thanks for the correction Walt!
You are, without a doubt, a real wealth of knowledge! No joke.
Mark
From: owner-yak-list-server(at)matronics.com [owner-yak-list-server(at)matronics.com] on behalf of Roger Kemp [f16viperdoc(at)me.com]
Sent: Saturday, May 09, 2015 1:19 AM
Doc
Sent from my iPad
Walt
Posted: Mon May 11, 2015 9:11 am Post subject: Motor oil |
Thanks Mark;
Mostly aviation trivia from me. When I need electrical advise I look to
you.
Cheers;
Walt
Posted: Tue May 12, 2015 8:35 am Post subject: Motor oil |
OK, you've convinced me to switch. However, I still need opinions. I have a case of Aeroshell W100 leftover... What are your thoughts on occasionally mixing a quart in with the Phillips 25w60? JB
Dennis
Posted: Tue May 12, 2015 8:53 am Post subject: Motor oil |
Won't hurt a thing.
Let's say you had recently changed the oil and switched to the Philips 25W-60 and you were at an airshow or fly-in that did not have anything other than Aeroshell 100 and you needed a quart or two of oil. Would you add 1 or 2 qts of the Aeroshell 100 or go without it?
I think you'd add it. I certainly would.
Dennis
Sent: Tuesday, May 12, 2015 11:31 AM
"A. Dennis Savarese" <dsavarese0812(at)bellsouth.net> wrote:Philips 25W-60 which is for radial engines.
Dennis
From: Jon Blake <jblake207(at)comcast.net> To: yak-list(at)matronics.com Sent: Friday, May 8, 2015 4:50 PM Subject: Motor oil
"http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
"http://forums.matronics.com/">http://forums.matronics.com
"http://www.matronics.com/contribution">http://www.matronics.com/contribution
cjpilot710(at)aol.com Guest
Posted: Tue May 12, 2015 10:43 am Post subject: Motor oil |
Me personally I do not like to 25w60 and only use 100 or 120. I have found that using 25w60 in my engine I get oil leaks. I know that sounds sort of silly but I do. Having said that I operate mostly (99%) of the time in a Florida climatic condition. In the winter months I use 100. Just recently the foundation I fly the B24 for has gone from multi grade to straight 100w. When you are talking gallons the $$$$ mount.
Mixing. You can mix grades in a pinch. I have put 25w60 in my tank when the FBO didn't have any 100 or 120. Just don't make it a habit. The real No/No is if you are using a mineral oil for normal operations and mix in a detergent oil SEA 100 or 120. IF you are using a detergent oil for normal operations you can mix in a quart or two of a mineral oil if that is all a FBO has to keep you going. Do not however make a habit of it.
Change your oil often. With a 10 micro filter, I change mine between 40 and 50 hours. That may seem long to some, but I find the oil surprising clean even at those times. A pre-oiler is the best investment.
I am not an expert on engine lubrication, and merely go on experience and advice from old timers, so I do respect differences of opinions here. I also note that "hap" is some times the epitome of success.
Jim "Pappy" Goolsby
Posted: Tue May 12, 2015 11:23 am Post subject: Motor oil |
Yep... In fact, done it before. Thanks Dennis.
Won't hurt a thing.
Dennis
Subject: Re: Yak-List: Motor oil
Dennis
From: Jon Blake <jblake207(at)comcast.net> To: yak-list(at)matronics.com Sent: Friday, May 8, 2015 4:50 PM Subject: Yak-List: Motor oil
Ernie
Posted: Tue May 12, 2015 4:34 pm Post subject: Motor oil |
Jon,
Before you switch, keep in mind we live in the tropics and operate our birds mostly in very hot weather. I ran the Phillips in my previous CJ And now run Aeroshell in the new one. I've found that I have much less oil accumulation in my lower cylinders with the Aeroshell.
Obviously this is purely anecdotal, since there are many other factors at play, but you have to ask yourself, do you need the multi weight capabilities based on the average temps you fly in? The same capabilities that allow the oil to flow in freezing temps, allow it to flow past your rings in a 90 degree hangar.
Just a thought.
Ernie
On Tuesday, May 12, 2015, Jon Blake <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
[quote]Yep... In fact, done it before. Thanks Dennis.
"A. Dennis Savarese" <[url=javascript:_e(%7B%7D,'cvml','dsavarese0812(at)bellsouth.net');]dsavarese0812(at)bellsouth.net[/url]> wrote:
Won't hurt a thing.
Dennis
From: Jon Blake <[url=javascript:_e(%7B%7D,'cvml','jblake207(at)comcast.net');]jblake207(at)comcast.net[/url]>
To: [url=javascript:_e(%7B%7D,'cvml','yak-list(at)matronics.com');]yak-list(at)matronics.com[/url]
"A. Dennis Savarese" <[url=javascript:_e(%7B%7D,'cvml','dsavarese0812(at)bellsouth.net');]dsavarese0812(at)bellsouth.net[/url]> wrote:Philips 25W-60 which is for radial engines.
Dennis
From: Jon Blake <[url=javascript:_e(%7B%7D,'cvml','jblake207(at)comcast.net');]jblake207(at)comcast.net[/url]> To: [url=javascript:_e(%7B%7D,'cvml','yak-list(at)matronics.com');]yak-list(at)matronics.com[/url] Sent: Friday, May 8, 2015 4:50 PM Subject: Motor oil
Viperdoc
Posted: Tue May 12, 2015 6:22 pm Post subject: Motor oil |
Ernie,
As a side note, if my 52 is going to sit for awhile I drain the supple into a catch tank. I leave the sump poem with a she from it to a 5 gal. Gas can. The 50's engine is still pickled.
Doc
Sent from my iPad
On May 12, 2015, at 7:33 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
[quote]Jon,
Just a thought.
Ernie
| Quote: | Yep... In fact, done it before. Thanks Dennis.
"A. Dennis Savarese" <[url=javascript:_e(%7B%7D,\'cvml\',\'dsavarese0812(at)bellsouth.net\');]dsavarese0812(at)bellsouth.net[/url]> wrote:
Won't hurt a thing.
Dennis
From: Jon Blake <[url=javascript:_e(%7B%7D,\'cvml\',\'jblake207(at)comcast.net\');]jblake207(at)comcast.net[/url]>
To: [url=javascript:_e(%7B%7D,\'cvml\',\'yak-list(at)matronics.com\');]yak-list(at)matronics.com[/url]
"A. Dennis Savarese" <[url=javascript:_e(%7B%7D,\'cvml\',\'dsavarese0812(at)bellsouth.net\');]dsavarese0812(at)bellsouth.net[/url]> wrote:Philips 25W-60 which is for radial engines.
Dennis
From: Jon Blake <[url=javascript:_e(%7B%7D,\'cvml\',\'jblake207(at)comcast.net\');]jblake207(at)comcast.net[/url]> To: [url=javascript:_e(%7B%7D,\'cvml\',\'yak-list(at)matronics.com\');]yak-list(at)matronics.com[/url] Sent: Friday, May 8, 2015 4:50 PM Subject: Motor oil
ist"">http://www.matronics.com/Navigator?Yak-List
Ernie
Posted: Tue May 12, 2015 6:26 pm Post subject: Motor oil |
Yea sometimes I flipped she her on it peddle, to jiggle the cripple too.Â
On Tuesday, May 12, 2015, Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)> wrote:
[quote]Ernie,
Doc
Sent from my iPad
On May 12, 2015, at 7:33 PM, Ernest Martinez <[url=javascript:_e(%7B%7D,'cvml','erniel29(at)gmail.com');]erniel29(at)gmail.com[/url]> wrote:
| Quote: | Jon,
Just a thought.
Ernie
On Tuesday, May 12, 2015, Jon Blake <[url=javascript:_e(%7B%7D,'cvml','jblake207(at)comcast.net');]jblake207(at)comcast.net[/url]> wrote:
Won't hurt a thing.
Dennis
Dennis
et="_blank">http://www.matronics.com/Navigator?Yak-List
Ernie
Posted: Tue May 12, 2015 6:31 pm Post subject: Motor oil |
I love auto correct, this is funnier than what I intended.
On Tuesday, May 12, 2015, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
[quote]Yea sometimes I flipped she her on it peddle, to jiggle the cripple too.Â
On Tuesday, May 12, 2015, Roger Kemp <[url=javascript:_e(%7B%7D,'cvml','f16viperdoc(at)me.com');]f16viperdoc(at)me.com[/url]> wrote:
| Quote: | Ernie,
Doc
Sent from my iPad
On May 12, 2015, at 7:33 PM, Ernest Martinez <erniel29(at)gmail.com> wrote:
| Quote: | Jon,
Just a thought.
Ernie
Won't hurt a thing.
Dennis
Dennis
| [b]
Viperdoc
Posted: Tue May 12, 2015 6:39 pm Post subject: Motor oil |
ROFLMAO! No idea where Apple was coming from on that one! Even with a proof read it snuck in on the transmit!
Sump open flowing into a tube to a 5 gal. Gas can!😫
Doc
Sent from my iPad
On May 12, 2015, at 9:26 PM, Ernest Martinez <erniel29(at)gmail.com (erniel29(at)gmail.com)> wrote:
| Quote: | Ernie,
Doc
Sent from my iPad
On May 12, 2015, at 7:33 PM, Ernest Martinez <[url=javascript:_e(%7B%7D,\'cvml\',\'erniel29(at)gmail.com\');]erniel29(at)gmail.com[/url]> wrote:
| Quote: | Jon,
Just a thought.
Ernie
On Tuesday, May 12, 2015, Jon Blake <[url=javascript:_e(%7B%7D,\'cvml\',\'jblake207(at)comcast.net\');]jblake207(at)comcast.net[/url]> wrote:
Won't hurt a thing.
Dennis
Dennis
