Sharky
Posted: Wed Apr 29, 2015 9:10 pm Post subject: OIL PRESSURE GAUGE FAULTY READING |
On an AI-14RA engine, oil pressure gauge showing intermittent reading. Showing correct reading and then no reading at all. Now and then shows correct reading again or nothing.
Have connected another gauge to test and same problem, have tested wire connection between gauge and transmitter/sender unit, also good. Could plugs be faulty or sender unit.
What other test should I do.
Sounds to me like a bad connection but where?
Can you assist?
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
Posted: Thu Apr 30, 2015 3:33 am Post subject: OIL PRESSURE GAUGE FAULTY READING |
I would suspect a faulty oil pressure sender.
Dennis
To: m14pengines-list(at)matronics.com
Sent: Thursday, April 30, 2015 12:10 AM
Subject: OIL PRESSURE GAUGE FAULTY READING
--> M14PEngines-List message posted by: "Sharky" <mavella(at)netactive.co.za (mavella(at)netactive.co.za)>
On an AI-14RA engine, oil pressure gauge showing intermittent reading. Showing correct and then no reading. Now and then shows correct reading again.
Have connected another gauge and same problem, have tested wire connection between gauge and transmitter/sender unit, also good. Could plugs be faulty or sender unit.
Can you assist?
http://forums.matronics.com/="http://www.matronics.com/Navigator?M14PEngines-List" target="_blank">orums.matronics.com/" target="_blank">http://forums.matronics.com
; -Matt Dralcontribution" target="_blank">http://www.matronics.com/contribution
Sharky
Posted: Fri May 01, 2015 12:08 am Post subject: Re: OIL PRESSURE GAUGE FAULTY READING |
Thanks Denis,
I was hoping to be something else, like the actual plugs but they look pretty solid to me.
Do you know where I can get a spare oil pressure sending unit?
Posted: Fri May 01, 2015 3:15 am Post subject: OIL PRESSURE GAUGE FAULTY READING |
Try Jill at M14P or Doug Sapp.
Dennis
Sent: Friday, May 1, 2015 3:08 AM
Subject: Re: OIL PRESSURE GAUGE FAULTY READING
Thanks Denis,
http://forums.matronics. href="http://www.matronics.com/Navigator?M14PEngines-List" target="_bl//forums.matronics.com/" target="_blank">http://forums.matronics.comh=
Posted: Fri May 01, 2015 12:16 pm Post subject: OIL PRESSURE GAUGE FAULTY READING |
Also George Coy. If he has them, his prices are very reasonable.
Sharky
Posted: Mon May 04, 2015 1:00 pm Post subject: Re: OIL PRESSURE GAUGE FAULTY READING |
Sorted. It was a faulty sender unit.
Thanks to all.
