Alternator field circuit breaker
phudes(at)ix.netcom.com
PostPosted: Sat Apr 11, 2015 11:54 am    Post subject: Alternator field circuit breaker Reply with quote
I am replacing the Nippon/Denso alternator in my RV9 with one from Plane Power. I did not build the RV.
The field CB is rated at 10 amps. Plane Power calls for a 5 amp one. Any issue with using the existing 10 amp CB?
Pete Hudes
fvalarm(at)rapidnet.net
PostPosted: Sat Apr 11, 2015 12:09 pm    Post subject: Alternator field circuit breaker Reply with quote
Does the alternator have an internal regulator? Does it include a crowbar
over voltage circuit? What size wire is running from the circuit breaker to
the alternator? I would think you will want to follow the install guide
closely.
Bevan
PostPosted: Sat Apr 11, 2015 12:23 pm    Post subject: Alternator field circuit breaker Reply with quote
Yes to both.
Pete
closely.
Bevan
kjashton(at)vnet.net
PostPosted: Sat Apr 11, 2015 1:31 pm    Post subject: Alternator field circuit breaker Reply with quote
Plane power depends on popping the 5A CB to provide the overvoltage protection. I would think using a larger CB will require more amps which might overheat your field wiring before popping a 10A breaker. Just a guess.
http://plane-power.com/pdf/internally%20regulated%20experimental%20alternator%20information.pdf
-kent
[quote] On Apr 11, 2015, at 4:22 PM, Pete <phudes(at)ix.netcom.com> wrote:
Yes to both.
Pete
> closely.
> Bevan
user9253
PostPosted: Sat Apr 11, 2015 3:52 pm    Post subject: Re: Alternator field circuit breaker Reply with quote
The crowbar over-voltage circuit could be damaged by excessive current allowed by a 10 amp breaker. Use a 5 amp breaker.
Joe
Joe Gores
rene(at)felker.com
PostPosted: Sun Apr 12, 2015 12:30 pm    Post subject: Alternator field circuit breaker Reply with quote
My chief engineer always reminds me that the CB is protect the wire not the
item the wire leads to. If Plan Power says 5 amps, then I would change to 5
amps and double check the wire to make sure it is adequate to handle 5 amps.
Rene'
801-721-6080
PostPosted: Sun Apr 12, 2015 10:16 pm    Post subject: Alternator field circuit breaker Reply with quote
Thanks everyone. 5 amp CB ordered.
Pete Hudes
Rene'
801-721-6080
PostPosted: Mon Apr 13, 2015 5:24 am    Post subject: Alternator field circuit breaker Reply with quote
At 15:21 2015-04-12, you wrote:
--> AeroElectric-List message posted by: "Rene" <rene(at)felker.com>
If you're replacing a 10A breaker, then it's
a pretty sure bet that the downstream wires are
good for 5A too. But this is a special case
where the breaker is indeed sized to integrate
gracefully with a downstream item . . . the
crowbar module.
Further, not just ANY 5a breaker. During the
operation of a crowbar ov protection device,
fault currents may be as high as 200A . . .
for a few tens of milliseconds.
The ENERGY dumped in this even is low but
the current can be substantial.
While the legacy, pullable mil-style breaker
[img]cid:7.1.0.9.0.20150412195958.0038fac8(at)aeroelectric.com.0[/img]
. . . will grunt the ov trip thousands of times without
breathing hard, some 5A breakers won't make it to first
base . . .
[img]cid:7.1.0.9.0.20150412195958.0038fac8(at)aeroelectric.com.1[/img]
This little feller burned in two on the first trip . . .
 Filesize:  266.83 KB
 Viewed:  16491 Time(s)
 Filesize:  188.11 KB
PostPosted: Mon Apr 13, 2015 5:29 am    Post subject: Alternator field circuit breaker Reply with quote
Wrote this one yesterday but it failed to post.
As a sub-note to the thread, I'll offer the following:
crowbar module.
[img]cid:7.1.0.9.0.20150413082505.03f18ff0(at)aeroelectric.com.2[/img]
base . . .
[img]cid:7.1.0.9.0.20150413082505.03f18ff0(at)aeroelectric.com.3[/img]
This little feller burned in two on the first ov trip . . .
Future versions of the crowbar ov module will include a
press to test function. It's not something that should
be exercised every pre-flight (although it wouldn't hurt)
but it will negate the need for yearly calibration testing
and will serve to prove adequacy of the installed breaker.
 Filesize:  266.83 KB
 Filesize:  188.11 KB
 Viewed:  16490 Time(s)
kenryan
PostPosted: Mon Apr 13, 2015 6:52 am    Post subject: Alternator field circuit breaker Reply with quote
I already own a couple of 4 amp Klixon push-pulls (like the one in the picture). Will 4 amp work instead of five? Also, when do you anticipate the new OVP to be available for purchase?
On Sun, Apr 12, 2015 at 5:08 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
--> AeroElectric-List message posted by: "Rene" <rene(at)felker.com (rene(at)felker.com)>
   crowbar module.
  base . . .
 Filesize:  188.11 KB
 Viewed:  16486 Time(s)
 Filesize:  266.83 KB
user9253
PostPosted: Mon Apr 13, 2015 7:10 am    Post subject: Re: Alternator field circuit breaker Reply with quote
I bought a new circuit breaker, 693-T11-211-3, and tried it on the bench before installing it. The breaker would not trip in the O.V. circuit. So I connected the breaker directly to a 12 volt battery to test it. Instead of tripping, the breaker literally smoked.
Joe Gores
user9253
PostPosted: Mon Apr 13, 2015 7:22 am    Post subject: Re: Alternator field circuit breaker Reply with quote
Probably, but it depends on the maximum current requirements of the alternator field. Do you know what it is? The field will need more current when recharging an almost dead battery.
Joe Gores
jluckey(at)pacbell.net
PostPosted: Mon Apr 13, 2015 7:38 am    Post subject: Alternator field circuit breaker Reply with quote
Listers,
I've noticed that several postings about Alternator Field circuit breakers have shown "push-to-reset" or "non-pullable" circuit breakers.
I think that "pullable" breakers like the Klixon that BobN referenced or the venerable Potter Brumfield, now Tyco W23 breakers are a better choice because they allow you to shut-down the alternator at will. This can be handy for testing or in the case of a malfunctioning over-voltage module. It is definitely worth the extra $15 for this level of flexibility & safety.
-Jeff
On Monday, April 13, 2015 8:22 AM, user9253 <fransew(at)gmail.com> wrote:
--> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
http://forums.matronics.com/viewtopic.p//www.matronics.com/Navigator?AeroElectric-List" target="_blank">http://w -Matt Dralle, List =========
PostPosted: Mon Apr 13, 2015 7:56 am    Post subject: Alternator field circuit breaker Reply with quote
Yes, the 4A will work for MOST if not all automotive
wound field alternators with CBOVP. With PM alternators,
the circuit breaker carries only control current for
a relay . . . hence . . . the breaker can be smaller
but not necessary. As a general rule, 5A breakers cost
less than the smaller sizes so 5A was selected as the
'universal' candidate for alternator control with
CBOVP.
The design, software are done . . . parts in hand.
I've got a project in the skunkwerks world of TC aircraft
that needs a fast turn around . . . OBAM play projects are
on temporary hold . . . but not long. That's the nice thing about
fast-turn requests. It couldn't drag out if we wanted it
to! Now, if we could just run TCGA certs with the same
sense of urgency . . .
kenryan
PostPosted: Mon Apr 13, 2015 8:26 am    Post subject: Alternator field circuit breaker Reply with quote
Unfortunately I do not know the maximum current requirements for the alternator fields. It is a Rotax with the built in generator and auxiliary 40 amp alternator.
On Mon, Apr 13, 2015 at 7:22 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
[quote]--> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe Gores
http://forums.matronics.com/viewtopic.php?p=440778#440778
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
FORUMS -
b Site -
          -Matt Dralle, List Admin.
user9253
PostPosted: Mon Apr 13, 2015 8:48 am    Post subject: Re: Alternator field circuit breaker Reply with quote
The Rotax internal alternator does not have a field. So yes, a 4 amp circuit breaker will work for the crowbar O.V. wired with a relay per Bob's Z-17.
http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z17K.pdf
And the 40 amp alternator is relatively small, so a 4 amp breaker will be adequate for its field circuit too.
Joe
Joe Gores
kenryan
PostPosted: Mon Apr 13, 2015 9:50 am    Post subject: Alternator field circuit breaker Reply with quote
Thanks guys.
On Mon, Apr 13, 2015 at 8:48 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=440788#440788
FORUMS -
b Site -
PostPosted: Mon Apr 13, 2015 12:03 pm    Post subject: Alternator field circuit breaker Reply with quote
At 12:49 2015-04-13, you wrote:
Thanks guys.
An interesting data point . . . the current draw of
the field in an engine driven power source is NOT
tightly associated with the machine's output rating.
The field intensity needed to produce full output
is a function of amps times turns in the field winding.
As it turns out, you can get ANY intensity at ANY
current if you have no restraints on volume allotted
to the field winding.
I've built regulators for 600A starter generators
that draw no more current than the 100A alternator.
Generally speaking, 10A is a BIG field current draw
for any machine . . . and a 60A machine on the
front of a Lycoming can produce 20A of output at
1 amp or so of field current.
This is why the regulators found in the full family
of aviation products are all about the same size.
Bob . . . [quote][b]
