Posted: Tue Mar 03, 2015 5:09 am Post subject: Infinity grip switch driving S702 starter relay |
Anyone else using an Infinity grip switch to actuate a S702 starter relay?
According to the specs of the Infinity grip switches, the contacts are rated at 6Amp.
| Quote: | From the B and C site, the S702 has a 2.5Ohm coil - so the math at 14volts works out
to 5.6Amps...and that would be a max since the battery would provide less at cranking
time.
The numbers say it should be OK - I'm looking to find out if anyone is doing it for
real - and how is it working for you?
Ralph Capen
rnewman(at)tcwtech.com Guest
Posted: Tue Mar 03, 2015 5:32 am Post subject: Infinity grip switch driving S702 starter relay |
Ralph. I would recommend you look at our Smartstart module for doing this function if you want to use the stick grip switch to drive the start contactor. The switches used in the stick grip may be rated at 6 amps, but that would be for a resistive load. The start contactor is an inductive load and has a significantly different effect in switches than a pure resistor.
Additionally, our module has a built in one minute timer and an interlock feature, making the stick grip starting concept safer and more useful.
All the info is at www.tcwtech.com
Bob Newman
TCW Technologies, LLC
610-928-3420
| Quote: | On Mar 3, 2015, at 8:07 AM, Ralph E. Capen <recapen(at)earthlink.net> wrote:
time.
Ralph Capen
Posted: Tue Mar 03, 2015 5:50 am Post subject: Infinity grip switch driving S702 starter relay |
Interesting - I'll look in to this....
How many are out there interfacing the Infinity grip switch to the Starter relay?
Still want to hear if anyone is using my stated configuration though....
flying-nut(at)cfl.rr.com Guest
Posted: Tue Mar 03, 2015 6:21 am Post subject: Infinity grip switch driving S702 starter relay |
Ralph, you may find some folks that are using the infinity switch direct
for the starter contactor but our fleet is relatively young. Problems
won't surface 'till down the road a ways. My start switch is is on the
key so I didn't have your same situation. However, it's far better to
wire in a relay now than later, IMHO.
My question is why put the starter on the grip anyway? You only use it
once each flight and typically don't need to have your hand on the grip
at that time. Plus, what keeps you from accidentally hitting that
switch while you're in the air???
Linn
recapen(at)EARTHLINK.NET Guest
Posted: Tue Mar 03, 2015 6:40 am Post subject: Infinity grip switch driving S702 starter relay |
Linn,
Good points made!
I currently have it on a relay that the hand-grip activates with a safety interlock
switch - my line of thinking is to simplify by removing the relay and driving it direct.
My initial line of thinking for putting it on the hand-grip was for an in-flight restart -
which would require one hand on the stick while the other works throttle and mixture.
What I currently have works very well - but it is complex and I am trying to simplify...
Looking for evidence of the problem you alluded to.
Ralph
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue Mar 03, 2015 6:53 am Post subject: Re: Infinity grip switch driving S702 starter relay |
I agree with Linn and others concerning the need for a relay. I wish I had used one of my Infinity Grip buttons for starting. I do want to hold the stick when starting, and I find that for activating my start button, manipulating mixture and throttle, and holding the stick, I am short one hand. (especially starting when the engine is hot) In my case, the VP-200 would take care of the issue of activating the starter when you don't want it activated. Otherwise, I would use Bob's TcwTech start protection switch.
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Tue Mar 03, 2015 6:55 am Post subject: Infinity grip switch driving S702 starter relay |
Ralph,
On the RV-8A the first version had the bottom push button on the stick being
the start button, providing power to the starter solenoid. This button does
not have the capacity to operate the starter solenoid directly. I installed
a small 12VDC relay (100ma coil, ~$1.50 from Allied Electronics) in the
circuit such that the stick button operated the relay, the relay then
provided power to the starter solenoid.
But - this setup was quickly changed as twice during the first flights I
inadvertently bumped the stick start button while the engine was running. I
kept the relay set up and just added a small momentary pushbutton out of the
way at the top of the right side switch/breaker panel to use instead of the
stick button.
On the RV-10 I just used the standard 10amp panel pushbutton for engine
start to directly provide power to the starter solenoid.
Bottom line - recommend not using the stick buttons to operate the starter
solenoid.
Carl
Posted: Tue Mar 03, 2015 7:16 am Post subject: Infinity grip switch driving S702 starter relay |
Carl,
Thanks for your input.
I have a secondary safety switch to prevent the accidental activation along
with the relay like you described currently installed.
My intent was to simplify by removing the relay. Sounds like my best bet
is to leave it as is! It works great for me.....
Ralph
Posted: Tue Mar 03, 2015 7:17 am Post subject: Infinity grip switch driving S702 starter relay |
David,
Thanks for the info. I'll probably leave mine as is since the relay and safety switch work well!
Ralph
Posted: Tue Mar 03, 2015 9:52 am Post subject: Infinity grip switch driving S702 starter relay |
Ah, it seems the answer is ...... "If it ain't broke, don't fix it!!!"
Linn ..... couldn't resist
On 3/3/2015 10:16 AM, Ralph E. Capen wrote:
David,
Ralph
Tim Olson
Posted: Tue Mar 03, 2015 11:16 am Post subject: Infinity grip switch driving S702 starter relay |
This post since it was cross posted, may not have gotten
the same follow-up on all lists, but I'll add my reply
to another poster's comment on prop windmilling being
enough in-flight...
I know in my case I've done complete mixture cut-off tests
in the plane where I've stopped the engine completely,
and also flown it dry on tanks for testing, and the prop
keeps spinning so fast that you may even perceive that
the engine is still making power. You just feel the loss
of thrust. So unless you happen to pull the nose up and
near-stall the plane, I doubt the starter will ever need to
be cranked to re-start. For me, as soon as the fuel
supply was there again, it roared back to life.
Also, the start operation isn't *that* complicated.
I understand the want to have a hand on the stick
and one on the throttle/mixture, but my knees do a fine
job of holding the stick for a normal start.
Additionally, if the plane is in trim, I don't see
the worry about holding the stick with a hand
while doing that once-in-a-hundred-years in-flight
restart that you may do. The knees would do ok
there too, but in actuality, you're not going to be
manipulating the mixture and throttle much if you're
doing an in-flight start. It's not like you'll be
doing a hot-start procedure at 7,000'.
Posted: Tue Mar 03, 2015 11:34 am Post subject: Infinity grip switch driving S702 starter relay |
Agreed!
vanremog(at)aol.com Guest
Posted: Tue Mar 03, 2015 7:03 pm Post subject: Infinity grip switch driving S702 starter relay |
It may also be an AC rating. DC is significantly harder on contacts during switching. The combination of DC switching and collapsing flux field from a large inductive would be death fro the switch. In DC applications always ensure that you have a back biased catch diode installed across an inductive load or the back EMF can take out the switching component in short order.
-GV
