dbrown2(at)nycap.rr.com Guest
Posted: Sun Jan 25, 2015 7:59 am Post subject: Dual Alternator, Dual Battery, Single Bus |
Hello Bob,
My project will have a dual electronic ignition and an all-electric panel. I intend to have the two battery and individual battery buses per your Figure Z-30. I will have a single power bus that is supplied by a 60 amp main alternator (Plane Power AL12-C60) with a 30 amp backup alternator (Plane Power FS1-14). The B-leads from both alternators are connected through a Maxi fuse block to the hot side of the starter contactor which then goes through the firewall to the bus.
I have some questions:
<![if !supportLists]>1) <![endif]>The 6 AGW B-leads from the alternators can easily carry 80 amps. Can I protect the both leads with 80 amp Maxi fuses? I believe I might have read that this is okay in the List FAQs.
<![if !supportLists]>2) <![endif]>According to Hartzell Engine Technologies (new owners of Plane Power alternators) the main alternator puts out 14.2 v and the backup puts out 13.6 v so if the main drops below 13.6 v the backup takes over. Their wiring diagram does not show a diode in the circuit to stop the flow of electricity from the bus to the B-terminal of the backup alternator. I thought that this may affect the backup alternators life but the technician at HET said not to worry about it. If I was really concerned I could turn the field off on the backup under normal operation and turn it on in the event of a low voltage indication. I prefer the automatic takeover of the backup so my question is this, do I need to have a diode in the circuit to block the reverse flow to the backup alternator or is the 0.6 v potential no big deal? If it is prudent to add the diode what type of diode do you recommend?
<![if !supportLists]>3) <![endif]>I also think I remember reading in the List FAQs (but can’t seem to find it) that in the event of the battery contactor opening and disconnecting the battery from the bus, a load on the bus could cause precipitous failure of the alternator. It would be nice to have a battery contactor open indicator light. What is the best way to add such a device to your dual battery circuit?
Dan
Posted: Mon Jan 26, 2015 3:24 am Post subject: Dual Alternator, Dual Battery, Single Bus |
Thanks Bob,
| Quote: | As long as you don't have 250w incanescant landing lights
or an electro-hydraulic pump system, transient loads
capable of stalling a self-excited alternator don't
exist. Further, since you're running dual batteries,
you'd have to crap two contactors to set that scenario
up.
I do have an electro-hydraulic pump for the landing gear but I get your point about the two battery contactors. I will make sure I do a contactor check during run-up to ensure that I am not flying around with one of them failed.
| Quote: | What does your power distribution look like. What electro-whizzies
from which which busses?
I am still working on that but basically its electronic ignition, fuel pump, clock and system memories, cabin lighting and 12v outlets split between the two battery buses and everything else on the main bus. The last time I tried to estimate the total load I came up with about 40 amps with everything I plan to equip my plane with on at the same time. If my estimate is correct I could probably run my full suite of goodies with the 30 amp aux alternator. If I find that my system want much more than 30 amps during normal cruise will install a contactor that cuts the power to non-essential equipment and reduces the load to <30 amps.
This brings up another question. I already have a contactor, that I have named avionics contactor, conveniently locate by the power bus. Traditionally I believe its intent was to turn off all the sensitive and expensive avionics during engine startup and such to protect them from power spikes or surges. At least that’s what I was told. I was also more recently told that modern avionics, with their internal protection, do not need such isolation. If that is the case I would like to use my avionics contactor as the non-essential equipment switch cited above. Is it true that the avionics switch is a thing of the past?
Thanks again,
Dan
Posted: Mon Jan 26, 2015 10:19 am Post subject: Re: Dual Alternator, Dual Battery, Single Bus |
| Quote: | | Is it true that the avionics switch is a thing of the past? |
Here is a quote from SkyView Pilot’s User Guide - Revision Q
| Quote: | | SkyView’s robust power protection allows it to be powered on during engine start. |
And here is a quote from the Dynon D-180 user guide:
| Quote: | | It is acceptable to have the FlightDEK-D180 turned on during engine start. |
My RV-12 does have an avionics switch, but only because I had to build the plane exactly per the plans in order to register it as E-LSA. But I never shut it off, even during engine start. The Garmin SL-40 and GTX-327 and GPS496 and Dynon D-180 all still work fine. I probably should exercise the avionics switch occasionally to remove corrosion on the contacts.
An avionics switch is a single point of failure.
Joe
_________________ Joe Gores |
Posted: Mon Jan 26, 2015 10:46 am Post subject: Re: Dual Alternator, Dual Battery, Single Bus |
Here is link to Bob Nuckolls article about the avionics master switch.
http://www.aeroelectric.com/articles/avmaster.pdf
Posted: Mon Jan 26, 2015 1:21 pm Post subject: Dual Alternator, Dual Battery, Single Bus |
Thanks Joe,
That article rings of a familiar tone. Maybe that where "I was also more
need such isolation."
Dan
ARGOLDMAN(at)aol.com Guest
Posted: Tue Jan 27, 2015 1:46 pm Post subject: Dual Alternator, Dual Battery, Single Bus |
Actually,
That information came from a conversation that I had with Dynon's Tec. When I asked him how do I monitor my oil pressure ect on startup he told me about starting the engine on the backup battery.
So if you start the engine with the skyview attached to the system bus and you get the electronic glitch that would reboot your system, by the time it reboots and is able to give you an oil pressure reading you may have toasted your engine. Are they just talking about the starting draw decreasing the voltage to the point of resetting or the transients caused by starting when they talk about the use of auxiliary power on startup. My understanding, possibly wrong is that the dynon battery is automatically connected in the case of low voltage. If low voltage is the case, does the switchover happen quickly enough to prevent the reboot? If a transient situation does the small aux battery have the capability to filter it out?
Additionally the installation/operation instructions for the ICOM A-200 (not really an ancient radio) state,
"Do not turn the power on until after the aircraft engines have been started. This is important for the protection of the circuit."
If you are concerned about single point failure, nothing stops you from having a duplicate avionics switch. I have duplicate fuel pump switches (located in different places).
Rich
In a message dated 1/27/2015 9:50:01 A.M. Central Standard Time, fransew(at)gmail.com writes:
| Quote: | TO MINIMIZE THE CHANCE OF THE SYSTEM RESETTING DURING ENGINE CRANKING, THE OPTIONAL REDUNDANT (DIODE OR'D) POWER INPUTS MAY BE CONNECTED TO AN AUXILIARY BATTERY . . .OR STABILIZED POWER INPUT. . .
The Garmin manual does not recommend using backup power during engine start. It says that OPTIONAL backup power MAY be used.
Both Garmin and Dynon say that having optional backup power will prevent rebooting during engine cranking, which I think is a good idea because rebooting is annoying. But neither company says that not having backup power will damage their units. And neither company recommends disconnecting their units from the aircraft electrical system during engine starting.
The point that I am trying to make is that an avionics master switch to protect avionics is unnecessary. Installing an avionics master switch introduces a single point of failure. If that switch fails, avionics go dark.
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=437697#437697===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
jmjones2000(at)mindspring Guest
Posted: Tue Jan 27, 2015 2:09 pm Post subject: Dual Alternator, Dual Battery, Single Bus |
I would be interested in looking at the circuitry of the standby battery from dynon. Does anyone know if there is a diode that allows current to flow from the standby battery to the dynon but not back into the battery?
Seems that you would either have a need for a replacement standby battery, or you would have a need to recharge the dynon battery somehow (if it were rechargeable) when the standby battery dies.
Justin
On Jan 27, 2015, at 12:44, ARGOLDMAN(at)aol.com (ARGOLDMAN(at)aol.com) wrote:
[quote] Actually,
Rich
In a message dated 1/27/2015 9:50:01 A.M. Central Standard Time, fransew(at)gmail.com (fransew(at)gmail.com) writes:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Joe
Joe Gores
Read this topic online = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Posted: Tue Jan 27, 2015 7:45 pm Post subject: Dual Alternator, Dual Battery, Single Bus |
Dynon--personal contact with the dynon tech rep when I was designing the electrical of my craft.
Icom from the installation manual
Rich
In a message dated 1/27/2015 5:47:12 A.M. Central Standard Time, fransew(at)gmail.com writes:
| Quote: | The below not withstanding, Dynon recommends starting and stopping the engine with the /Skyview not connected to the ships buss. They recommend starting the engine on the skyview backup battery so that you can see the engine instruments and connecting to the ships power after start. What do they know that we don't?
Rich
Where did you read that? Please post a link to Dynon manual and page.
The Dynon SkyView Pilot’s User Guide - Revision Q page 2-1 says, "SkyView’s robust power protection allows it to be powered on during engine start."
According to Bob's teachings, there are no high voltage spikes during engine starting. The only concern is a brownout. Dynon's SkyView automatically switches to its own backup battery during brownout conditions. No action is required by the pilot as the power transfer is automatic.
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=437690#437690===============================================
Posted: Tue Jan 27, 2015 7:46 pm Post subject: Dual Alternator, Dual Battery, Single Bus |
Puts my mind at ease about the dynon-- now just to think of the icom
Rich
In a message dated 1/27/2015 6:13:28 A.M. Central Standard Time, fransew(at)gmail.com writes:
Below is a quote from SkyView System Installation Guide - Revision R page 2-5.
| Quote: | SkyView Can Be On During Engine Start SkyView units incorporate robust power protection that allows them to be powered on during engine start for full engine monitoring. SkyView displays require a minimum of 10V, and during engine start, it’s common for the electrical system to temporarily drop below 10V. If an SV-BAT- 320 backup battery is not installed, SkyView may shut off / reboot. If you wish to monitor your engine prior to engine start, an SV-BAT-320 backup battery should be installed so that the SkyView display can switch to the SV-BAT-320 when its power inputs are not receiving at least 10V. The SkyView display will switch from SV-BAT-320 to ship’s power when its power inputs receive voltage above 10V.
Joe Gores
http://forums.matronics.com/viewtopic.php?p=437692#437692===============================================
Posted: Tue Jan 27, 2015 8:33 pm Post subject: Re: Dual Alternator, Dual Battery, Single Bus |
Here is a link to the http://tinyurl.com/SkyView-User-Guide
Kellym gives a good explanation in a separate thread.
It is not an electronic glitch that reboots the SkyView, but is low voltage caused by the heavy starter load. Aircraft system voltage during engine cranking can drop down to 8 volts or so. The Dynon needs 10 volts or else it shuts off. The SkyView then reboots when the aircraft system rises above 10 volts. But if the SkyView has a backup battery, it automatically switches to that instead of rebooting. The switch over is instantaneous. The SkyView, like any electrical load, will draw current from the highest voltage source that is available. There are no significant voltage spikes (transients) caused by engine starting that would cause the SkyView to reboot. The Skyview backup battery is isolated from the aircraft electrical system and is recharged by the SkyView.
Joe
