Grounding to the frame...
nickc(at)mtaonline.net
PostPosted: Mon Jan 12, 2015 9:49 am    Post subject: Grounding to the frame... Reply with quote
Hello Kolb Flyers,
Things on the list seem a little slow….. so I soon will need to jump into setting up the electrical system in my Kolbra, and my “hot box” wants to be grounded to the frame. So please share your suggestions with me. I have not put too much effort in to studying aircraft electrical systems yet.
Nick Cassara
Palmer, Alaska
607AK
Rex Rodebush
PostPosted: Mon Jan 12, 2015 5:44 pm    Post subject: Re: Grounding to the frame... Reply with quote
I'm sure grounding to the frame will work fine. Many people do it. I just felt more comfortable with a separate grounding plate for all components.
See attached picture. It's the brass/copper colored plate mounted to the aluminum seat pan.
 Filesize:  1.49 MB
 Viewed:  4093 Time(s)
rickofudall
PostPosted: Tue Jan 13, 2015 4:59 pm    Post subject: Grounding to the frame... Reply with quote
Nick, I've wired up two Kolbs using Aeroelectric Connection architecture Z-17. On the second one I pulled out a Hot Box because I don't like devices that have wires disappearing into a riveted box and I was trying to save every ounce possible on a massively overweight -3X. Being winter in the land of no sun, you'll really gain from reading Bob Knuckoll's book (best $20 you'll ever spend) and joining his forum here on Matronics.
http://aeroelectric.com/
Rick Girard
On Mon, Jan 12, 2015 at 11:49 AM, Nick Cassara <nickc(at)mtaonline.net (nickc(at)mtaonline.net)> wrote:
Hello Kolb Flyers,
Nick Cassara
Palmer, Alaska
607AK
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
tp://forums.matronics.com
Believe those who are seeking the truth, doubt those who find it.
-Andre Gide
