Noise Cancelling headphones
rv7a.builder(at)yahoo.com
PostPosted: Thu Nov 27, 2014 8:38 am    Post subject: Noise Cancelling headphones Reply with quote
On Thursday, November 27, 2014 8:19 AM, rv7a.builder <rv7a.builder(at)yahoo.com> wrote:
Hi Bob,
I just got myself some Lightspeed Sierra ANR and plugged them into my RV-7A this morning. Prior to this I just had a couple of sets of regular headphones. The headphones worked without the noise canceling turned on (push button, 2AA batteries). When I push the button the noise level got reduced and it sounded real good. When I key the transmitter there is a loud squeal. With the nose cancelling off, there is no squeal when I keyed the transmitter. I think this only happened when the engine was running. I think I checked the transmitter and headphones before I started the engine this morning? I have my jacks wired through a Flightcom 403mc and my radio is a GNC300XL. I had to fly this morning with the noise cancelling off but I should wanted it on! Any thoughts would be appreciated. John Robinson. RV-7A Phase 1.
danb
PostPosted: Mon Jan 12, 2015 1:05 am    Post subject: Re: Noise Cancelling headphones Reply with quote
John,
I recently bought a set of Bose headsets and had a similar thing happen. Oddly enough, I was able to hit the PTT and talk to ground fine, however, when i went to tower and hit the PTT I got a loud squeal. Strange how a different frequency on the radio induces the noise. Anyone have a thought? use a filter?
Kellym
PostPosted: Mon Jan 12, 2015 6:16 am    Post subject: Noise Cancelling headphones Reply with quote
I had that problem with a previous plane, where radio mostly worked fine
with lower frequencies, but would squeal with frequencies above say
125.0. Once I put my radio in another aircraft that didn't have
problems, it was obvious the problem existed in my airplane outside of
the radio. Turned out to be the antenna cable, which was made in the
days before crimped connectors were common. On the radio end of the
cable there was a cold solder joint on the shield, allowing RF to
feedback into the radio. I was given all kinds of theories in trouble
shooting, of problems in the radio, problems with the brand headset not
having shielded wires, etc. etc.
New cable completely eliminated the problem.
So I suggest trying a different PTT, try your radio in a different
airframe that has same model radio, see if the problem follows the
components or not.
On 1/12/2015 2:05 AM, danb wrote:
John,
http://forums.matronics.com/viewtopic.php?p=436876#436876
Kelly McMullen
KCHD
voltar(at)vx-aviation.com
PostPosted: Mon Jan 12, 2015 7:33 am    Post subject: Noise Cancelling headphones Reply with quote
Try also taking your headset cord and wrap three turns of it around your hand and secure it with a pair of tie wraps. You've just made an RF choke that may eliminate conduct RF energy into the headset.
Vern
======Vernon R. Little | Chairman, Iris Dynamics Ltd. | President, Vx Aviation
On Jan 12, 2015, at 6:15 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
[quote]--> AeroElectric-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
I had that problem with a previous plane, where radio mostly worked fine with lower frequencies, but would squeal with frequencies above say 125.0. Once I put my radio in another aircraft that didn't have problems, it was obvious the problem existed in my airplane outside of the radio. Turned out to be the antenna cable, which was made in the days before crimped connectors were common. On the radio end of the cable there was a cold solder joint on the shield, allowing RF to feedback into the radio. I was given all kinds of theories in trouble shooting, of problems in the radio, problems with the brand headset not having shielded wires, etc. etc.
So I suggest trying a different PTT, try your radio in a different airframe that has same model radio, see if the problem follows the components or not.
--> AeroElectric-List message posted by: "danb" <danb_89(at)yahoo.com (danb_89(at)yahoo.com)>
John,
www.buildersbooks.com[/url]nbsp; * My Pilot Store wwonsulting www.mrrace.com
========================== &nb --> http://forums.ma=====================================================
danb
PostPosted: Mon Jan 12, 2015 7:55 am    Post subject: Noise Cancelling headphones Reply with quote
Thanks Kelly, that's good information and gives me something to look at.
Dan
Sent: Monday, January 12, 2015 7:15 AM
Subject: Re: Re: Noise Cancelling headphones
components or not.
John,
http://ww===========
PostPosted: Mon Jan 12, 2015 8:21 am    Post subject: Noise Cancelling headphones Reply with quote
My headsets are plugged into the bulkhead right behind the baggage area in my RV-7A. The thought was to keep the cords out of the way. When I bought the nose canceling headsets it became difficult to reach the headset controller(volume, Bluetooth, on/off) so I bought a 5ft extension from Aircraft Spruce and I no longer have any squealing? Go Figure? This 5ft extension also allows me to easily unplug my headset if I have to use my handheld as a backup. Previously I would have to yank the cord from the back bulkhead which I am sure is not a good idea. Thank you guys for all of your input. John
On Monday, January 12, 2015 7:32 AM, Vern Little <voltar(at)vx-aviation.com> wrote:
Vern
John,
www.aeroelectric.cre www.buildersbooks.comnbsp; * My Pilot Store wwonsulting www.mrrace.com
http://www.matronics.com/contribution http://www.matronics.com/Navigator?AeroElectric-List
courier new,courier" size="2">www.aeroelectric.com
/" target="_blank" rel="nofollow">www.buildersbooks.com
="_blank" rel="nofollow">www.homebuilthelp.com
="_blank" rel="nofollow">www.mypilotstore.com
lank" rel="nofollow">www.mrrace.com
_blank" rel="nofollow">http://www.matronics.com/contribution
ist" target="_blank" rel="nofollow">http://www.matronics.com/Navigator?AeroElectric-List
el="nofollow">http://forums.matronics.com
