gliderx5
Posted: Tue Dec 30, 2014 12:17 pm Post subject: Latex Paint Rolling Video |
Jack
Great info. I have tried Floetrol but I was not able to get the results that others have.
I have a couple questions on the DTM. When you used the clear DTM over painted surfaces did you need to do any surface prep? How did you apply it? How did it hold up to weather?
Malcolm Morrison
www.wienerdogaero.com
To: "kolb-list" <kolb-list(at)matronics.com>
Sent: Tuesday, December 30, 2014 12:32:07 PM
Subject: Re: Kolb-List: Latex Paint Rolling Video
On 12/30/2014 9:17 AM, mojavjoe(at)comcast.net (mojavjoe(at)comcast.net) wrote:
| Quote: | I'm going to spray my side by side with latex and have been looking for a clear coat product that wound be compatible with latex. Thought of varnishes, too hard, some of the stuff used by crafters (don't know if they will stand up to rain and sunlight), Valspar used to make a clear latex but I can't find it listed any longer. Skybiker used a clear coat in 04 and said that it still looked good. Malcolm do you know what he used, or do you or anyone on the list know of a good clear coat. - The Kolb-List Email Forum - FAQ, href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List - MATRONICS WEB FORUMS - href="http://forums.matronics.com">http://forums.matronics.com
| Kolbers, before I retired I worked as a commercial painter and vinyl hanger for a commercial contractor. There were times we needed a very smooth finish on walls or trim with latex paint and we added a product that is called Floetrol made by the Flood Company in Ohio, it would allow the paint to flow out smooth as it dried. Also as to getting a clear coat check with Sherwin Williams and check on a product called DTM Acrylic and ask for their UTRA DEEP BASE. It is a CLEAR BASE that is used to mix very deep colors. You can buy it in semi-gloss and also gloss. Just get it without any color added. Will not yellow over time as oil base varnishes do. I've never checked but you could also check to see if their house paints have a clear base for deep colors.
Jack Carillon 1994 FSII Akron OH.
_blank">www.aeroelectric.com
" target="_blank">www.buildersbooks.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
Herbgh(at)nctc.com Guest
Posted: Tue Dec 30, 2014 1:32 pm Post subject: Latex Paint Rolling Video |
Right
Not a simple solution as is Latex...Just mention it as an option...Herb
On 12/30/2014 02:08 PM, gliderx5(at)comcast.net (gliderx5(at)comcast.net) wrote:
[quote] Herb
It appears that Ultra 7000 is a solvent based paint, is quite expensive, and I doubt you would want to apply it with a roller. I'm sure that it would give you a superior gloss, but the reasons for using latex are cost ($50/gallon) and non-toxocity (can paint in your basement).
Malcolm Morrison
From: "Herb" <Herbgh(at)nctc.com> (Herbgh(at)nctc.com)
To: "kolb-list" <kolb-list(at)matronics.com> (kolb-list(at)matronics.com)
Sent: Tuesday, December 30, 2014 10:48:25 AM
Subject: Re: Latex Paint Rolling Video
My Mini Max was finished with Sherwin Williams Ultra 7000 ..base /clear and it was as good as any paint job I have ever seen...better than most .. Very glossy and deep looking... Sadly the plane is sitting in an open hanger in the Carolina's now with an inch of dirt on it..!!
I notice that gallons of various base colors are available on Ebay for 250 a gallon...So, If one is not too particular about the color...it might be that the products could be bought for 500 to 700 dollars to finish a Kolb?
Looking at Sherwin William's site...I did no see anything about plasticizers...but I was told by the builder of my Max that he used them... Herb
On 12/30/2014 09:15 AM, gliderx5(at)comcast.net (gliderx5(at)comcast.net) wrote:
| Quote: | mojavejoe,
I know a few builders have used, or are currently experimenting with clear coats, but I don't know which products. Maybe someone else on the list knows. It would sure make is easier to get a glossy finish if it works. For my dusty workshop however I think I would still have to sand and polish to get the glassy, smooth finish that I'm getting now.
Anyone else know about latex clear coats?
Malcolm Morrison
www.wienerdogareo.com
From: mojavjoe(at)comcast.net (mojavjoe(at)comcast.net)
Sent: Tuesday, December 30, 2014 9:17:07 AM
From: gliderx5(at)comcast.net (gliderx5(at)comcast.net)
Sent: Wednesday, December 24, 2014 8:09:07 AM
Subject: Latex Paint Rolling Video
I just finished a new video on applying latex paint with a roller. After the sanding and polishing process the results are nearly as good as spraying. Both methods, spraying and rolling have their advantages.
Spraying gives the best finish, it’s faster for big areas, and requires less sanding to smooth the orange peel. But, you need spray equipment and a paint booth the contain the over spray, and you need to mask parts that you don’t want painted.
Rolling is faster for smaller areas and requires no masking other than along edges, it needs no paint booth or equipment, there’s no over spray. But, it requires more sanding to remove the orange peel and while the result is quite good it’s probably not quite as good as spraying.
Have a look at the video and let me know what you think.
https://www.youtube.com/watch?v=OhlxE3EFcCQ
Merry Christmas
Malcolm Morrison
_blank" data-mce-href="http://www.aeroelectric.com">www.aeroelectric.com
" target="_blank" data-mce-href="http://www.buildersbooks.com">www.buildersbooks.com
="_blank" data-mce-href="http://www.homebuilthelp.com">www.homebuilthelp.com
="_blank" data-mce-href="http://www.mypilotstore.com">www.mypilotstore.com
ank" data-mce-href="http://www.mrrace.com">www.mrrace.com
_blank" data-mce-href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
get="_blank" data-mce-href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
ta-mce-href="http://forums.matronics.com">http://forums.matronics.com
smlplanet(at)msn.com Guest
Posted: Wed Dec 31, 2014 12:24 am Post subject: Latex Paint Rolling Video |
When I painted mine in 04 I had looked at several latex paints and how they held up after long periods of time exposed to the weather. I ended up using Flex Bon which is made in Florida and designed to hold up under sun and heat year around. I used Depont automotive clear coat and applied two coats and have been very happy how well it has held up all these years. I lost the roof off my hanger 4 years ago and even exposed that long it still looks good.
Date: Tue, 30 Dec 2014 15:31:57 -0600
Right
[quote] Herb
Malcolm Morrison
| Quote: | mojavejoe,
Malcolm Morrison
Merry Christmas
Malcolm Morrison
ank">www.mrrace.com
baberdk
Joined: 23 Jan 2014 Posts: 53 Location: East Moline, Il
Posted: Wed Dec 31, 2014 7:30 am Post subject: Latex Paint Rolling Video |
I have thought about Valspar Spar Varnish. According to the label, it should work. Has anyone actually tried this?
Respectfully,
Dennis Baber
baberdk(at)gmail.com (baberdk(at)gmail.com)
Lord keep an arm around my shoulder
And a hand over my mouth
pcarillonsr(at)neo.rr.com Guest
Posted: Wed Dec 31, 2014 1:01 pm Post subject: Latex Paint Rolling Video |
On 12/30/2014 3:14 PM, gliderx5(at)comcast.net (gliderx5(at)comcast.net) wrote:
| Quote: | Jack
Malcolm Morrison
From: "Jack" <pcarillonsr(at)neo.rr.com> (pcarillonsr(at)neo.rr.com)
On 12/30/2014 9:17 AM, mojavjoe(at)comcast.net (mojavjoe(at)comcast.net) wrote: Kolbers, before I retired I worked as a commercial painter and vinyl hanger for a commercial contractor. There were times we needed a very smooth finish on walls or trim with latex paint and we added a product that is called Floetrol made by the Flood Company in Ohio, it would allow the paint to flow out smooth as it dried. Also as to getting a clear coat check with Sherwin Williams and check on a product called DTM Acrylic and ask for their UTRA DEEP BASE. It is a CLEAR BASE that is used to mix very deep colors. You can buy it in semi-gloss and also gloss. Just get it without any color added. Will not yellow over time as oil base varnishes do. I've never checked but you could also check to see if their house paints have a clear base for deep colors.
| Malcolm , My experience with DTM has been mostly on new work, we always lightly sand between coats with about 120 grit sandpaper on walls with a drywall pole sander and on trim with sponge pads and only sand very lightly just to remove any thing from roller cover fuzz to something in the paint. Can be re coated in 2 to 6 hrs depending on temp and humidity. We always strain the paint if any paint has been put back in the can. We even had to strain new cans of latex if when opened if they had a skin on the lid . DTM stands for Direct to Metal. On round metal duct work after cleaning we just put 2 coats of DTM no primer necessary no sanding between coats, ( no one could run their hands on it .) On new and old painted surfaces it needs to be clean and if going over a high gloss a bonding primer should be used first or sanding to dull the surface. DTM will bond to almost any clean surface. We applied most of ours with rollers or brush. We used the clear high gloss base over a faux finish on the exterior of a restaurant (made smooth sandstone match granite on the front of an old bank that was converted into a high end restaurant), That was at least 10 years ago an it has held up good to the weather except right where the sandstone meets the sidewalk, snow shovels and power sidewalk sweeper damage. I went and checked just before writing this.
This material will start to set faster than other latex paint so you can't roll back into it as long as other paints . I would still thin it. Sherwin Williams makes another product they call All Surface Enamel. We were told that if we needed just a quart of DTM we could buy this as it was just DTM in quarts. DTM only comes in gallons. I don't know if they have an ultra deep base in this line to use as the clear. If you want experiment with this product you could buy a quart to try. There would definitely be a learning curve to use this product. Using the Floetrol you would still need to thin a little. Check the S&W site and you can get the data sheets on these products.
Jack Carillon 1994 FSII Akron Oh.
[quote] [b]
gliderx5
Posted: Wed Dec 31, 2014 2:40 pm Post subject: Latex Paint Rolling Video |
Jack,
I will check with Sherwin Williams on the clear DTM. The All Surface Enamel is actually the product I've been using on the last few projects and it's great.
Thanks for the info
Malcolm Morrison
Sent: Wednesday, December 31, 2014 4:00:57 PM
| Quote: | Jack
Malcolm Morrison
