Posted: Sat Dec 20, 2014 12:08 pm Post subject: How does the Ducatti rectifier/regulator work? |
At 13:51 2014-12-20, you wrote:
Quote: |
A fellow RV-12 builder asked me this:
> From the the little that I have read concerning dynamos, they
operate at full output all the time as they have no field current
controlling them.
> Does that mean that if one runs the strobes and landing light all
the time, the Ducati reg/rectifier will have less heat to dissipate
through the cooling fins, and perhaps stay cooler and last longer?
I do not know the answer, thus am asking the experts on the
AeroElectric List. How does the Rotax 912 rectifier/regulator
work? Does it short out the dynamo output to control voltage? Or
does it add a series resistance to drop the output voltage? Or what?
Thanks, Joe
Back 'in the day' when pm alternators were first being
added to small bikes, the electrical output on the order
of 5 amps did not offer a very challenging energy management
problem. Earliest regulators simply used an SCR triggered
on each of the alternator's half-cycle to simply short the
AC output when the waveform was 'high enough' . . . this
crude regulation philosophy caused the alternator to operated
in a max-power-output mode all the time . . . with excess
power being dissipated in the alternator's windings and
the SHUNT mode, rectifier/regulator's heat sink.
As the alternators go bigger and consumer design goals
for more sophisticated electrical systems grew, there
was a pretty popular shift to SERIES mode regulation.
The B&C R/R products have always used this philosophy.
The Ducatti regulators favored by Rotax were of this
general design as well . . .
http://aeroelectric.com/Pictures/Regulators/Rotax-Ducati_Rectifier-Regulator.jpg
There are more modern versions of this design that
use MOSFET transistors in the power control loop . . .
designs that dissipate much less power as heat.
Posted: Sat Dec 20, 2014 2:21 pm Post subject: How does the Ducatti rectifier/regulator work? |
. . . From the the little that I have read concerning dynamos, they
controlling them.
True, FULL output voltage, but not necessarily full
output POWER. It's the job of the rectifier regulator
to tailor the wild-frequency, wild-voltage AC into
some reasonably stable output at the desired voltage.
user9253
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
Posted: Sun Dec 21, 2014 8:43 am Post subject: Re: How does the Ducatti rectifier/regulator work? |
I assume that the SCRs conduct at low voltage and shut off when the voltage on terminal "C" reaches the set-point. And heat is generated due to the forward voltage drop across the SCRs.
The battery symbol in the Rotax regulator/rectifier schematic looks upside down.
According to this forum:
http://www.edaboard.com/thread67699.html
The "E" in resistor values stands for ohms. Thus I interpret 2E2 to be 2.2 ohms.
Joe
_________________ Joe Gores |
Posted: Sat Dec 27, 2014 7:57 am Post subject: How does the Ducatti rectifier/regulator work? |
At 09:15 2014-12-27, you wrote:
Quote: |
<electronic.powertuning(at)yahoo.com>
Merry Christmas to all of you !
What is the maximum frequency of the output voltage generator ?
Good question! I've never had occasion to 'scope
the 912/914 internal alternator's electrical
'innards'. The SD-8 at 4KRPM is about 500 Hz.
But without actually measuring the frequency
on a running engine, you'll have to count the
magnets on the flywheel. Each pair of magnets
would produce one a.c. cycle as they pass an
stator pole piece. So 8 magnets would give
you 4 cycles per rev, 6000 rpm is 100 rev/sec
so the output would be 400 Hz at 6000 rpm.
Scale from there. That's the WAG, your own
discoveries may vary . . .
Let us know what you find out!
merlinspitfire
Joined: 26 Dec 2014 Posts: 3 Location: CLUJ_NAPOCA, ROMANIA
Posted: Sat Dec 27, 2014 8:55 am Post subject: Re: How does the Ducatti rectifier/regulator work? |
Thank You .So not exceed 600Hz frequency
No one checked with an oscilloscope ?
Posted: Sat Dec 27, 2014 9:32 am Post subject: How does the Ducatti rectifier/regulator work? |
Where does the 600Hz number come from?
merlinspitfire
Posted: Sat Dec 27, 2014 3:52 pm Post subject: Re: How does the Ducatti rectifier/regulator work? |
We considered a maximum value for the choice of components in case I want to design a regulator
user9253
Posted: Sun Dec 28, 2014 9:02 am Post subject: Re: How does the Ducatti rectifier/regulator work? |
Using Bob's formula and Gilles webpage info
http://www.aero-hesbaye.be/circuit_elec.htm
5 pair of magnets x 6000 RPM / 60 seconds = 500 Hz maximum
BTW, Gilles' webpage is interesting. It is written in German. Google Chrome translated it. But much is lost in translation, making some of it difficult to understand. During the short circuit test, the Rotax dynamo put out 21 amps without overheating.
The 22,000 microfarad capacitor improves the output waveform, but is it required by avionics? (Not that I intend to remove mine.)
Joe
Posted: Mon Dec 29, 2014 7:48 am Post subject: How does the Ducatti rectifier/regulator work? |
Joe
I'd forgotten about the work that Gilles and friends
had accomplished on the Rotax 912/914 alternator system.
The text of the article cites 200Hz (at) 2400 rpm which
confirms your extrapolation above.
Experiments I conducted some years ago on the SD-8
and companion R/R failed to demonstrate much value
for having the capacitor in place.
I'll be doing some work on PM alternators and next
generation rectifier/regulators over the next few
months. I'll take a look at the value for including
the large capacitor beyond the need to operate the
system sans battery.
"Back-in-the-day" . . . a rule of thumb for brute-
force (single cap) filters was 1000uF/Amp of load
downstream of a 60Hz rectifier. Effectiveness of
filtering would be about 5x better at the operating
frequency of the Rotax pm alternator. It seems likely
that the capacitor was originally included to offer
smoother output given the really trashy performance
of phase-switched SCR's as regulators.
We'll see . . .
Eric M. Jones
Posted: Wed Dec 31, 2014 7:39 am Post subject: Re: How does the Ducatti rectifier/regulator work? |
I hesitate to inject my questions about the schematic of the Ducati dynamo regulator. But what is that little unlabeled zener diode feeding the base of the BF493S?
And why does this look like an alternator regulator instead of a DC dynamo regulator? What am I missing?
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
