riddon(at)sent.com Guest
Posted: Wed Dec 10, 2014 8:58 am Post subject: Blue foam |
Has anyone got, or know where I can obtain some blue styrofoam, as used in the construction of the tailplanes etc. I need a couple of pieces, approx 50cm x 10cm x 10cm. I need these to make a former for a repair piece for a part for a boat and have used up or thrown away all the bits that I had left over from my Europa.
Richard Iddon.
G-RIXS.
XS Tri Gear, languishing at Blackpool waiting for the airport to open fully again.
Posted: Wed Dec 10, 2014 9:47 am Post subject: Blue foam |
Richard, I have certainly got that amount, although cannot guaruntee in quite those measurements until I have time to get it out & measure. You will be welcome to it even if in a cause which distracts you from your flying!
Regards, David
On 2014-12-10 16:56, Richard Iddon wrote: [quote] | Quote: | --> Europa-List message posted by: Richard Iddon <riddon(at)sent.com (riddon(at)sent.com)>
Richard Iddon.
G-RIXS.
ectric.com
">www.buildersbooks.com
builthelp.com
lotstore.com
m
.matronics.com/contribution
ics.com
| [b]
Posted: Wed Dec 10, 2014 10:58 am Post subject: Blue foam |
Hi David.
Thanks for the offer. I managed to snap my carbon fibre spinnaker pole on my last trip and am trying to make an internal sleeve to repair it. Nigel Graham has given me some good advice but I need to make a male former to mould a repair piece on and I think blue foam will be the best option as I can dissolve it from inside the sleeve after I have made it.
If the weather ever becomes flyable again soon, I can pop down to Gloucester or wherever is convenient for you to pick it up. Good excuse for a flight and a £50 bacon buttie.
All the best for Christmas & New Year.
Richard.
Regards, David
> Richard Iddon.
> G-RIXS.
> ectric.com
> builthelp.com
> lotstore.com
> m
> ics.com
www.aeroelectric.com
www.homebuilthelp.com
www.mypilotstore.com
www.mrrace.com
http://forums.matronics.com
spcialeffects
Posted: Wed Dec 10, 2014 12:06 pm Post subject: Re: Blue foam |
Hi Richard, Im still building so have p p p plenty should you want. Frank
Posted: Mon Dec 15, 2014 2:24 am Post subject: Blue foam |
Richard, I am assuming that the other offer you had was superior and that you don't need me to put together my ageing bits of foam for you.
Happy Christmas, David
On 2014-12-10 18:55, Richard Iddon wrote: | Quote: | | Quote: | --> Europa-List message posted by: Richard Iddon <riddon(at)sent.com (riddon(at)sent.com)>
Hi David.
Richard.On 10 Dec 2014, at 17:46, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk) wrote: Richard, I have certainly got that amount, although cannot guaruntee in quite those measurements until I have time to get it out & measure. You will be welcome to it even if in a cause which distracts you from your flying! Regards, David On 2014-12-10 16:56, Richard Iddon wrote: | Quote: | | --> Europa-List message posted by: Richard Iddon <riddon(at)sent.com (riddon(at)sent.com) Has anyone got, or know where I can obtain some blue styrofoam, as used in the construction of the tailplanes etc. I need a couple of pieces, approx 50cm x 10cm x 10cm. I need these to make a former for a repair piece for a part for a boat and have used up or thrown away all the bits that I had left over from my Europa. Richard Iddon. G-RIXS. XS Tri Gear, languishing at Blackpool waiting for the airport to open fully again. ectric.com ">www.buildersbooks.com builthelp.com lotstore.com m .matronics.com/contribution ttp://www.matronics.com/Navigator?Europa-List ics.com | www.aeroelectric.com www.buildersbooks.com www.homebuilthelp.com www.mypilotstore.com www.mrrace.com http://www.matronics.com/contribution http://www.matronics.com/Navigator?Europa-List http://forums.matronics.com | ============= ectric.com ">www.buildersbooks.com builthelp.com lotstore.com m .matronics.com/contribution ttp://www.matronics.com/Navigator?Europa-List ics.com | [b]
