spcialeffects
Posted: Sat Nov 22, 2014 2:39 pm Post subject: Stern post access panel |
Hello all. I would like to make an access panel in the stern post in case I need to remove the long control shaft and also to make it easier for access into the tail end For maintance. My inspector is a bit dubious about cutting into the post but I said to him that I got the idea after seeing that G-IANI has a vent from the D panel to the stern post. So my question is, is there a mod for this install on G-IANI?
76.27 KB |
4942 Time(s) |
nigel_graham(at)m-tecque. Guest
Posted: Sat Nov 22, 2014 4:24 pm Post subject: Stern post access panel |
I'm not aware of a mod ever being requested for this.
If you are building a mono wheel with a tail spring, then this might not
be a great idea as the stern post will carry some of the weight of the
aircraft on the ground.
If on the other hand you are building a tri-gear, then would think that
the stern post will not be subjected to any great loads that low down,
so it shouldn't be a problem. G-IANI is a tri-gear.
Nigel
On 22/11/2014 22:39, spcialeffects wrote:
http://forums.matronics.com//files/image_995.jpg
tonyrenshaw268(at)gmail.c Guest
Posted: Sat Nov 22, 2014 7:04 pm Post subject: Stern post access panel |
Hi Nigel,
Why would you worry about the sternpost carrying some of the load? The way it is reduxed in, well I would think it should make no difference as it is such a strong member. I for example am building a Classic, but have incorporated a sternpost. My tail spring sits quite tightly in the sternpost, and mine is a mono wheel, actually a taildragger. I’d like to know if anyone else sees this as an issue?
Tony Renshaw
P.S. I have thought of reinforcing the tail area nevertheless, as that hole for access is a “big” one.
| Quote: | On 23 Nov 2014, at 11:23 am, Nigel Graham <nigel_graham(at)m-tecque.co.uk> wrote:
If you are building a mono wheel with a tail spring, then this might not be a great idea as the stern post will carry some of the weight of the aircraft on the ground.
If on the other hand you are building a tri-gear, then would think that the stern post will not be subjected to any great loads that low down, so it shouldn't be a problem. G-IANI is a tri-gear.
Nigel
spcialeffects
Posted: Sat Nov 22, 2014 11:52 pm Post subject: Re: Stern post access panel |
Thanks for the reply Nigel. I am building a mono, classic. With the tail spring bonded to the stern post I can see how some load would be transferred into the post, however unlike the tri gear vent photo I am putting back what Iv removed which must strengthen in back up a bit?
dg.watts(at)talktalk.net Guest
Posted: Sun Nov 23, 2014 1:10 am Post subject: Stern post access panel |
My mono, classic with the XS Tailwheel spring, has now got over 2,100 hours on it over the last 17 years and I have never found the need for any other access for maintenance than is afforded by the standard access panel under the tailplane which I used to install the Tailwheel spring when it first came out.
Dave Watts G-BXDY
| Quote: | On 23 Nov 2014, at 07:52, spcialeffects <spcialeffects(at)aol.com> wrote:
http://forums.matronics.com/viewtopic.php?p=434373#434373
Posted: Sun Nov 23, 2014 1:12 am Post subject: Stern post access panel |
Hi Tony,
My first post wasn't very well worded. The stern post is, as you say,
immensely strong and shouldn't give cause for worry.
My concern is for the proximity of a large diameter hole so close to the
tailwheel spring mounting point. The tailwheel loads on a mono will be
dissipated upwards through the sternpost. By placing the inspection hole
immediately above it in the load path, there is a possibility of failure
should the aircraft experience a ground loop or particularly heavy
tail-down landing. The farther away this hole is placed from the spring,
and the smaller the diameter of the hole, the less likelihood of a
problem. The position is of course, dictated by the alignment of the
pitch push-rod (as per O.P.'s post). The trig-gear does not have this
problem as it has no tail spring.
Nigel
On 23/11/2014 03:04, Tony Renshaw wrote:
Hi Nigel,
Tony Renshaw
> Nigel
