Ampreg 22, not approved by Europa??
tonyrenshaw268(at)gmail.c
PostPosted: Tue Nov 04, 2014 12:05 pm    Post subject: Ampreg 22, not approved by Europa?? Reply with quote
Ironic,
Unless things have changed, to my knowledge it is still not approved by Europa.
TR
<pre><b><font size=3D2 color="#000000" face=3D"courier new,courier">
 Filesize:  206.84 KB
 Viewed:  4275 Time(s)
clivesutton
PostPosted: Wed Nov 19, 2014 1:48 pm    Post subject: Re: Ampreg 22, not approved by Europa?? Reply with quote
Confirmed in a telephone call to AD at the UK's LAA a week or two ago, West Systems 105/205 would seem to be approved - MOD74 instruction leaflet top of page 2 refers:
". . . acceptable alternative structural epoxy resin systems may be used. Some suitable alternatives are Schueffler L285/H286, West Systems 105/205 and Aeropoxy PR2032/PH3660. The use of materials other than those listed above
will require approval from Europa Aircraft."
grahamsingleton(at)btinte
PostPosted: Wed Nov 19, 2014 4:45 pm    Post subject: Ampreg 22, not approved by Europa?? Reply with quote
Schueffler L285/H286 is the best of the buch. Much more user friendly, less toxic, better wetting
and it's approved for certified aircraft.
Graham
Sent: Wednesday, 19 November 2014, 21:48
Subject: Europa-List: Re: Ampreg 22, not approved by Europa??
--> Europa-List message posted by: "Clive Sutton" <clive.maf(at)googlemail.com (clive.maf(at)googlemail.com)>
http://forums.matronics.com/viewtopic.php?p=434111#434========================http://wwsp; -Matt Drropa-List" target="_blank">http://www.matronics.com/Navigator?Europa-Listnbsp; - MATRONICS =======
PostPosted: Wed Nov 19, 2014 7:39 pm    Post subject: Ampreg 22, not approved by Europa?? Reply with quote
Thanks Graham,
I will see if it the Schueffler is available downunder. A little shocked Ampreg 22 can have a Europa formation on the Technical Data Sheet but not be approved.
Tony R.
On 20 Nov 2014, at 9:34 am, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote]Schueffler L285/H286 is the best of the buch. Much more user friendly, less toxic, better wetting
Graham
From: Clive Sutton <clive.maf(at)googlemail.com (clive.maf(at)googlemail.com)>
Subject: Re: Ampreg 22, not approved by Europa??
00" face="3D"courier" new,courier"="">[url=3D"http://www.aeroelectric.com"]www.aeroelectric.com[/url]
books.com"">www.buildersbooks.com
quot;">www.homebuilthelp.com
quot;">www.mypilotstore.com
">www.mrrace.com
a-List"">http://www.matronics.com/Navigator?Europa-List
PostPosted: Thu Nov 20, 2014 2:48 am    Post subject: Ampreg 22, not approved by Europa?? Reply with quote
Tony
It's available in the USA as MGS,
Graham
1-877-773-7336 | sales(at)compositescanada.com (sales(at)compositescanada.com)
MGS Epoxy 285 + Hardener H285/H287
Low viscosity, low toxicity laminating resin approved by the German Federal Aviation Authority. Excellent mechanical and wet-out properties. Will not spill out from fabric on vertical surfaces. Will maintain mechanical properties up to 210 F if post-cured. Mix ratio is 100:50 by volume and 100:40 by weight. Hardeners 285 and 287 can be blended to obtain optimum working time. Working time (at) 20 C = 2-3 hours (285) or 5-6 hours (287). Sizes: 1.5 gallon kit, 6 gallon kit.
To: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
Sent: Thursday, 20 November 2014, 3:38
Subject: Re: Re: Ampreg 22, not approved by Europa??
Thanks Graham,
Tony R.
Graham
[url=]www.aeroelectric.com[/url]
">www.mrrace.com
* AeroElectric www.homebui= * Race Consulting http://www.matronics.com/cont-========================f="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.c========================
" target="_blank" href="http://forums.matronics.com/">http://forums.mat===================
[/b][b]
