bbollaert(at)comcast.net Guest
Posted: Tue Jun 27, 2006 7:46 am Post subject: SIKAFLEX WINDSCREEN |
For those thinking of using an alternative for the windscreen , someone mentioned Sikaflex -252 , i called the company tech line and they only reccomend there -295 UV product
http://www.sikaindustry.com/ind/ipd-marine/ipd-ma-products.htm
along with the 226 cleaner http://www.sikaindustry.com/ipd-marine-surface-primerchart & 209 primer , this is what i think that i will use (very important to use the correct one and prepare the surfaces ).
Brian Bollaert
