berkut13(at)berkut13.com Guest
Posted: Fri Oct 24, 2014 9:04 am Post subject: Toroid beads |
Anyone got a part number (or spec) handy for the toroid beads that slide over the RG-58/400 coax on our home made antennas?
-James
tim2542(at)sbcglobal.net Guest
Posted: Fri Oct 24, 2014 9:41 am Post subject: Toroid beads |
If you dont find any James let me know, I have a few left over.
Tim Andres
On Friday, October 24, 2014 10:23 AM, "berkut13(at)berkut13.com" <berkut13(at)berkut13.com> wrote:
-James
deej(at)deej.net Guest
Posted: Fri Oct 24, 2014 9:56 am Post subject: Toroid beads |
Will need them ongoing, I was really looking for a source.
Thanks though.
-James
Sent: Friday, October 24, 2014 12:37 PM
Subject: Re: Toroid beads
Tim Andres
-James
Posted: Fri Oct 24, 2014 10:21 am Post subject: Toroid beads |
Too big. Looking for source for the small ferrite "doughnuts" that slip over the coax at the di-pole element split.
Shown here:
http://www.berkut13.com/com2_08.jpg
James
jimkale(at)roadrunner.com Guest
Posted: Fri Oct 24, 2014 10:32 am Post subject: Toroid beads |
You might try RST Engineering. It is the guy who writes the Kit Planes Electronics articles. He normally sells them.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of berkut13(at)berkut13.com
Sent: Friday, October 24, 2014 12:55 PM
Thanks though.
-James
Tim Andres
On Friday, October 24, 2014 10:23 AM, "berkut13(at)berkut13.com (berkut13(at)berkut13.com)" <berkut13(at)berkut13.com (berkut13(at)berkut13.com)> wrote:
-James
0123456789012345
Posted: Fri Oct 24, 2014 10:41 am Post subject: Toroid beads |
On 10/24/2014 02:19 PM, berkut13(at)berkut13.com wrote:
Hi James, I think the ones from Radio Shack will perform the same job,
electrically.
Yes, they are physically bigger, but they do offer one that is the right
inside diameter size to fit around the coax. They just have a plastic
case around the ferrite that "snaps" in place. Makes them easy to
remove, too, without having to undo any soldering or crimping since they
are a split configuration.
You can remove the outer plastic shell and wrap them with something
smaller (tape, whatever) if the physical outside diameter is too big.
You can probably find the exact ones you are looking for at McMaster
Carr or some other online source, and someone else on the list might be
able to offer a specific reference.
-Dj
Dj Merrill - N1JOV - VP EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
Posted: Fri Oct 24, 2014 11:10 am Post subject: Toroid beads |
No thanks! Last time I ordered from RST, it took 6 months of reminder phone calls/emails to get it. I’m not ever doing that again...YMMV.
To keep this on track...I need specs and a distributor if possible.
http://www.mouser.com/catalog/catalogusd/647/1295.pdf
If the selection is nothing more than finding something that fits around the coax, I would order from the “TOROIDAL FERRITE BEADS” section.
-James
Sent: Friday, October 24, 2014 1:32 PM
Subject: RE: Toroid beads
Posted: Fri Oct 24, 2014 11:19 am Post subject: Toroid beads |
Those are much different than the ones I think James May be looking for. I have no idea if they are suitable. RST once sold a kit with the small ferrite beads that just fit the RG 58 and could easily be imbedded into a composite structure. I think that is what he's looking for.
ralphmariafinch(at)gmail. Guest
Posted: Fri Oct 24, 2014 11:21 am Post subject: Toroid beads |
Or your mileage won't vary. I keep seeing bitter complaints about RST total lack of customer service. I'd for sure never order anything from him.
On Fri, Oct 24, 2014 at 12:08 PM, <berkut13(at)berkut13.com (berkut13(at)berkut13.com)> wrote:
[quote] No thanks! Last time I ordered from RST, it took 6 months of reminder phone calls/emails to get it. I’m not ever doing that again...YMMV.
wrmaxwell(at)bigpond.com Guest
Posted: Fri Oct 24, 2014 2:15 pm Post subject: Toroid beads |
They are simply called "toroids", which describe their shape, Jim. They come in various compositions, both ferite and iron, that vary in their frequency responses. You will need need a ferite composition effective at VHF. Commonly available through ham radio suppliers, so should not be too hard to find over there.
On 25/10/2014 5:19 AM, berkut13(at)berkut13.com (berkut13(at)berkut13.com) wrote:
[quote] Too big. Looking for source for the small ferrite "doughnuts" that slip over the coax at the di-pole element split.
Shown here:
James
Posted: Fri Oct 24, 2014 7:22 pm Post subject: Toroid beads |
At 12:03 PM 10/24/2014, you wrote:
| Quote: | Anyone got a part number (or spec) handy for the toroid beads that slide over the RG-58/400 coax on our home made antennas?
-James |
These are so ineffectual as to make their 'benefits'
undetectable except by sophisticated test equipment
in the lab. Cessna produced thousands of airplanes with
coax brazenly attached to horizontal cat-whisker dipoles
with excellent results. Our resident physics PhD did a study
on these antennas back in '69 or so. This was before 'donuts
on the coax' became the 'buzz-phrase'. Back then the purists
were into 4:1 coax baluns . . . they took care of the 'worries'
about feeding an unbalanced coax with a balanced antenna . . .
but demonstrated a 3:1 SWR under the best condition.
Later, somebody tried the ferrite beads thing . . . not all
ferrites are made the same. You need a material that
exhibits low losses at the frequency of interest . . . 110
Mhz or thereabouts. Then it's useful to understand that
the EFFECTIVENESS of adding such magnetics to the feed line
varies as the SQUARE of the turns. So, 9 ferrites strung
along a coax offer performance on the order of three turns
of coax fed through a larger torroid.
The big question is: If you don't have a balun (coax
or ferrite), who would know? The answer is: nobody.
We're talking a receiving antenna excited with nano or
pico watts from a ground station. Further, the signal
is line of sight . . . seldom more than 50 miles from
ground station to airplane. A wet string with a gazillion
to one SWR would receive the signal.
If you'd really like to 'balance' things up, you
can build a 1:1 "Pawsey stub" balun from a piece of
scrap coax. See:
http://tinyurl.com/yytxwd3
I've built dozens of these and the work just fine
but as a VOR receive antenna, the benefits for having
installed it are not observable from the cockpit.
If you'd like to see an example of effective
ferrite decoupling of a badly mated antenna/feedline
condition, look at the "airwhip" vhf comm antenna
articles on the web. One poster took one apart to show
the ferrite torroid at the base with 4-5 turns of
coax through the core . . . 16 to 25 times the
effectiveness of a single core. Further, the material
from which this core is made is narrowly crafted for
the frequency of interest. Ferrites from Radio Shack
for noise mitigation are not even close.
My first choice: Hook the coax to the antenna 'bare
foot' and it will work fine.
Second choice; Build a 1:1 Pawsey stub balun.
Third choice; track down suitable torroids but use
larger ones that will allow multiple passes of
coax thorugh the center.
But understand that choices 2 an 3 are pretty much
a waste of time in terms of outcome.
Bob . . . [quote][b]
dlj04(at)josephson.com Guest
Posted: Sat Oct 25, 2014 1:09 am Post subject: Toroid beads |
I agree with Bob that ferrite donuts are not necessary or desirable for
VOR/LOC/GS antennas. If you want good symmetrical coverage, you want a
balanced feed for your dipole and the folded balun shown in Bob's
is a good way to do that. The benefits are observable in the cockpit in
the form of increased reception range for weak signals.
If you want to make a com antenna and it's tuned correctly but you want
it to be a little more broadband (lower VSWR at the band edges,) using a
string of ferrite toroids or a tubular ferrite core is one approach.
You are using the ferrites to create loss, not coupling. In effect you
create a high resistance for currents flowing on the outside of the
shield. It is partly resistance, not just impedance. If there is high
VSWR, the ferrite heats up when you transmit, the same as a resistor in
series would, allowing some of the reflected power to be dissipated as
heat rather than bouncing back to the radio. This is not *exactly* what
you want, but it's better than having the radio shut down if you try to
transmit at 135 MHz and your antenna is sharply tuned to 122.
You do not want to create additional tuned circuits by looping the coax
through one larger toroid, you just want to create resistive loss for
reflected power, because you haven't designed an antenna that's
inherently broadband enough (good broadband antennas don't need
ferrites.) A suitable sleeve or tube core is Fair-Rite 2643625202,
available from Mouser
http://www.mouser.com/ProductDetail/Fair-Rite/2643625202 for about a
dollar. This can substitute for the 3 or 4 donuts often used. You should
use ferrites only when you can't get the VSWR low enough any other way.
David Josephson
thomas.n.gautier(at)jpl.n Guest
Posted: Sat Oct 25, 2014 3:08 am Post subject: Toroid Beads |
If you decide to go the bead route check out
palomar-engineers.com
for a source of suppressor beads for coax. They have a nice application chart.
Nick Gautier
Posted: Sat Oct 25, 2014 7:21 am Post subject: Toroid beads |
| Quote: | | You do not want to create additional tuned circuits by looping the coax through one larger toroid, you just want to create resistive loss for reflected power, because you haven't designed an antenna that's inherently broadband enough (good broadband antennas don't need ferrites.) |
Agreed to within one important point. There are 'ferrites'
and then there are 'FERRITES' . . .
There's a constellation of mixes of metal and binders used
to fabricate the device. A ferrite core can be an
efficient, compact solution to the fabrication of an
inductor or transformer. In this instance, the manufacturer
strives for the LOWEST possible losses in the core material
at the frequency of interest.
When used as a mitigator of noise, design goals can include
a 'filter' comprised of combinations of inductors and capacitors
that provide high series impedance (inductor) and low shunt
impedance (capacitor) at the antagonistic frequencies. In this
case, low loss components don't 'exterminate' the noise, they
just 'contain' it.
With the advances in powered metal technologies it was
discovered that while putting a ferrite 'bead' or toroid
over a wire would create a lumped inductance of some small
value . . . the designer could, if goals warranted, include
some material in the bead that made it a lousy candidate for
tuned circuits or transformers. This material deliberately
created energy losses within the core material . . . losses
that converts antagonistic energies into heat thus reducing
their nuisance factors.
http://tinyurl.com/3b7nuj
As a general rule, ALL products sold for the purposes
of reducing noise will be fabricated from materials having
deliberate losses . . . like the filter 'beads' and
'snap around the cable' products.
But when you pick up one of those little donut shaped
thingies with no particularly defining features of
color or part numbers, you're in the dark. The
odd toroid captured in the wild is often optimized
for a rather narrow range of characteristics that
may or may not be suited to your task.
One of several resources for reviewing capabilities
and limits for the various products can be found
here . . .
http://tinyurl.com/nx4qb9h
In the case for the 'string of beads on the coax'
the goal is to de-couple currents flowing on the
feed line shield, the task is not to add a filtering
loss but to add a high-q (read low loss) common mode
inductance to the feed-line. This would become the
lumped component version of a Pawsey stub or Bazooka
balun.
As far as weak signal performance goes, the only
time you're even close to experiencing a 'weak signal'
event is trying to read a VOR radial that is WWAAAaaayy
off the beaten track for IFR operations.
When "flying the routes", your charts will be marked
with a VOR change-over point . . . a location along
a line between VOR stations that is "equal signal"
for the stations of interest. For this mode of flight ops,
signal strengths combined with modern receiver
capabilities make a 'weak signal' event due to
standing waves on your feed line a physical
impossibility.
I've played with 'beads on the coax' in the lab and
found their benefit to be difficult to measure with
boxes having names like Hewlett-Packard and Watkins-
Johnson on them. The notion that you're going to
get more meaningful measurements with a box having
Garmin or King on front is not grounded in practice.
A suitable sleeve or tube core is Fair-Rite 2643625202, available from Mouser http://www.mouser.com/ProductDetail/Fair-Rite/2643625202 for about a dollar. This can substitute for the 3 or 4 donuts often used. You should use ferrites only when you can't get the VSWR low enough any other way.
Not very quantified . . . who actually measures VSWR
on a VOR antenna and what is 'low enough'? The measure
of antenna performance cannot be lumped into the VSWR
bucket. A resistor can have a VSWR of 1:1 over a huge
range of frequencies with ZERO performance while an
antenna with 'low enough' VSWR can perform poorly for
a variety of reasons not related to the antenna itself.
Antenna science is a BIG PICTURE activity that has
to included the entire sphere of interest . . . while
centered on your headphones, the sphere envelopes a host of
variables no single one of which is the holy grail
of satisfactory operations.
Consider some of the Blue Tooth, Wi-Fi and remote
control products. Very few of these devices have
antennas that would warm Bob Archer's heart . . . but
in the context of their operating sphere, they
perform as advertised. Some with pretty amazing
results. Dr. Dee can wear her little Blue-Tooth ear
piece and be out weeding in her garden while tutoring
a student. Amazes me.
Posted: Sun Oct 26, 2014 10:02 am Post subject: Toroid beads |
The constellation of materials used to make ferrites is referred to as
the "mix." Most common of the ferrites used in RF transformers and
chokes at VHF is type 43, which is mostly nickel and zinc. It's useful
over the whole com/nav/GS range, particularly if you are looking for
loss as we are, rather than high-Q inductance. There is good information
on the Palomar Engineers page referred to by Tom Gauthier. If you don't
recognize the joke in the Palomar author's pseudonym (sadly, the man
behind the name died at 90 last year after many excellent articles over
the years), you haven't been around antennas long enough...
Many engineers who use ferrites don't really understand what's going on.
Note that many manufacturers now specify the result of putting a core on
a wire in terms of impedance rather than inductance. It is not as simple
as a lumped inductance caused by increased permeability; if it were, the
effect would not be so broadband. Refer to several papers by Jim Brown
(and one by him and me, using a lot of H-P, W-J and Anritsu test
equipment) on ferrites at www.audiosystemsgroup.com/publish.htm ... Jim
and I started doing a lot of work analyzing the behavior of ferrites for
rfi reduction in audio equipment and learned a lot of surprising stuff.
The core mentioned in my previous post (the URL got mangled, go to
mouser.com and enter 2643625202) adds about 350 ohms of impedance,
mostly resistive, to a single wire at 100 MHz.
I agree, there's no reason to use ferrites on a receiving antenna. As I
mentioned, you use them only on a com antenna coax, where it attaches to
the antenna, when the VSWR is too high. If your radio works without
ferrites on the coax, leave them off, they are a band-aid to fix
compromised antenna design. They will never make a bad antenna better,
only allow a radio to work with a bad antenna when it might not
otherwise. The heat generated in the ferrite is the power you would have
radiated if the antenna had been properly matched. You want an actual
balun such as a Pawsey stub or a hybrid transformer for a VOR antenna
not to reduce VSWR, but to keep the pattern symmetrical. Not nice to
receive a VOR when you're heading east and have it disappear when you
turn west (I have had this experience while I was developing antennas on
my Mooney, and it was fixed by using a balun.) And some of us do use
VORs still.
David Josephson
