ed(at)solairecanada.com Guest
				 Posted: Mon Sep 29, 2014 8:21 am    Post subject: RV6-List Digest: 0 Msgs - 09/28/14 |
				I am building an RV-6 (with RV-7 FWF parts that always need to be modified).
 The problem I am now tackling is with fabricating the FAB. The downdraft FI
 is offset to the left and I ended up (like many other builders) having to
 cut a hole in the bottom cowling where the mixture arm was jamming.
 I had seen this on some builders websites and had a brain fart on
 manufacturing a smooth blister for this.
 I laid-up the glass on the inside of the appropriate size spoon and after
 trimming it is perfect and ready for painting!
 There surely are many builders having this issue, so I thought I would share
 this time saving idea.
 Another trick that helped a lot is that I used a thin 30 mm Mylar tape
 bonded to the floor with two-way tape, underneath the spar stubs.
 This made it very easy to slide the wings in and out during construction,
 without scraping the aluminum.
 It can stay in permanently, just in case the wings would have to be removed
 again in the future.
 As a glider pilot I assemble my glider every day I go fly and have used this
 tape on the bottom of the spar cavity for years now.
 A high density tape would also work.
 Ed Hollestelle
 RV-6 C-FCEH
  |  | - The Matronics RV6-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV6-List |
