tonyvaccarella
Posted: Sat Sep 13, 2014 3:06 am Post subject: Wing missing mass balance reassess |
Hello all,
I just joined this forum today - I live in Sydney Australia and have recently got possession of a partially built Europa XS (tailwheel) from the USA.
While taking stock of the equipment I noted that the aileron mass balance reassesses that should have been installed prior to wing close-out are missing.
Point here is that the wings are definitely closed - so before I even begin, I need to sort out this problem. Has anyone come across this before. Will I need to open the wind again (if that is possible) or can I install the reassesses at this late stage.
Tony Vaccarella
_________________ Tony Vaccarella
Mascot NSW 2020
Sydney Australia |
tonyrenshaw268(at)gmail.c Guest
Posted: Sat Sep 13, 2014 3:43 am Post subject: Wing missing mass balance reassess |
Hi Tony,
No help with an XS wing except to say I have heard of the wing being opened with the careful application of heat, that no doubt others might be able to comment on. Otherwise I live in Hornsby Heights Sydney, also building a Taildragger, so, welcome to the Europa fraternity. You will find this list invaluable and whilst little things have frustrated me along the way, the Europa engineering, the way it was originally designed and then brought out as a kit so we could have a crack, I still admire.
Tony Renshaw
0414391887
Quote: | On 13 Sep 2014, at 1:06 pm, "tonyvaccarella" <tony(at)weimagine.com.au> wrote:
Hello all,
Tony Vaccarella
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
http://forums.matronics.com/viewtopic.php?p=430477#430477
Fred Klein
Posted: Sat Sep 13, 2014 10:10 am Post subject: Wing missing mass balance reassess |
On Sep 13, 2014, at 4:06 AM, tonyvaccarella <tony(at)weimagine.com.au (tony(at)weimagine.com.au)> wrote:
Quote: | While taking stock of the equipment I noted that the aileron mass balance reassesses that should have been installed prior to wing close-out are missing. |
Tony…I don’t recall any previous discussion on this forum of the situation which you face.
I too have heard of judicious application of heat being used to undo Reduxed joints, but I’ve no experience doing so.
Given that the previous builder of your kit made this omission…and I’ll say a rather fundemental omission at that...if I were in your shoes, the first thing I would do is slowly and carefully verify that EVERYTHING ELSE which was required to have been installed prior to wing close-out was in fact accomplished.
If everything else is satisfactory, I would then explore the possibility of cutting out the underside of the wing at the trailing edge so that the mass balance recess could be inserted and reinforced…I’d consider the possibility of creating some flanges which could support the moulded recess.
I do not have the background or knowledge to give any advice…I can only describe how I would imagine myself dealing w/ this problem.
Be aware that there have been some wings shipped w/ the pre-moulded locations for the mass balance recess moldings mis-aligned (as were mine)…in which case, preparation for those moldings was a bit more complicated. I believe there is an advisory from the factory on how to deal w/ this situation.
Proceed w/ caution,
Hope this helps,
Fred
Posted: Sat Sep 13, 2014 12:23 pm Post subject: Wing missing mass balance reassess |
Tony, I wouldn't even contemplate taking the whole upper
wing surface off. If there is any question of opening the
wing up then a small local patch could , I guess be cut
out and subsequently repaired, probably best from both
cosmetic and aerodynamic views, on the undersurface. It is
very difficult to do any heat produced modifications on
any sizeable area. Getting a spar pin socket out of the
seat back works nicely if you blow a heat gun down the
hole, but I would hesitate to try anything bigger. But
what you really need is an inspector with fibreglass
skills, and ideally someone who is a professional glider
repairer. I assume there must be one or more such persons
in Oz as glider pilots not infrequently get it wrong and
make a bit of a mess of their plane, and very extensive
damage can be repaired to as new standards. But there are
strict principles for maintaining the strength of the
structures. Alternatively, speaking as a retired
gynaecologist, I suspect it might be possible to put
modified recess bits in through the hole in the close out
possibly by say cutting in two vertically and patching
over the join line.
Regards, David Joyce, G-XSDJ
On Sat, 13 Sep 2014 04:06:46 -0700
Hello all,
Tony Vaccarella
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
Un/Subscription,
Forums!
Admin.
budyerly(at)msn.com Guest
Posted: Sat Sep 13, 2014 12:36 pm Post subject: Wing missing mass balance reassess |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Tony,
Often there is little precious room in the wing for poorly built (or just factory assembled and glued up) aileron weights.
Many times I have to cut the top off the supplied boxes and flanges to get the weight box to fit the customers (or factory NG assembled) ailerons.
To be brief: you will fabricate a weight box as we did in the Classic wing which was all foam (Reference page 8-14). The exercise above is easy and often times fits the wing and aileron weights much more accurately. When finished you will have a bit more sanding to do, but it is worth it.
REMEMBER- Since the rear of the wing is cut out, what you are doing is adding back in shear load structure.
One solution is to use foam of about 3/8 inch thick or more, on each side of the mass balance arm hole and at the front. Lay 2-3 layers of glass around the closeout. You may recess the foam an inch from the opening and make a closeout as in the aileron. This recessed closeout is a strong C section, but will require filling or it will look nasty. Use more foam to fill the gap with a bit of expand cell and cover with 2 oz cloth for neatness.
Or as we did in the Classic, install the foam about 3/16 inch from the aileron weight with rapid epoxy. Cut a generous flox corner at the junction of the foam to top, bottom, and aft closeout skins. Be sure to run the glass along the upper surface and butt it at the lower skins. Let the glass hang past the skins a bit and peel ply. Trim after cure. I prefer the latter as there is less filling, but in my opinion, the former aileron style closeout is a stronger joint with the glass flat on both the upper, lower and aft closeout. It takes another step to fill and clean up as it is a big hole...
Cutting the wing open for essentially a close out of 4 plies is too hard to recover from in time and money.
Congratulations on your purchase.
Study your build manual hard, ask questions and hone your skills.
You will be rewarded with a great aircraft.
Best Regards,
Bud Yerly
US Europa Dealer
Description: |
 Download |
Filename: |
Wing_Build.pdf |
Filesize: |
1.79 MB |
Downloaded: |
344 Time(s) |
jan_de_jong(at)casema.nl Guest
Posted: Sun Sep 14, 2014 5:37 am Post subject: Wing missing mass balance reassess |
Tony,
All good advice IMO: carefully inspect the inside as much as possible,
do not try to remove the wing lid, find a local solution.
http://www.europaowners.org/main.php?g2_itemId=37071 shows my wing
before bonding the lid on.
As you can see I removed the mass balance box mold tops before bonding
the lid on.
After bonding the lid on I laid up on the inside of the box to the lid.
Advice of Neville Eyre.
I hope this gives an idea of what is aimed for.
Jan de Jong
On 9/13/2014 1:06 PM, tonyvaccarella wrote:
Quote: |
Hello all,
Tony Vaccarella
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
Posted: Sun Sep 14, 2014 6:46 am Post subject: Wing missing mass balance reassess |
I agree with Jans advice...I had to remove the wing closeout and you cant do it without destroying it. Â Its a messy job to do.
Will
William Daniell
LONGPORT
+57 310 295 0744
On Sun, Sep 14, 2014 at 8:36 AM, Jan de Jong <jan_de_jong(at)casema.nl (jan_de_jong(at)casema.nl)> wrote:
[quote]--> Europa-List message posted by: Jan de Jong <jan_de_jong(at)casema.nl (jan_de_jong(at)casema.nl)>
Tony,
All good advice IMO: carefully inspect the inside as much as possible, do not try to remove the wing lid, find a local solution.
http://www.europaowners.org/main.php?g2_itemId=37071 shows my wing before bonding the lid on.
As you can see I removed the mass balance box mold tops before bonding the lid on.
After bonding the lid on I laid up on the inside of the box to the lid. Advice of Neville Eyre.
Jan de Jong
Quote: | --> Europa-List message posted by: "tonyvaccarella" <tony(at)weimagine.com.au (tony(at)weimagine.com.au)>
Hello all,
Tony Vaccarella
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
pa-List" target="_blank">http://www.matronics.com/Navigator?Europa-List
JonathanMilbank
Joined: 14 Apr 2012 Posts: 395 Location: Aberdeen area
Posted: Mon Sep 15, 2014 3:40 am Post subject: Re: Wing missing mass balance reassess |
Tony,
I can't add much to the advice of others and my wings are the Classic early foam-cored type, so what I'm about to say may be irrelevant for XS wings. It is important to keep constantly in mind when creating the recesses that when the ailerons eventually get attached, their trailing edge downward deflection is limited by the mass balance weights touching the underside of the wing top surface. You need enough deflection for rigging adjustments.
In the Classic the tolerance for downward aileron deflection is very tight and so it was imperative not to add too much thickness under the wing upper surface by adding unnecessary extra layers of anything. After attaching the aileron hinges to the wings, I was careful with temporarily attaching the mass balance foam arms and lead weights using 5 minute epoxy to ensure that the arms weren't angled too much upwards from the leading edges of the ailerons. Also allow a millimetre or so for the thickness of the "uni" glass straps which eventually get wrapped around the mass balance arms and their weights.
What the others have already advised you all seems like good stuff to me.
tonyvaccarella
Posted: Mon Sep 15, 2014 4:23 am Post subject: Re: Wing missing mass balance reassess |
Thank you to all the people who have posted a reply to my post. I will be making a close inspection of the aircraft with my technical adviser tomorrow and hopefully some information will come from that meeting.
Thank you all once again.
Tony
Mascot NSW 2020
Sydney Australia |
tonyvaccarella
Posted: Mon Sep 15, 2014 5:59 am Post subject: Re: Wing missing mass balance reassess |
Hello again,
Well I think I have finally worked out what's happened. I only took possession of this aircraft 2 weeks ago and been busy reviewing what I have and what is missing.
The aircraft was sold to me as an XS and came from the USA s/n A011 but on closer inspection of the wings seemed to show that they are foam core. So I think I was sold a Europa Classic. It is for this reason that the mass-balance reassesses are missing at that they are not cut out. In reviewing the Builders Manual for the Classic Wing, the mass balance boxes are not provided and need to be build. Also the reassess is constructed AFTER the wing is closed.
I feel releaved in one way but annoyed in another that I was sold a Classic when I was assured it was an XS.
Has anyone heard of this happening before - should I be concerned with the Classic as compared to the XS?
Thanks once again..
Tony
Mascot NSW 2020
Sydney Australia |
rowlandcarson(at)gmail.co Guest
Posted: Mon Sep 15, 2014 7:07 am Post subject: Wing missing mass balance reassess |
On 15 Sep 2014, at 14:59, tonyvaccarella <tony(at)weimagine.com.au> wrote:
Quote: | The aircraft was sold to me as an XS and came from the USA s/n A011 but on closer inspection of the wings seemed to show that they are foam core. So I think I was sold a Europa Classic. It is for this reason that the mass-balance reassesses are missing at that they are not cut out. In reviewing the Builders Manual for the Classic Wing, the mass balance boxes are not provided and need to be build. Also the reassess is constructed AFTER the wing is closed.
Tony - it appears that kit A011 was sold by the factory in 1995 so it’s pretty certain to be a Classic, as the XS didn’t come along until about 2000.
No doubt opinions will vary, but I wouldn’t worry too much about the difference between the XS and Classic wings. There are also differences in the fuselage (eg XS has larger baggage bay) but having flown in both models, I don’t feel the differences are enough to get hot under the collar about.
There are examples of combinations of XS and Classic parts - I think some Classic wings are flying on an XS fuselage, and some Classic fuselages have XS firewall-forward stuff.
Did you get the build manuals as issued by the factory with that kit? Did you get any construction and/or inspection documentation from the original builder(s)?
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
nigel_graham(at)m-tecque. Guest
Posted: Mon Sep 15, 2014 7:17 am Post subject: Wing missing mass balance reassess |
Tony,
The original "classic" kits were sold in three phases, Kit one was tail
planes with rudder, fin, flaps and ailerons. Kit two was the blue foam
wings and kit three was the fuselage.
There are many Europas out there that started life with "Classic" blue
foam wings, but by the time their builders were ready for the fuselage
kit, the "New" XS was available, so many of them ended up as hybrids.
The good thing is that there is absolutely nothing "second rate" about
the earlier wings. They are slightly shorter than the XS and have
shorter but deeper ailerons and are reputed to weigh less (I haven't
weighed mine to check), but fly just as well.
The XS fuselage had a 2" deeper left hand footwell to address complaints
from early flyers that the legroom was a bit lacking (why Europa didn't
extend both footwells I have no idea), so a quick check to see it you
have an XS fuselage is to see if these are the same depth or not.
Other XS differences include an integrated fin (no longer a need to make
the blue foam fin and stick it on), pre-moulded fuel drain cut-outs
under the fuel tank and slightly different foam reinforcement around the
rear of the cockpit module by the rear "D" bulkhead.
If you do have this combination of foam wings with XS fus, you can feel
happy that it is XS'ish. If however, the fus is the earlier "Classic"
then you may be justified contacting the seller for a "robust" discussion.
Either way, you have it now and I doubt you are going to ship it back to
the States. Just get to grips with the build and have some fun, you'll
end up with a fantastic little plane.
I have copies of all of the original Blue Foam build manuals in pdf
format. If you would like a copy, email me off list and I'll send them on.
Nigel
On 15/09/2014 14:59, tonyvaccarella wrote:
Quote: |
Hello again,
Thanks once again..
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
http://forums.matronics.com/viewtopic.php?p=430565#430565
Posted: Mon Sep 15, 2014 7:27 am Post subject: Wing missing mass balance reassess |
Tony, The XS is a superior plane but not by a lot and the
Classic still outperforms most other small aircraft. There
are a number of modifications that are applicable to the
Classic which give it most of the advantages of the XS.
Principle amongst these are a strengthening bar between
the rear lift pins to allow the Max All Up Wt to be
increased to that of the XS (ie from memory to 1370lbs), A
new design of baggage bay to give much more room for
luggage and moving the rear wheel back from its original
Classic position under the rear fuselage to sit on a tail
spring extension a foot or so behind the back of the fus,
with this significantly improving ground handling. If all
these are incorporated then one could say more or le3ss
honestly that it had been uprated to XS spec. If not
already incorporated then it is a smart move to plan to do
so.
On Mon, 15 Sep 2014 06:59:11 -0700
Hello again,
wing is closed.
Thanks once again..
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
Un/Subscription,
Forums!
Admin.
pete(at)lawless.info Guest
Posted: Mon Sep 15, 2014 7:40 am Post subject: Wing missing mass balance reassess |
Hi Tony
Have a look in the wing root where the aileron push rod goes in. You
will be able to see the blue foam in there.
Just need to be careful of the stall characteristics if the wing is
foam, as the original leading edge profile can get screwed up by the
filling and sanding. Can all be sorted out easily by fitting short
stall strips to the root end of the leading edge.
Pete
PS Kit one was fin, rudder, stabiliser. Flaps and ailerons came with
the wings.
G-RMAC #109 very definitely not XS with foam wing!
On 15/09/14 16:17, Nigel Graham wrote:
Quote: |
<nigel_graham(at)m-tecque.co.uk>
Tony,
tail planes with rudder, fin, flaps and ailerons. Kit two was the blue
foam wings and kit three was the fuselage.
complaints from early flyers that the legroom was a bit lacking (why
Europa didn't extend both footwells I have no idea), so a quick check
to see it you have an XS fuselage is to see if these are the same
depth or not.
make the blue foam fin and stick it on), pre-moulded fuel drain
cut-outs under the fuel tank and slightly different foam reinforcement
around the rear of the cockpit module by the rear "D" bulkhead.
feel happy that it is XS'ish. If however, the fus is the earlier
"Classic" then you may be justified contacting the seller for a
to the States. Just get to grips with the build and have some fun,
you'll end up with a fantastic little plane.
on.
Nigel
> Hello again,
> Thanks once again..
> Tony
> Tony Vaccarella
> Mascot NSW 2020
> Sydney Australia
JonathanMilbank
Posted: Mon Sep 15, 2014 8:12 am Post subject: Re: Wing missing mass balance reassess |
The foam filled Classic wings are definitely lighter by something like 10 lbs each. As regards the extended spring-arm tail wheel, I'll go to my grave insisting that the original tail wheel (direct cable linkage and no springs) is better with far less propensity to ground looping. I have about 700 hours in my own original tail wheeled aircraft and did the test flying of my friend's aircraft with extended tail wheel for the initial permit issue.
No, it isn't that I'm more accustomed to my own aircraft which causes me difficulty in keeping straight after landing in his machine. I have no doubt after several hours in his and I'm certain that the springs built into the linkage cause a lag in response whenever anyone applies pedal either way.
These springs are a feature of both the factory extended tail wheel modification and the more tidy-looking extended tail wheel design by Graham Singleton. I'd be interested to hear from anyone who has experience with both the factory- and the Singleton tail wheel designs.
I understand why the factory saw fit to redesign the tail wheel arrangement and I accept that it probably helps during take off in a crosswind, but I believe that it makes matters worse for landing in a crosswind. I look forward to a reply from Graham perhaps to offer a suggestion as to what, if anything, might be done to improve tail responsiveness particularly after landing. Perhaps tighten the springs?
In the meantime, I strongly recommend that Tony should fit a tricycle undercarriage, as I have recently done and enjoy stress-free landings.
ptag.dev(at)talktalk.net Guest
Posted: Fri Sep 19, 2014 5:22 am Post subject: Wing missing mass balance reassess |
Hi! Tony. I was sold a hybrid classic wings and xs cockpit module but also paid for a mono and trike conversion by the factory and was somewhat miffed to find the new quick build wings were about to hit the market! I placated my self by the thought that the foam filled wings or parts of them may float if ditched! Since then I am very happy to have abandoned the mono concept and have landed in 35 knot cross winds and have done 1200 hours landing in every country in Europe. My friends think I need my "bumps" feeling for flying to Texel direct over the North Sea in 1 hour 45 ! Still I guess you wouldn't be much of a similar mind in O Z! Just get it completed and join the satisfied Europa owners .
Regards Bob Harrison. G-PTAG (kit 337 first flew 06/09/2000.
Sent: 15/09/2014 15:59
Subject: Re: Wing missing mass balance reassess
--> Europa-List message posted by: "tonyvaccarella" <tony(at)weimagine.com.au>
Hello again,
Thanks once again..
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
- MATRONsp; - List Contribution Web Site nbsp; &======================
