Posted: Sun Aug 31, 2014 11:08 am Post subject: ICOM A 24 handheld radio |
Al while ago I bought the above radio. I took it with me religiously as a
back up on the basis that you can use it in flight and in the event of an
off airport landing it might be useful. Today my X air which as been
excellent up to now went intermittent.
I thought ok I will just fire up the ICOM. Well it didn't work or rather
not with a headset. Further research on the web suggests that despite
having a headset adapter in the box, there are problems getting it to work
with a headset. If you cant use a headset then the value as a backup is
questionable.
Has anyone had this issue?
I would welcome suggestions for handheld back up radios which do work with
headsets...
Will
christoph.both(at)acadiau Guest
Posted: Sun Aug 31, 2014 12:08 pm Post subject: ICOM A 24 handheld radio |
Sporty's SP 400 works great with the optional GA audio adapter supplied by Sporty's. If you don't want to key the mike on the unit you can also hook a mic switch in line with the headset audio. Works like a charm alongside the SP400 which is cradled with a RAM mount to the instrument panel. I had installed radio problems and the handheld really got me out of trouble a few times!
Chris Both
Europa 223
On Aug 31, 2014, at 16:08, "William Daniell" <wdaniell.longport(at)gmail.com<mailto:wdaniell.longport(at)gmail.com>> wrote:
Al while ago I bought the above radio. I took it with me religiously as a back up on the basis that you can use it in flight and in the event of an off airport landing it might be useful. Today my X air which as been excellent up to now went intermittent.
I thought ok I will just fire up the ICOM. Well it didn't work or rather not with a headset. Further research on the web suggests that despite having a headset adapter in the box, there are problems getting it to work with a headset. If you cant use a headset then the value as a backup is questionable.
I would welcome suggestions for handheld back up radios which do work with headsets...
Will
cakeykev(at)gmail.com Guest
Posted: Sun Aug 31, 2014 12:29 pm Post subject: ICOM A 24 handheld radio |
I use an Icom with a Lynx headset with a paramotor. The headset is especially made for this and works very well. But of course you would need to carry a spare headset.
Kevin Challis
On 31 Aug 2014, at 20:08, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
[quote]Al while ago I bought the above radio. I took it with me religiously as a back up on the basis that you can use it in flight and in the event of an off airport landing it might be useful. Today my X air which as been excellent up to now went intermittent.
Will
William Daniell
LONGPORT
+57 310 295 0744
peterz(at)zutrasoft.com Guest
Posted: Sun Aug 31, 2014 12:52 pm Post subject: ICOM A 24 handheld radio |
i have used the icom a24 without issue with the supplied headset adapter, with the bose a20 and a ptt switch plugged into the adapter.
cheers,
pete
On Aug 31, 2014, at 4:29 PM, Kevin Challis <cakeykev(at)gmail.com (cakeykev(at)gmail.com)> wrote:
[quote]I use an Icom with a Lynx headset with a paramotor. The headset is especially made for this and works very well. But of course you would need to carry a spare headset.
Kevin Challis
Quote: | Al while ago I bought the above radio. I took it with me religiously as a back up on the basis that you can use it in flight and in the event of an off airport landing it might be useful. Today my X air which as been excellent up to now went intermittent.
Will
William Daniell
LONGPORT
+57 310 295 0744
a-List"">http://www.matronics.com/Navigator?Europa-List
//forums.matronics.com
rampil
Posted: Mon Sep 01, 2014 7:24 am Post subject: Re: ICOM A 24 handheld radio |
My vertex 710 also works fine with my Lightspeed Zulu and a rubber ducky antenna, thought the range is limited. On the Vertex, the headset cord adapter is a rigid, rugged screw-in
Exactly what is the problem you are having? Is it the speakers, the mike, the PTT?
What was the company's response when you complained?
Posted: Mon Sep 01, 2014 11:43 am Post subject: ICOM A 24 handheld radio |
Ira
well i complained yesterday so i expect that it will take them a while.
I did some research on the web and apparently it has to do (as somebody mentioned) with the impedance of the mic.
I can hear fine. Tx either produces whine or whistle and/or doesn't show as TX in the little window. the signal is not received.
Without headset the radio works fine.
I am sending it to the representative here to see if they can work out what is wrong. I will let you know the result.
yours
Will
William Daniell
LONGPORT
+57 310 295 0744
On Mon, Sep 1, 2014 at 10:24 AM, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
[quote] --> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=429765#429765
pa-List" target="_blank">http://www.matronics.com/Navigator?Europa-List
FORUMS -
b Site -
-Matt Dralle, List Admin.
787driver
Joined: 02 Sep 2014 Posts: 3 Location: Southern Florida
Posted: Thu Sep 04, 2014 9:50 am Post subject: Re: ICOM A 24 handheld radio |
Truth be told I've found the speaker on the Icom to be quite loud enough to use on just about any general aviation aircraft without a headset. It certainly is not ideal but it's one less thing to fiddle with in an abnormal situation. If all I intended to do was to re-enter the traffic pattern (circuit) and land its perfectly fine for that without a headset.
Posted: Thu Sep 04, 2014 10:01 am Post subject: ICOM A 24 handheld radio |
Yes I can see that. didnt think of that since my radio went inop on the ground
Will
William Daniell
LONGPORT
+57 310 295 0744
On Thu, Sep 4, 2014 at 12:50 PM, 787driver <savagecub(at)gmail.com (savagecub(at)gmail.com)> wrote:
[quote] --> Europa-List message posted by: "787driver" <savagecub(at)gmail.com (savagecub(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=429979#429979
FORUMS -
b Site -
rampil
Posted: Thu Sep 04, 2014 10:58 am Post subject: Re: ICOM A 24 handheld radio |
Generically speaking, an impedance mismatch of the microphone will cause the
a lower transmitted sound volume. That is because the mismatch will cause a lower voltage signal into the transmit input circuit.
A whine or squeal is usually the fault of a feedback loop. Could it be that the mike was too close to the headset speaker when you were testing it?
Ira
