Kellym
Posted: Sat Aug 30, 2014 7:02 am Post subject: Shunt - Location |
Well, I physically mounted mine, along with an ANL current limiter
yesterday. I placed the shunt above and to the left of the oil and fuel
pressure sensor block. I wired it into the Alt line, your option 1.
Reason is that I am using the VPX box in lieu of a bus. VPX measures the
current flow from the battery automatically, and my shunt measure flow
from Alt, and the VPX shows graphically on my Dynon Skyview where the
electrons come from and where they go. Hooked up shunt last night and
verified it did exactly as described, by connecting a battery charger in
front of the shunt, and a second one on the battery.
Really slick.
If you only have one location to measure current, I would do your option
2, because you want to know whether you are charging the battery or
drawing from it. Amps from the alternator and total load are less
important than whether you are discharging your battery.
I don't know with Garmin, but I suspect that like Dynon you can install
a second shunt if you really want more info.
On 8/30/2014 7:47 AM, Phillip Perry wrote:
Quote: | Last night I was thinking about shunt locations and it seems like
there are 3 different electrical locations for it.
1) Connected in the B-Lead (to measure the output of the ALT).
2) Connected to the battery (to measure the load on the battery; but
it misses the contributions of electrons coming from the ALT to the
main buss.)
Location 3 seems to be the most logical spot for me.
3) Immediately before the main buss. So the ALT and Battery can be
sending electrons to the buss and I'll be measuring them before they
enter the buss as they're consumed. Then I'm getting a measurement of
true load (minus the start).
Where have most of you installed yours? I really like option 3 but
want to make sure I'm not missing something. I'm also curious to know
where yours is installed? I'm thinking of putting it on the aft side
of the sub panel, so I can yank a G3X screen and access it.
Phil
KCHD |
Posted: Sat Aug 30, 2014 7:21 am Post subject: Shunt - Location |
A lot of options. Some thoughts:
<![if !supportLists]>· <![endif]>Most shunts cannot handle starting current, so the shunt cannot be install anywhere between the battery and the starting solenoid.
<![if !supportLists]>· <![endif]>While knowing what the non-starting loads are is of value, once measured there is little more to be gained by having them constantly monitored.
<![if !supportLists]>· <![endif]>The load on the alternator however provides an indication of battery health (via charge rate compared with buss voltage). So the shunt on the alternator output does have some value if monitored.
<![if !supportLists]>· <![endif]>On my plane I did not install a current shunt. I find independent voltage monitoring of each battery to be a better indicator of electrical power distribution system health. No issue however if one wants to add current monitoring as well.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
Sent: Saturday, August 30, 2014 10:48 AM
Subject: Shunt - Location
Last night I was thinking about shunt locations and it seems like there are 3 different electrical locations for it.
2) Connected to the battery (to measure the load on the battery; but it misses the contributions of electrons coming from the ALT to the main buss.)
3) Immediately before the main buss. So the ALT and Battery can be sending electrons to the buss and I'll be measuring them before they enter the buss as they're consumed. Then I'm getting a measurement of true load (minus the start).
Where have most of you installed yours? I really like option 3 but want to make sure I'm not missing something. I'm also curious to know where yours is installed? I'm thinking of putting it on the aft side of the sub panel, so I can yank a G3X screen and access it.
Phil
saylor.dave(at)gmail.com Guest
Mine is between the B-lead and the main bus. Assuming the battery is fully charged, it shows how much power the entire plane is drawing and indicates that the alternator is working. Right after start-up it shows a larger draw as the battery gets topped off. Then it settles into its normal routine. I have a low voltage light, and my engine monitor alerts for hi/low volts and amps.
--Dave
Single 925, single PP alt, numerous internal batteries
On Sat, Aug 30, 2014 at 7:47 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
[quote]Last night I was thinking about shunt locations and it seems like there are 3 different electrical locations for it.
Phil
Quote: |
tp://forums.matronics.com
| [b]
Posted: Sat Aug 30, 2014 7:22 am Post subject: Shunt - Location |
I prefer to know what my battery is doing. If it goes more than a couple of amps negative with the engine running, then you have problems. Also, right after start you will see 25+ amps positive which is a great indication that your alternator is working well enough to recharge your battery while powering the bus. Knowing what the bus is drawing is good for load shedding, but that's all. The one from the alternator is good too, so you will know if it isn't putting out amperage.
The battery info is my favorite and most informative one.
Jesse SaintI-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Aug 30, 2014, at 10:47 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Phil
Quote: |
List"">http://www.matronics.com/Navigator?RV10-List
Posted: Sat Aug 30, 2014 10:25 am Post subject: Shunt - Location |
Mine is in the main battery feed.
Linn
On 8/30/2014 10:47 AM, Phillip Perry wrote:
[quote] Last night I was thinking about shunt locations and it seems like there are 3 different electrical locations for it.
Phil
Checked by AVG - www.avg.com
08/30/14 [b]
Posted: Sat Aug 30, 2014 10:30 am Post subject: Shunt - Location |
It is between the starter solenoid (battery side) and my bus. The alternator is also tied to the bus. 8awg wire in and out. The 8awg ties to the same lug as the 2awg going to the battery.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Aug 30, 2014, at 11:33 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
[quote]Good feedback so far.
Jessie, on your position, I assume it's inline and handles the start without any issue. (That's where Garmin suggests)
What do you actually see on your digital readouts? Do you see 0 Amps on a charged battery and typically -1 or so inflight?
I'm just trying to understand the difference between what would be seen monitoring a batteries charge vs monitoring a load at the buss input.
Very helpful stuff everyone.... Keep the thoughts coming please.
Phil
On Sat, Aug 30, 2014 at 10:12 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
Quote: | I prefer to know what my battery is doing. If it goes more than a couple of amps negative with the engine running, then you have problems. Also, right after start you will see 25+ amps positive which is a great indication that your alternator is working well enough to recharge your battery while powering the bus. Knowing what the bus is drawing is good for load shedding, but that's all. The one from the alternator is good too, so you will know if it isn't putting out amperage.
www.itecusa.org
www.mavericklsa.com
C: [url=tel:352-427-0285]352-427-0285[/url]
O: [url=tel:352-465-4545]352-465-4545[/url]
F: [url=tel:815-377-3694]815-377-3694[/url]
Quote: | Last night I was thinking about shunt locations and it seems like there are 3 different electrical locations for it.
Phil
Kellym
Posted: Sat Aug 30, 2014 4:14 pm Post subject: Shunt - Location |
You really only have two choices. Either between Alternator and buss, or
between starter relay and buss. The latter tells you what you expect,
positive charge or discharge. You would have difficulty connecting
between battery and starter relay because it is #4 wire, requiring
bigger terminals than the shunt is intended to take, and I don't think
any shunt is designed for over 100 amps, while starter pulls 2-3 times
that. So your #2 and #3 necessarily have to be the same place and
probably will be your choice.
Phil
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org <mailto:jesse(at)itecusa.org>
www.itecusa.org <http://www.itecusa.org>
www.mavericklsa.com <http://www.mavericklsa.com>
C: 352-427-0285 <tel:352-427-0285>
O: 352-465-4545 <tel:352-465-4545>
F: 815-377-3694 <tel:815-377-3694>
> to the main buss.)
> and access it.
> Thanks,
> Phil
> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
> //forums.matronics.com <http://forums.matronics.com>
KCHD |
philperry9
Posted: Sat Aug 30, 2014 4:32 pm Post subject: Shunt - Location |
I'm not sure that's true and it's part of what I'm wrestling with..... This is a direct quote from the G3X installation manual and from this text, it leads me to believe that it could be placed anywhere in the #2 wire and it would read the charge or discharge rates of that battery. Am I missing something?
Quote: |
An alternator ammeter shunt should be installed inline in the alternator output (“B” terminal). A battery ammeter shunt should be installed between the battery positive terminal and the battery contactor. Depending on the location of the alternator or battery relative to its supported electrical bus, it is typically desirable to install the shunt on the firewall near where the alternator or battery output would normally penetrate the firewall.
On Sat, Aug 30, 2014 at 7:13 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
[quote]--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
You really only have two choices. Either between Alternator and buss, or between starter relay and buss. The latter tells you what you expect, positive charge or discharge. You would have difficulty connecting between battery and starter relay because it is #4 wire, requiring bigger terminals than the shunt is intended to take, and I don't think any shunt is designed for over 100 amps, while starter pulls 2-3 times that. So your #2 and #3 necessarily have to be the same place and probably will be your choice.
Phil
On Sat, Aug 30, 2014 at 10:12 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com) <mailto:jesse(at)saintaviation.com (jesse(at)saintaviation.com)>> wrote:
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org (jesse(at)itecusa.org) <mailto:jesse(at)itecusa.org (jesse(at)itecusa.org)>
C: [url=tel:352-427-0285]352-427-0285[/url] <tel:[url=tel:352-427-0285]352-427-0285[/url]>
O: [url=tel:352-465-4545]352-465-4545[/url] <tel:[url=tel:352-465-4545]352-465-4545[/url]>
F: [url=tel:815-377-3694]815-377-3694[/url] <tel:[url=tel:815-377-3694]815-377-3694[/url]>
to the main buss.)
and access it.
Phil
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
Kellym
Posted: Sat Aug 30, 2014 5:05 pm Post subject: Shunt - Location |
I suppose there might be some aircraft with battery on the firewall
where you might do that, but it makes no sense.
What information are you going to get by having the shunt at the
battery? So you have a shunt that can handle the current, it will have
less resolution of low current movement. (all shunts are designed for
0-50mv, where 50 mv equals full scale). The only current you see at the
battery besides what goes to the buss is the starter and anything else
that you bypass the buss for some reason.
You really don't want to be splicing #2 or #4 wire to install a shunt.
#8 from starter relay to the buss will tell you all the information you
want.
I don't have a clue why Garmin wrote that. I'm not aware of any
certified aircraft that do it that way.
On 8/30/2014 5:32 PM, Phillip Perry wrote:
Quote: | I'm not sure that's true and it's part of what I'm wrestling with.....
alternator output (“B” terminal). */A battery ammeter shunt should
contactor./* Depending on the location of the alternator or
<mailto:kellym(at)aviating.com>> wrote:
<kellym(at)aviating.com <mailto:kellym(at)aviating.com>>
choice.
Phil
<jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
than a
positive
working well
Knowing
that's all.
if it
Jesse Saint
I-TEC, Inc.
<mailto:jesse(at)itecusa.org <mailto:jesse(at)itecusa.org>>
www.itecusa.org <http://www.itecusa.org> <http://www.itecusa.org>
C: 352-427-0285 <tel:352-427-0285> <tel:352-427-0285
<tel:352-427-0285>>
O: 352-465-4545 <tel:352-465-4545> <tel:352-465-4545
<tel:352-465-4545>>
F: 815-377-3694 <tel:815-377-3694> <tel:815-377-3694
<tel:815-377-3694>>
<philperry9(at)gmail.com <mailto:philperry9(at)gmail.com>
seems like
the ALT).
the battery;
from the ALT
to the main buss.)
Battery can
them
I'm getting
option 3
of putting
G3X screen
and access it.
Phil
tp://forums.matronics.com <http://forums.matronics.com>
KCHD |
Posted: Sat Aug 30, 2014 5:35 pm Post subject: Shunt - Location |
If the #2 wire goes to the starter solenoid and the buss is connected to that same point with #8 then the shunt can be placed in the #8 line and not carry starter current. Then the shunt will read the charge current minus the load current. It all depends on what data you're interested in.
I want to know the health of my alternator and my battery ..... I don't care what the 'load' is. Putting the shunt in the buss to battery link gives me what I am looking for. Also, a voltmeter .... seems like every accessory has one in it .... will tell you the other half of the data you should have.
I agree with Kelly .... you don't want anything in that #2 cable between the battery and the starter .... except the starter solenoid and master solenoid. Anyway a 300+A shunt is pricey.
Linn
On 8/30/2014 8:32 PM, Phillip Perry wrote:
[quote] I'm not sure that's true and it's part of what I'm wrestling with..... This is a direct quote from the G3X installation manual and from this text, it leads me to believe that it could be placed anywhere in the #2 wire and it would read the charge or discharge rates of that battery. Am I missing something?
Quote: | --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Phil
Jesse Saint
I-TEC, Inc.
to the main buss.)
and access it.
Phil
08/30/14 [b]
Posted: Sat Aug 30, 2014 5:42 pm Post subject: Shunt - Location |
I agree. From your earlier email, though, there are actually all 3 choices. You could see how much the bus is using by connecting the alternator to the battery side of the shunt and the bus to the other side. As I mentioned earlier, though, this doesn't give valuable information compared to the other two options.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
Quote: | On Aug 30, 2014, at 9:04 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
I suppose there might be some aircraft with battery on the firewall where you might do that, but it makes no sense.
What information are you going to get by having the shunt at the battery? So you have a shunt that can handle the current, it will have less resolution of low current movement. (all shunts are designed for 0-50mv, where 50 mv equals full scale). The only current you see at the battery besides what goes to the buss is the starter and anything else that you bypass the buss for some reason.
You really don't want to be splicing #2 or #4 wire to install a shunt. #8 from starter relay to the buss will tell you all the information you want.
I don't have a clue why Garmin wrote that. I'm not aware of any certified aircraft that do it that way.
> On Sat, Aug 30, 2014 at 7:13 PM, Kelly McMullen <kellym(at)aviating.com <mailto:kellym(at)aviating.com>> wrote:
> choice.
> Phil
> than a
> positive
> working well
> Knowing
> that's all.
> if it
> Jesse Saint
> I-TEC, Inc.
> <tel:352-427-0285>>
> <tel:352-465-4545>>
> <tel:815-377-3694>>
> Sent from my iPhone
> seems like
> the ALT).
> the battery;
> from the ALT
> to the main buss.)
> Battery can
> them
> I'm getting
> option 3
> of putting
> G3X screen
> and access it.
> Thanks,
> Phil
> _blank">http://www.matronics.com/contribution
> FORUMS -
> _blank">http://forums.matronics.com
> b Site -
> target="_blank">http://www.matronics.com/contribution
philperry9
I dug my Aeroelectric book out of one of our moving boxes and I'll try to
read it with a cup of coffee in the morning.
I'm mostly interested in understanding charge or discharge rates. I can
build a reference load chart (by running on battery only during a test
session) to determine exactly what each piece of equipment pulls and how I
might be able to shed load if needed.
Phil
On Sat, Aug 30, 2014 at 8:04 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
Posted: Sat Aug 30, 2014 6:11 pm Post subject: Shunt - Location |
Knowing which piece draws X amps is a good exercise, but what do you do with the data? With modern equipment the load is comparatively small and with the transponder and strobes off a good battery should outlast your fuel supply.
Alternator states are typically good charge (depending on battery level) or no charge. A slipping belt will be in-between. Batteries are more insidious .... they fail slowly at first and then gather steam towards useless. A good battery health indicator is the battery voltage just before start ..... how much did it lose since you last flew? I have a desulfator trickle charger that I hook up after each flight so my 'settling time' is rather short.
IMHO, of course!
Linn
On 8/30/2014 9:42 PM, Phillip Perry wrote:
[quote] I dug my Aeroelectric book out of one of our moving boxes and I'll try to read it with a cup of coffee in the morning.
I'm mostly interested in understanding charge or discharge rates. I can build a reference load chart (by running on battery only during a test session) to determine exactly what each piece of equipment pulls and how I might be able to shed load if needed.
Phil
On Sat, Aug 30, 2014 at 8:04 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
Quote: | I'm not sure that's true and it's part of what I'm wrestling with..... This is a direct quote from the G3X installation manual and from this text, it leads me to believe that it could be placed anywhere in the #2 wire and it would read the charge or discharge rates of that battery. Am I missing something?
On Sat, Aug 30, 2014 at 7:13 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com) <mailto:kellym(at)aviating.com (kellym(at)aviating.com)>> wrote:
choice.
Phil
than a
positive
working well
Knowing
that's all.
if it
Jesse Saint
I-TEC, Inc.
<mailto:jesse(at)itecusa.org (jesse(at)itecusa.org) <mailto:jesse(at)itecusa.org (jesse(at)itecusa.org)>>
C: [url=tel:352-427-0285]352-427-0285[/url] <tel:[url=tel:352-427-0285]352-427-0285[/url]> <tel:[url=tel:352-427-0285]352-427-0285[/url]
<tel:[url=tel:352-427-0285]352-427-0285[/url]>>
O: [url=tel:352-465-4545]352-465-4545[/url] <tel:[url=tel:352-465-4545]352-465-4545[/url]> <tel:[url=tel:352-465-4545]352-465-4545[/url]
<tel:[url=tel:352-465-4545]352-465-4545[/url]>>
F: [url=tel:815-377-3694]815-377-3694[/url] <tel:[url=tel:815-377-3694]815-377-3694[/url]> <tel:[url=tel:815-377-3694]815-377-3694[/url]
<tel:[url=tel:815-377-3694]815-377-3694[/url]>>
<philperry9(at)gmail.com (philperry9(at)gmail.com) <mailto:philperry9(at)gmail.com (philperry9(at)gmail.com)>
seems like
the ALT).
the battery;
from the ALT
to the main buss.)
Battery can
them
I'm getting
option 3
of putting
G3X screen
and access it.
Phil
08/30/14 [b]
philperry9
Posted: Sat Aug 30, 2014 6:21 pm Post subject: Shunt - Location |
I think I just sorted it out in my head. I was thinking that the #8 B-Lead, #2 Battery, and #8 Buss feed wires would all bind at the battery-side post of the starter solenoid. This would mean I have a single feed to the 'real' buss bar.
I'm now 99% sure that's not the case. I need to look at it closer, but I believe I've got a connection for the B-Lead on one end of the buss and on the other end of the buss I have a battery connection. That makes perfect sense when someone says to put it "in the battery lead".
I won't be back at the hangar until Tuesday, but I'm pretty sure I just figured it out. Sometimes I'm dense!
Phil
On Sat, Aug 30, 2014 at 9:10 PM, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote] Knowing which piece draws X amps is a good exercise, but what do you do with the data? With modern equipment the load is comparatively small and with the transponder and strobes off a good battery should outlast your fuel supply.
IMHO, of course!
Linn
Quote: | I dug my Aeroelectric book out of one of our moving boxes and I'll try to read it with a cup of coffee in the morning.
Phil
choice.
Phil
than a
positive
working well
Knowing
that's all.
if it
Jesse Saint
I-TEC, Inc.
seems like
the ALT).
the battery;
from the ALT
to the main buss.)
Battery can
them
I'm getting
option 3
of putting
G3X screen
and access it.
Phil
08/30/14
Kellym
Posted: Sat Aug 30, 2014 7:40 pm Post subject: Shunt - Location |
Yes, that is what you want. One more failure state to an alternator that wasn't mentioned, is the failure of one or two diodes. That will result in an alternator that will produce 10-20 amps, but no more. You would see it as a small discharge on your battery, and not going to 25+ amps right after start as it should. (similar to loose and slipping belt results) Otherwise, you will have full alt output or no output in most cases.
On 8/30/2014 7:20 PM, Phillip Perry wrote:
Quote: | I think I just sorted it out in my head. I was thinking that the #8 B-Lead, #2 Battery, *and #8 Buss feed wires* would all bind at the battery-side post of the starter solenoid. This would mean I have a single feed to the 'real' buss bar.
| It also means you are are seeing the entire system except for the starter draw, and will know whether the battery is being charged or discharged.
Phil
Quote: | Knowing which piece draws X amps is a good exercise, but what do you do with the data? With modern equipment the load is comparatively small and with the transponder and strobes off a good battery should outlast your fuel supply.
IMHO, of course!
Linn
Phil
choice.
Phil
than a
positive
working well
Knowing
that's all.
if it
Jesse Saint
I-TEC, Inc.
seems like
the ALT).
the battery;
from the ALT
to the main buss.)
Battery can
them
I'm getting
option 3
of putting
G3X screen
and access it.
Phil
08/30/14
| [b]
KCHD |
rv10flyer
Posted: Sat Aug 30, 2014 8:32 pm Post subject: Re: Shunt - Location |
I have three hall effect current sensors on my GRT. Main Bat feed , Aux Bat feed and Alt feed. A toggle can be switched between the Bat and Alt sensors. Does Garmin not work with the hall effect type sensors?
_________________ Wayne G. |
philperry9
Posted: Sun Aug 31, 2014 3:49 am Post subject: Shunt - Location |
The toggle switch on a pair of hall effect sensors is a good idea
The Garmin does work with them but I already own a pair of shunts. And at this point in the project, I'll take advantage of the stuff I own and try to keep from spending any more money than I have to.
Phil
On Sat, Aug 30, 2014 at 11:32 PM, rv10flyer <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)> wrote:
[quote]--> RV10-List message posted by: "rv10flyer" <wayne.gillispie(at)gmail.com (wayne.gillispie(at)gmail.com)>
Wayne G.
http://forums.matronics.com/viewtopic.php?p=429669#429669
Kelly McMullen
Posted: Sun Aug 31, 2014 6:37 am Post subject: Shunt - Location |
So put one shunt on the alternator B+ line and one one the starter relay to buss line and you will know both what the battery is providing and what the alternator is providing.
On Sun, Aug 31, 2014 at 4:48 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
[quote] The toggle switch on a pair of hall effect sensors is a good idea
Phil
A&P/IA, EAA Tech Counselor
KCHD |
bill.peyton
Posted: Sun Aug 31, 2014 6:48 am Post subject: Re: Shunt - Location |
You are over thing it. The shunt should always be place on the output lead of the alternator. The aircraft does not run on the battery, it derives it's power from the alternator. The only time the battery is used in the aircraft, or an automobile for that manner, is when you start the engine, or if the alternator fails. The bus voltage can be used to trigger the g3x to provide you a warning and also a status if the alternator fails. I. Addition, the plane power alternators have a separate lead that you can hook up to an indicator light on the panel to indicate an alternator failure.
In summary, you should be monitoring the current being drawn from the alternator, and set up the G3x to alarm you during overcurrent and under current situations. You should also set up a voltage level alarm for over voltage and under voltage on both your primary and secondary battery. In addition, you should have a load shed plan in case of the alternator failure. Use this plane to de-power the high current unnecessary items on the bus.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
woxofswa
Posted: Sun Aug 31, 2014 11:00 am Post subject: Re: Shunt - Location |
Wiring the traditional way of consumptive drain on the battery still gives a lot of info options.
With everything running, the meter will still spike with new items energized as a back up indication that the wizzie is getting power.
You can also get the draw of individual items by checking them with the ALT off. That is nice to be able to check and note during construction or adding new items. (I used a ground power plug during construction).
Obviously that is usually done on the ground with the engine not running, but it doesn't have to be. I know there is controversy about turning the alt off with the engine running, but Socata used to have just such a check as part of the run up. If you need to know the total draw on the ALT, turning it off will tell you. (after batt has been start replenished).
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
