Recomanded radio for Yak 52
Goto page Previous  1, 2
jan.mevis(at)informavia.b
PostPosted: Thu Aug 28, 2014 10:35 pm    Post subject: Recomanded radio for Yak 52 Reply with quote
Try funkwerk-usa.com
Jan
On 28/08/14 21:28, "Roger Kemp" <f16viperdoc(at)me.com> wrote:
Will the Funkwerk interchange with the 2.5 in panel hole Becker is
occupying currently?
Doc
Sent from my iPad
> On Aug 28, 2014, at 2:06 PM, Hans Oortman <pa3arw(at)ziggo.nl> wrote:
> Jan, Doc,
> As you know we have tested a Becker radio (the 25kHz spacing one) in the
> workshop of my company. The Becker is simply not designed for such a
> noisy(from electromagnetic field point of view) as the Yak52. It's been
> designed for glider operation. It took me all kinds of tricks to get it
>free
> of noise, I finally achieved it though but I am still going to change
>to a
> new Funkwerk because we have to have 8.33kHz spacing anyway as of the
>first
> of jan 2017.
> I'd change to a Funkwerk and have the wiring completely redone with
>proper
> screening, common earth etc.
> Hans O.
> PH-YAK
> Op 28-08-14 19:49, Jan Mevis <jan.mevis(at)informavia.be> schreef:
>> Well, I also had more noise when I installed the Taylor plug wires, but
>> then I still had the original Russian radio (a Briz).
>> Uninstalling the 8mm cables was not an option, so I replaced the Briz
>>by a
>> Becker.
>> I took the time to replace ALL the radio wiring (audio, mike,
>> push-to-talk, antenna, power supply) and also paid attention to have a
>> good, common earth connection.
>> I'm far from a specialist in avionics (Mark is the real specialist).
>>So I
>> suppose I was lucky.
>> Afterwards I replaced the Becker by a Funkwerk ATR833 because I wanted
>>an
>> 8.33 kHz separation and the Funkwerk was a good buy for the money.
>> Then I installed my "old" Becker + a PM1200 on our Yak 52.
>> There too I replaced ALL the audio wiring and made sure to have one
>> single, good earthing connection point.
>> I don't claim that this is the better way to do it (Mark?) but it
>>worked
>> for me.
>> Our Yak 52 also has Dennis' plug wires.
>> The installation on my Yak 50 (including my Garrecht transponder) is
>> checked and approved by a specialized EASA 145 company (imposed by the
>> French CAA).
>> BR,
>> Jan
>>> On 28/08/14 19:29, "Roger Kemp" <f16viperdoc(at)me.com> wrote:
>>> Jan, I did get the wiring harness with the radio. Using A/C grade RG
>>>56
>>> cable I believe. Forget who made the antenna but nothing had been a
>>> problem until I went to Taylor plug wires then all hell has gradually
>>> evolved.
>>> Now this noise is not throttle setting related but with the engine
>>>turned
>>> off it receives quit clearly? I know, kill the engine to receive! ;^0
>>> Doc
>>> Sent from my iPad
>>>> On Aug 28, 2014, at 12:43 AM, Jan Mevis <jan.mevis(at)informavia.be>
>>>>wrote:
>>>> I am perfectly satisfied with the Funkwerk, it is very good.
>>>> I'm also co-owner of a Yak 52. In the Yak 52 I installed the small
>>>> Becker
>>>> with the PM1200 for intercom.
>>>> This also works flawlessly.
>>>> But I also replaced the complete cabling (audio cables, push-to-talk
>>>> cables, antenna cables).
>>>> If you have noise on the Becker, then you should look at the cabling.
>>>> Also: I connected all the mass cables on one point for a common mass
>>>>and
>>>> made also sure that this mass point is well connected to the battery.
>>>> Verifying and replacing the cables is quite a job of course, but not
>>>>so
>>>> difficult.
>>>> You should check the cables before replacing the Becker.
>>>> BR,
>>>> Jan
>>>> PS: consider buying the wiring harness offered as an option with the
>>>> radio
>>>> or the PM 1200. It's generally of a very good quality.
>>>>> Hi Jan,
>>>>> Yes I to go for the 8,33 spacing now. Looking on the Garmin 225a or
>>>>>b.
>>>>> Problem is the dimension on depth.
>>>>> Are you satisfied with the Funkwerk? Problem now with the Becker is
>>>>> that
>>>>> it pick up to mutch noise from the Aircraft when reciving.
>>>>> BR
>>>>> Havard
>>>>> Sendt fra min iPhone 4S
>>>>>> Den 27. aug. 2014 kl. 20:13 skrev Jan Mevis
>>>>>><jan.mevis(at)informavia.be>:
>>>>>> I'd go for an 8.33 kHz separation.
>>>>>> Just a matter of time before it will be imposed in Europe.
>>>>>> I have a German Filser Funkwerk.
>>>>>> BR,
>>>>>> Jan
>>>>>>> On 27/08/14 19:57, "Håvard Dale" <havard.dale(at)yaknorway.com>
>>>>>>> Hi all,
>>>>>>> Would like to get some recomandations on which radio to instal in
>>>>>>>my
>>>>>>> 52.
>>>>>>> Now have an becker but it will be replaced.
>>>>>>> Have a new in box PM1200 I/C I would use with a new radio.
>>>>>>> Thanks,
>>>>>>> Kind regards
>>>>>>> Havard Dale
>>>>>>> Norway
>>>>>>> Sendt fra min iPad
>>>>>>>> Den 27. aug. 2014 kl. 09:02 skrev Yak-List Digest Server
>>>>>>>> <yak-list(at)matronics.com>:
>>>>>>>> Online Versions of Today's List Digest Archive
>>>>>>>> Today's complete Yak-List Digest can also be found in either of
>>>>>>>>the
>>>>>>>> two Web Links listed below. The .html file includes the Digest
>>>>>>>> formatted
>>>>>>>> in HTML for viewing with a web browser and features Hyperlinked
>>>>>>>> Indexes
>>>>>>>> and Message Navigation. The .txt file includes the plain ASCII
>>>>>>>> version
>>>>>>>> of the Yak-List Digest and can be viewed with a generic text
>>>>>>>>editor
>>>>>>>> such as Notepad or with a web browser.
>>>>>>>> HTML Version:
>>>>>>>>http://www.matronics.com/digest/digestview.php?Style=82701&View=ht
>>>>>>>>ml&
>>>>>>>> Ch
>>>>>>>> ap
>>>>>>>> ter 14-08-26&Archive=Yak
>>>>>>>> Text Version:
>>>>>>>>http://www.matronics.com/digest/digestview.php?Style=82701&View=tx
>>>>>>>>t&C
>>>>>>>> ha
>>>>>>>> pt
>>>>>>>> EMail Version of Today's List Digest Archive
>>>>>>>> Yak-List Digest Archive
>>>>>>>> Total Messages Posted Tue 08/26/14: 1
>>>>>>>> Today's Message Index:
>>>>>>>> 1. 08:21 AM - Re: Air system Flush (Todd McCutchan)
Page 2 of 2
