uuccio(at)gmail.com Guest
Posted: Fri Aug 22, 2014 8:39 am Post subject: intercom noise (was radio noise) |
When my (Rotax 912) engine goes over 3800 RPM it breaks the squelch on the
radio, the radio goes in RX mode and I hear a bunch of white noise, which
for all intents and purposes makes receiving transmissions very difficult.
I have been through several iterations of this problem (see previous posts,
involving a noisy Autopilot on the 130Mhz which is our local frequency) but
yesterday I realized that if I turn the intercom off the problem disappears
(the radio doesn't go into RX mode).
So it appears that there is some kind of noise source which makes its way
into the Intercom (it's a GMA 240). What steps can I take to get rid of
this problem? I have already shielded the magneto wires.
sacha
Posted: Fri Aug 22, 2014 8:53 am Post subject: intercom noise (was radio noise) |
When I say "white noise" I mean interference noise that seems related to
engine RPM.
saylor.dave(at)gmail.com Guest
Posted: Fri Aug 22, 2014 9:08 am Post subject: intercom noise (was radio noise) |
I'm not associated with any avionics manufacturer, but I know from experience with several Garmin audio panels that they just don't reject noise as well as PS Eng audio panels. In several cases, changing to a PS got rid of whines, buzzes, static, etc. that extra shielding and ground loop witch hunts just didn't fix. What you're hearing may just not be resolvable with a Garmin. I really like a lot of their other products, but the audio panels aren't as good.
--Dave
On Fri, Aug 22, 2014 at 9:37 AM, Sacha <uuccio(at)gmail.com (uuccio(at)gmail.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Sacha" <uuccio(at)gmail.com (uuccio(at)gmail.com)>
sacha
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
FORUMS -
b Site -
-Matt Dralle, List Admin.
user9253
Joined: 28 Mar 2008 Posts: 1975 Location: Riley TWP Michigan
Posted: Sat Aug 23, 2014 4:19 am Post subject: Re: intercom noise (was radio noise) |
Breaking the radio squelch would not make it more difficult to hear incoming radio transmissions. The symptoms that you describe are from breaking the intercom squelch. The white noise is cockpit noise. As the engine RPM increases, the cockpit noise increases until it reaches a point where the intercom squelch is broken. Try adjusting the intercom squelch at cruise RPM using the large knobs, left knob for pilot and right knob for copilot.
Joe
_________________ Joe Gores |
Posted: Sat Aug 23, 2014 5:55 am Post subject: intercom noise (was radio noise) |
Hi Joe,
Thanks for your suggestion. What you say makes perfect sense. I tried
turning up the pilot intercom squelch before but I may have inadvertently
left the copilot squelch low and the copilot headset connected. I'll check
that next time I'm in the plane.
Sacha
Posted: Thu Aug 28, 2014 12:56 pm Post subject: intercom noise (was radio noise) |
Joe,
I can confirm that you hit the nail on the head. Yesterday and today I
unplugged the copilot headset and the intercom squelch problem went away.
Thank you again!
Sacha
user9253
Posted: Thu Aug 28, 2014 2:10 pm Post subject: Re: intercom noise (was radio noise) |
You are welcome, Sacha.
Joe
