tonyrenshaw268(at)gmail.c Guest
Posted: Wed Jul 30, 2014 8:10 pm Post subject: Shielded Strobe Light Query |
Gidday,
I am using AveoflashLP Ultra Aurora Nav/Strobe lights, that have their flasher units within the lights. There is 4 cables coming from each strobe, and to get quad core shielded is very hard, and expensive. The suppliers don’t mention in their installation documentation that you need shielded wiring, and yet when pushed, they do. I am wondering if I just shield the positive cable, or whether I need to also shield the negative/earth, and the “phase wire” which goes to each strobe to keep them synchronised. I’d be interested on what anyone thinks, and in fact whether shielding them all together could introduce a specific problem rather than just having one or two of the wires shielded.
Tony Renshaw
Sydney Aussie
richard collings
Joined: 08 Jul 2011 Posts: 73 Location: warwickshire england
Posted: Thu Jul 31, 2014 1:28 am Post subject: Shielded Strobe Light Query |
Hi Tony
Just a thought, but if your position lights are LED, ie. very low current
load, then you could use radio mic cable which you will have to get anyway
to wire in your jack plugs.
Changing the subject, I am coming down to Sydney in January next year and
would like to meet you and look at your Europa, perhaps we could arrange
something nearer the time.
Richard
Posted: Thu Jul 31, 2014 3:51 am Post subject: Shielded Strobe Light Query |
Tony, Not clever enough to give you a definitive answer,
but strongly suspect you should have all wires in a single
sheath. You can incidentally buy nice cable sheath in
various diameters which you can apply easily
retrospectively over a bundle of wires. Can't remember
where I got mine from now, but I found them by googling
wire sheathing or something similar.
Regards, David Joyce, G-XSDJ
On Thu, 31 Jul 2014 10:27:43 +0100
Hi Tony
very low current load, then you could use radio mic cable
which you will have to get anyway to wire in your jack
plugs.
January next year and would like to meet you and look at
your Europa, perhaps we could arrange something nearer
the time.
Richard
Posted: Thu Jul 31, 2014 4:28 am Post subject: Shielded Strobe Light Query |
Hi David,
Thanks for that advice. I didn't know about after market shielding, nor the single shielding. I suppose it makes sense, otherwise why have multi core with single shielding. Amazing how a little cross pollenisation of ideas can create positive synergy. Appreciated.
Tony Renshaw
P.S. Quad Core shielded is bloody expensive. Oh well, only have to buy it once. (That's my wife excuse).
[quote] On 31 Jul 2014, at 9:50 pm, "David Joyce" <davidjoyce(at)doctors.org.uk> wrote:
Tony, Not clever enough to give you a definitive answer, but strongly suspect you should have all wires in a single sheath. You can incidentally buy nice cable sheath in various diameters which you can apply easily retrospectively over a bundle of wires. Can't remember where I got mine from now, but I found them by googling wire sheathing or something similar.
> Hi Tony
> Just a thought, but if your position lights are LED, ie. very low current load, then you could use radio mic cable which you will have to get anyway to wire in your jack plugs.
> Changing the subject, I am coming down to Sydney in January next year and would like to meet you and look at your Europa, perhaps we could arrange something nearer the time.
> Regards
> Richard
Tony & David
My guess is that because you want to keep RF (caused by square waves in the strobe),
you should sheath the signal wires only.
Fergus Kyle would know, maybe Bud does too
Graham
Sent: Thursday, 31 July 2014, 12:50
Subject: Re: Shielded Strobe Light Query
--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
"Richard Collings" <rcollings(at)talktalk.net (rcollings(at)talktalk.net)> wrote:
[quote] --> Europa-List message posted by: "Richard Collings" <rcollings(at)talktalk.net (rcollings(at)talktalk.net)>
Hi Tony
Richard
h&jeuropa
Posted: Thu Jul 31, 2014 6:19 am Post subject: Re: Shielded Strobe Light Query |
Tony,
Here is a link to AeroLED install instructions for a similar light which incorporates position light and strobe. Just follow the AeroLED instructions. You will only need 3 conductor shielded wire. Be sure you connect the shield, ground wire and a physical connection to the LED assembly all together at the wingtip.
http://www.aeroleds.com/wp-content/uploads/2013/05/Pulsar-Installation-Experimental.pdf
We are using AeroLED and have no problem with noise or interference.
Jim & Heather
pestar
Joined: 11 Apr 2007 Posts: 61 Location: Auckland, New Zealand
Posted: Thu Jul 31, 2014 2:48 pm Post subject: Shielded Strobe Light Query |
Hi Peter,
Thanks for that, and I'll call them soon. What's a "Golden Solder" company?
Tony R
Quote: | On 1 Aug 2014, at 8:32 am, "pestar" <peter(at)reivernet.com> wrote:
Tony
You can get the necessary cabling from EDMO who are aviation distributors based out of Melbourne. I installed AeroLeds in my MCR-4S as they required the same type of 4 +1 shielded cabling. At that time EDMO had an office at Ardmore in New Zealand (walking distance from my hangar) so I sourced it from them at cost significantly less than paying retail from any of the "Golden Solder" companies.
Cheers Peter
Peter Armstrong
DynAero MCR-4S (Do not shoot me ).
http://forums.matronics.com/viewtopic.php?p=427650#427650
budyerly(at)msn.com Guest
Posted: Thu Jul 31, 2014 2:55 pm Post subject: Shielded Strobe Light Query |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Tony,
Originally Aveo USA dealers mentioned that just a simple 18 gauge wire unshielded was enough for a simple strobe, nav, steady flashing unit needed. However, whenever you have a pulsing electrical device noise is a real concern. I would prefer to use a shielded wire on the strobe side of the wire. I'm sure you have downloaded as much as you can on the installation, but do look at some complaints about other strobe type led operations on emergency vehicles etc and radio interference.
We try to do our due diligence but I prefer to be on the cautious side. Here is a comment from http://www.emcrules.com/2011/07/radio-interference-from-led-lighting.html
they are engineers in the lighting industry.
I quote:
However, although today’s LEDs are capable of long life, and delivering high light output levels with very little power consumption, most need to be paired with a drive circuit to provide constant current sourcing to operate in our homes and offices, and that’s where the problem comes in. These switching drive circuits operate at increasingly higher frequencies, and in order to maintain the highest efficiency, and highest LED longevity possible, they also need to maintain very high slew rates. These factors contribute to the overall unwanted emissions from each individual lighting element, increasing the Electromagnetic background noise. End quote.
This noise is in the VHF range so I have probably overcautiously decided to install shielded wire. The Aveo circuitry is in the light itself and a long way away from your radio gear, but noise is unwanted in a system. Even the flap motor, so twisted pairs at a minimum should be used. See the guys on the wiring installation attached. I talked to them. I tested the lights near my handheld radio and they are clean until a foot or so away, and when paired together in sync make a slight pulsed hiss. Now if you run the blue wire to put the strobes in sync that is a long pulsing wire. Probably should shield that one at a minimum. If you can shield both pulsed lights and tie the shield to your main ground bus and leave it open at the light it should work.
Some RV guys are using non shielded wire and have no complaints. Some Zenith guys are having issues. But they both use the airframe as a ground. We use a separate ground wire which if properly done helps with noise.
Bud Yerly
Description: |
 Download |
Filename: |
aveo-serieswiringdiagram.pdf |
Filesize: |
130.11 KB |
Downloaded: |
385 Time(s) |
Posted: Thu Jul 31, 2014 8:49 pm Post subject: Shielded Strobe Light Query |
Hi Jim and Heather,
Tried to send private message but email address below bounces. Can you give it to me off list please?
Rgds
Tony R.
