saylor.dave(at)gmail.com Guest
Posted: Thu Jul 31, 2014 5:11 pm Post subject: Stuck in Cheyenne |
Guys, a friend of mine is stranded in Cheyenne with his RV-10 due to a flat tire. He's having trouble finding one locally. If anyone can offer him a 15x600-6 sooner than Saturday, he'd appreciate it very much. Please give me a call and I'll pass on his contact info.
--Dave Saylor
Posted: Thu Jul 31, 2014 5:25 pm Post subject: Stuck in Cheyenne |
Dave Saylor 831-750-0284
On Thu, Jul 31, 2014 at 6:10 PM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
[quote]Guys, a friend of mine is stranded in Cheyenne with his RV-10 due to a flat tire. He's having trouble finding one locally. If anyone can offer him a 15x600-6 sooner than Saturday, he'd appreciate it very much. Please give me a call and I'll pass on his contact info.
--Dave Saylor
tp://forums.matronics.com
| [b]
Kelly McMullen
Posted: Thu Jul 31, 2014 6:48 pm Post subject: Stuck in Cheyenne |
Every FBO should have 6:00 X 6 6ply on hand. Mount a pair of those as temporary substitute to get home.
--Dave Saylor
| [b]
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Thu Jul 31, 2014 6:49 pm Post subject: Stuck in Cheyenne |
I happen to know from experience that a flat-spotted 600x6 works great on a -10 with the wheel pant removed. He may want to remove both wheel pants for any flying. No use being stranded when there are likely some old-yet-useable 600x6's up for grabs in Cheyenne.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
Sent from my iPad
On Jul 31, 2014, at 9:10 PM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
--Dave Saylor
List"">http://www.matronics.com/Navigator?RV10-List
Posted: Fri Aug 01, 2014 6:28 am Post subject: Stuck in Cheyenne |
Kelly and Jesse, I'll suggest 600x6s. Do you know off-hand what the difference between the two sizes would be? Shape? Height?
He's got a long way to go so he might want to keep all the fairings. His call.
--Dave
On Thu, Jul 31, 2014 at 7:48 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]Every FBO should have 6:00 X 6 6ply on hand. Mount a pair of those as temporary substitute to get home.
| Quote: | Guys, a friend of mine is stranded in Cheyenne with his RV-10 due to a flat tire. He's having trouble finding one locally. If anyone can offer him a 15x600-6 sooner than Saturday, he'd appreciate it very much. Please give me a call and I'll pass on his contact info.
--Dave Saylor
| [b]
Posted: Fri Aug 01, 2014 7:11 am Post subject: Stuck in Cheyenne |
They are a little bit taller, but I don't know how much. It is possible that they will fit in the fairings, but I doubt it, without some modification. The 5 knots or so lost without the main wheel pants on shouldn't be a show stopper.
Actually, is the tire bad or just the tube? A 600x6 tube should work fine in the existing tire. Then he could keep his fairings on.
Jesse Saint
C: 352-427-0285
F: 815-377-3694
On Aug 1, 2014, at 10:27 AM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
[quote]Kelly and Jesse, I'll suggest 600x6s. Do you know off-hand what the difference between the two sizes would be? Shape? Height?
--Dave
| Quote: | Every FBO should have 6:00 X 6 6ply on hand. Mount a pair of those as temporary substitute to get home.
| [b]
Posted: Fri Aug 01, 2014 9:23 am Post subject: Stuck in Cheyenne |
Thanks Jesse. I did some digging around and found a Goodyear document that says, at least for Goodyear tires, that 600-6s are about 2" larger in diameter. So yeah, I wouldn't think the fairings would go back on.
The 600-6s are also a few pounds heavier. That probably drove Vans' selection, but it shouldn't keep someone from using them if necessary.
--Dave
On Fri, Aug 1, 2014 at 8:10 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote] They are a little bit taller, but I don't know how much. It is possible that they will fit in the fairings, but I doubt it, without some modification. The 5 knots or so lost without the main wheel pants on shouldn't be a show stopper.
Jesse Saint
C: [url=tel:352-427-0285]352-427-0285[/url]
F: [url=tel:815-377-3694]815-377-3694[/url]
| Quote: | Kelly and Jesse, I'll suggest 600x6s. Do you know off-hand what the difference between the two sizes would be? Shape? Height?
--Dave
flying-nut(at)cfl.rr.com Guest
Posted: Fri Aug 01, 2014 11:16 am Post subject: Stuck in Cheyenne |
On 8/1/2014 1:22 PM, David Saylor wrote:
| Quote: | Thanks Jesse. I did some digging around and found a Goodyear document
back on.
--Dave
OK, would anyone that has not mounted the pants consider mounting them
over 600-6s????? They'd only be 1" higher.
Linn
Lew Gallagher
Posted: Fri Aug 01, 2014 12:43 pm Post subject: Stuck in Cheyenne |
Hey Linn,
You might want to consider clearance on the lower end of the pants ... the
higher you raise them to get top tire clearance, the more you have
interference with bleed valve/brake bolt clearance on the bottom end.
Later, - Lew
Linn
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
cjay
Posted: Sat Aug 09, 2014 5:13 pm Post subject: Re: Stuck in Cheyenne |
I fly with600-6s, wanted a little better performance on unimproved airstrips. Definitely had to mod the wheel pants though.
Another benefit was the 30 mph shimmy went away.
cjay
