dav1111(at)cox.net Guest
Posted: Fri Jun 23, 2006 1:04 pm Post subject: RV 10 Motor Mount Ground |
I used the top left motor mount bolt as the ground on the firewall to the engine.
Russ Daves
N710RV - Due to fly within the month.
carl.froehlich(at)cox.net Guest
Posted: Fri Jun 23, 2006 4:35 pm Post subject: RV 10 Motor Mount Ground |
The ground lug on the starter. This is the highest current draw - thus gets the best ground connection. Use the same wire size that you run +12V to the starter. Terminate on a common ground lug on the firewall, grounding the battery(s) on the cabin side.
Carl Froehlich
RV-8A (260 hrs)
RV-10 (tail cone)
[quote] --
