		jeff(at)rmmm.net Guest
				 Posted: Sun Jan 15, 2006 4:32 pm    Post subject: Tri-Gear Tire & Tube life |
				Now that we're on PSI for Tires. What air pressure are others running
 in the tri-gear tires for best life?
 Jeff
 A258
 Awaiting Inspection.
 On Jan 15, 2006, at 4:25 PM, Paul McAllister wrote:
  <paul.mcallister(at)qia.net>
  Hi Jim,
  I'm using a MCleary Airtrack 7/600, but inflated at 18 PSI.  My first
  inner
  tube failure was at around 220 hours.  The low pressure running caused
  chafing of the tube side wall to the point where it rubbed through.
  At that
  time I used the same tire and just put a new tube in it.
  The second failure was at 370 hours for the same reason however I
  noticed
  that although I had tread left the side walls of the tire were very
  weak
  when compared to a new tire.  For the same pressure it looked much
  "flatter".  I am assuming that internal structure of the tire was
  fatigued
  do to running it flat.
  What I am thinking of doing is to replace the tire every 200 hours and
  the
  tubes every 100 hours.
  Regards,  Paul
		flyinggpa(at)comcast.net Guest
				 Posted: Sun Jan 15, 2006 5:36 pm    Post subject: Tri-Gear Tire & Tube life |
				All
 I wish I knew !  They wear out very fast.  I am on my second set.
 Cliff Shaw
 1041 Euclid ave.
 Edmonds, WA 98020
 425 776 5555
 http://www.europaowners.org/WileE
		topglock(at)cox.net Guest
				 Posted: Sun Jan 15, 2006 6:14 pm    Post subject: Tri-Gear Tire & Tube life |
				Jeff,
 I run 30psi all the way around.  No problems, other than the typical
 outside tire wear, due to the camber of the mains.  I reversed the main
 tires on the wheels at the 100 hour check and hope to get another 100
 out of them.  Now that I'm based on grass, maybe they'll last a bit
 longer.  Think I'll try the Michelins, next time...
 Get Gold Rush in the air, so you can make our May fly-in...
 Jeff - N55XS
 133 hours
 JEFF ROBERTS wrote:
  Jeff
  A258
 >Hi Jim,
 >inner
 >At that
 >noticed
 >weak
 >fatigued
 >the
 >Regards,  Paul
