bakerocb
Posted: Thu Jun 12, 2014 9:21 am Post subject: Direction Indicator Needs (Summary) |
6/12/2014
Hello Aeroelectric and Avionics Listers, On this subject back on 6/10/2014 I wrote:
“I know that there are many technically smart people on these lists and I would like to enlist your assistance.
Picture this situation: There are hundreds (maybe thousands) of EAB (Experimental Amateur Built) IFR capable aircraft flying around with vacuum driven mechanical spinning mass gyroscopic attitude and directional indicators. A large percentage of these builders and pilots would like to (or need to) replace those indicators with something electronic (other than expensive electrical motor driven mechanical spinning mass gyroscopic) in nature and remove the entire vacuum system from their EAB.”
and
“How about it experts (and entrepreneurs) are my desires hopeless and unrealistic?”
I want to now post what I have learned / concluded and express my gratitude to the several people who responded:
1) The two best choices for replacing my previous vacuum driven attitude gyro:
a) The Sandia SAI 340 Quattro. See here:
http://www.sandia.aero/?q=node/80
b) The Dynon EFIS-D6. See here:
http://www.dynonavionics.com/docs/D6_intro.html
2) The best choice for replacing my previous vacuum driven directional gyro:
The MGL Avionics Velocity Singles Horizon / Compass. See here:
http://www.mglavionics.com/html/velocity_singles.html
Many thanks again for all that posted help and I would be willing to discuss my choices if desired.
OC
'O C' Baker says "The best investment you can make is the effort to gather and understand information."
kleh(at)dialupatcost.ca Guest
Posted: Thu Jun 12, 2014 10:51 am Post subject: Direction Indicator Needs (Summary) |
There is also the Trutrak gemini ADI series for a drop in 3" replacement
with gps track (not magnetic heading). These are rate sensing gyros so
they are a bit different than spinning gyro's. If you hold a pitch
attitude and there is an altitude change they function well. However
with no corresponding altitude change they gradually return to
displaying nose level. Not really a problem but if I decelerate very
very slowly I can get the nose quite high while the display still reads
a level flight attitude. Accordingly the gemini flashes an airpseed
warning when the speed gets low.
Similarly if you maintain a turn for a long time, the display will
gradually indicate wings level unless it has heading or track
information such as from a gps.
I would not expect the $500. MGL magnetic sensor and display to be a
satisfactory replacement for a directional gyro. I've never flown it but
the description says it won't be accurate during any turn unless you
upgrade to the substantially more expensive AHRS. I was surprised to
learn that in my location at 45*N lattitude, the magnetic vector is
tilted about 70 degrees below the horizon which makes attitude info
pretty much essential to simulate a gyro compass.
While it's as heavy as the removed vacuum pump, I've been running a
$25. junk table 28volt T&B for quite some time powered with a $5. dc-dc
converter on my 12 volt electrical system. Nothing like the noise from a
spinning gyro to remind me that the master is still on.
Ken
On 12/06/2014 1:21 PM, Owen Baker wrote:
| Quote: | 6/12/2014
from their EAB.”
and
unrealistic?”
gyro:
OC
bakerocb
Posted: Fri Jun 13, 2014 6:04 am Post subject: Direction Indicator Needs (Summary) |
6/13/2015
Hello Ken, Thanks for your posting. You wrote:
1) “There is also the Trutrak gemini ADI series for a drop in 3" replacement
with gps track (not magnetic heading).”
I do not think that the units that provide only GPS track information, but
not stabilized magnetic heading information, meet the intended requirements
of 14 CFR 91.205 (d) (9) “Gyroscopic direction indicator (directional gyro
or equivalent)" for replacing my vacuum driven directional gyro.
A case in point: Suppose that ATC tells the pilot to “Fly heading XXX”. I
don’t think that flying some very similar track instead will necessarily
result in immediate danger or a flight violation (if the ATC controller is
not happy with the movement of your aircraft he will most likely just issue
you a new heading to fly), but I don’t think that flying a track instead of
a heading is what a conscientious pilot would want to do.
2) “I would not expect the $500. MGL magnetic sensor and display to be a
upgrade to the substantially more expensive AHRS.”
My comments:
a) You write: “.... the description says it won't be accurate during any
turn unless you
I can not find that information on the MGL web site. Can you please help me
find it?
b) You write: “.... the description says it won't be accurate during any
turn unless you
I can not find any information on the MGL web site that states or implies
that there is any improvement or relationship between a lone SP-6 Sensor,
Tilt-compensated magnetic compass and the display of its heading information
and the heading information displayed from a lone SP-7 Sensor
Attitude indication and turn/bank indication.
c) Here is an extract from the MGL web site:
"Heading stability issues: You may find short term fluctuations of the
heading occurring. These tend to be very small and are typically less than
one
degree. This could still cause the heading to fluctuate occasionally by a
single degree. These fluctuations occur naturally
in the earth’s magnetic field and can also be caused by nearby electrical
equipment such as radios, lamps, electronic
instrumentation or computers, even the ignition systems of engines. The AV-2
is specifically designed for fast response
and thus may show residual fluctuations of the magnetic field that are
impossible to filter out without causing delays in the
update of the heading information."
I can understand that there exists different levels of heading stability and
instantaneous accuracy between the magnetic wet compass envisioned by 14 CFR
91.205 (b) (3) for VFR flight and a stabilized magnetic device that would
meet 14 CFR 91.205 (d) (9) for IFR flight to perfection so it may come down
to which device will meet both the intention of 14 CFR 91.205 (d) (9), but
not to perfection, and the individual pilot's needs.
d) You write: "I was surprised to learn that in my location at 45*N
lattitude, the magnetic vector is tilted about 70 degrees below the horizon
which makes attitude info pretty much essential to simulate a gyro compass."
Understand. How does one determine whether or not some stabilized magnetic
heading indication device indeed has attitude information incorporated at
all into providing more accurate and instantaneous magnetic heading
indication and to the level of that incorporation between the zero
stabilization of a wet compass and perfection?
3) "Nothing like the noise from a spinning gyro to remind me that the master
is still on."
Any time my master switch is on and the alternator is not putting out the
minimum acceptable voltage (such as after alternator failure or engine shut
down) the B&C voltage regulator in my system is flashing a light on my
instrument panel. See here:
http://www.bandc.biz/alternatorcontrollerregulator14vhomebuilt.aspx
Different strokes for different folks. Thanks again for your input.
OC
Time: 11:51:37 AM PST US
Subject: Re: Direction Indicator Needs (Summary)
Ken
Posted: Fri Jun 13, 2014 1:49 pm Post subject: Direction Indicator Needs (Summary) |
Hi Owen
I agree that gps track does not equate to a gyro compass.
If you look in the manual
http://www.mglavionics.com/AV2.pdf
on page 10 you will see the definitions of the 2-D, 3D-A, and 3D-G
choices or operating modes.
The disadvantages column says "Cannot correctly compensate for tilt
during any form of turn due to centrifugal forces acting on the
accelerometers" That is for the 3D-A mode which is what you get with the
SP6 as far as I can tell.
The disadvantage column for the 3D-G (the best mode of operation with a
full AHRS) says "Can show very large errors if the horizon information
is invalid which could have a number of causes such as exceeding
operational limitations of the horizon system." I interpret this to mean
that you are back to the 3D-A mode if the attitude info is not available.
This is the same results I found in my little experiments with a 3D
magnetic sensor. The results were only useable when flying straight and
level. I'd expect much better results near the equator of course. Again
I have no experience with the MGL products but lacking actual
performance reports, I discounted purchasing the stand alone $500.
magnetic heading system for these reasons.
Ken
On 13/06/2014 10:03 AM, Owen Baker wrote:
6/13/2015
replacement
but not stabilized magnetic heading information, meet the intended
requirements of 14 CFR 91.205 (d) (9) “Gyroscopic direction indicator
(directional gyro or equivalent)" for replacing my vacuum driven
directional gyro.
I don’t think that flying some very similar track instead will
necessarily result in immediate danger or a flight violation (if the ATC
controller is not happy with the movement of your aircraft he will most
likely just issue you a new heading to fly), but I don’t think that
flying a track instead of a heading is what a conscientious pilot would
want to do.
My comments:
turn unless you
me find it?
turn unless you
implies that there is any improvement or relationship between a lone
SP-6 Sensor,
information and the heading information displayed from a lone SP-7 Sensor
than one
a single degree. These fluctuations occur naturally
electrical equipment such as radios, lamps, electronic
AV-2 is specifically designed for fast response
and instantaneous accuracy between the magnetic wet compass envisioned
by 14 CFR 91.205 (b) (3) for VFR flight and a stabilized magnetic device
that would meet 14 CFR 91.205 (d) (9) for IFR flight to perfection so it
may come down to which device will meet both the intention of 14 CFR
91.205 (d) (9), but not to perfection, and the individual pilot's needs.
horizon which makes attitude info pretty much essential to simulate a
gyro compass."
magnetic heading indication device indeed has attitude information
incorporated at all into providing more accurate and instantaneous
magnetic heading indication and to the level of that incorporation
between the zero stabilization of a wet compass and perfection?
master is still on."
the minimum acceptable voltage (such as after alternator failure or
engine shut down) the B&C voltage regulator in my system is flashing a
light on my instrument panel. See here:
OC
bakerocb
Posted: Sat Jun 14, 2014 4:58 am Post subject: Direction Indicator Needs (Summary) |
6/14/2014
Hello Ken, Thanks for your response.
1) I had written: “I can not find that information on the MGL web site. Can you please help me find it?”
And that is exactly what you did when you wrote:
2) “If you look in the manual http://www.mglavionics.com/AV2.pdf
on page 10 you will see the definitions of the 2-D, 3D-A, and 3D-G choices or operating modes.”
and
”I discounted purchasing the stand alone $500. magnetic heading system for these reasons.”
3) I agree completely with your analysis and greatly appreciate your input.
If I want the degree of stabilization that I interpret that 14 CFR 91.205 (d) (9) “Gyroscopic direction indicator
(directional gyro or equivalent)" intends then I must purchase:
a) The AV-2 AHRS Display (VELOCITY Series),
b) Both the SP-6 and SP-7 Sensors (Full AHRS),
c) And, if I intend to mount the two sensors in the same location, an SP-2 / SP-4 Connector.
d) For a total cost of USD $1305 plus shipping.
This increased cost over my earlier posted solution of using just the display and the SP-6 sensor causes me to reconsider the potential solutions to my problem, but I can not yet rule out the MGL solution because of the additional expense. (An addict will go to some extreme lengths to feed his addiction.)
Thanks again for your inputs and I continue to welcome any inputs that others may have.
OC
and understand information." ============================
Time: 02:49:26 PM PST US
Hi Owen
Ken
