flysrv10(at)gmail.com Guest
Posted: Fri May 16, 2014 3:24 am Post subject: aerosport rudder trim |
Hello List,
Anyone has installed Aerosport's rudder trim kit?
Need a picture of the rudder arm angle in relation to horizontal. It seems that in order for the spring to clear the sub panels, the arms have to installed about 25 deg from horizontal and it seems too flat of an angle to me.
His website picture clips the rudder arms.
Thank you.
Rob Kermanj
aerosport1
Posted: Fri May 16, 2014 7:23 am Post subject: aerosport rudder trim |
Rob
If you have the standard vans panel and depending on where you mount the unit you could have a interference with the sub panel.
You can angle the arms if needed a little. The other option is to lower the
Spring holes on the arms
Geoff Combs
Aerosport products
Sent from my iPhoneGeoff Combs
Aerosport Modeling & Design
On May 16, 2014, at 6:23 AM, Rob Kermanj <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
[quote]Hello List,
Thank you.
Rob Kermanj
List"">http://www.matronics.com/Navigator?RV10-List
//forums.matronics.com
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
