RV-10 Air Oil Separator Installation
rv10free2fly(at)yahoo.com
PostPosted: Sat May 03, 2014 1:51 pm    Post subject: RV-10 Air Oil Separator Installation Reply with quote
Could other builders please indicate if you've gone to the effort of installing an air/oil separator on your IO-540 engines?
If so what is the recommended type and location of same in the engine compartment please?
Any pictures of installations would be greatly appreciated too please.
Warm regards and wishing you all safe skies.
Patrick Pulis
Adelaide, South Australia
carl.froehlich(at)verizon
PostPosted: Sat May 03, 2014 3:09 pm    Post subject: RV-10 Air Oil Separator Installation Reply with quote
This is what I'm using. It works. I collect the oil - not return it to the engine. I empty out a couple of ounces each oil change.
Carl
On May 3, 2014, at 5:51 PM, Patrick Pulis <rv10free2fly(at)yahoo.com.au> wrote:
Patrick Pulis
 Filesize:  796 KB
 Viewed:  6373 Time(s)
PostPosted: Sun May 04, 2014 4:43 am    Post subject: RV-10 Air Oil Separator Installation Reply with quote
Many thanks Carl & Ashley for your replies.
Warm regards
Patrick
On 4 May 2014, at 8:37, Carl Froehlich <carl.froehlich(at)verizon.net> wrote:
Carl
<image.jpeg>
> Patrick Pulis
<pre><b><font size=2 color="#000000" face=3D"courier new,courier">
</b></font></pre>
bill.peyton
PostPosted: Mon May 05, 2014 4:43 am    Post subject: Re: RV-10 Air Oil Separator Installation Reply with quote
You might want to check out this thread on VAF that I started on Air oil sep and oil consumption http://www.vansairforce.com/community/showthread.php?t=92980. I have the Anti-splat A/O sep and am very happy with the results. If you mount it on the firewall, be sure to pick up either the cross brace, or support it in more than the two mounting tabs provided. The SS firewall is not thick enough to support the weight of the Separator on it's own. Here is another couple of threads on the subject of installation http://www.vansairforce.com/community/showthread.php?t=42386&highlight=air+oil+seperator, and a photo of my installation.
 Filesize:  2.04 MB
 Viewed:  6348 Time(s)
WA0SYV
Aviation Partners, LLC
PostPosted: Tue May 06, 2014 2:20 am    Post subject: RV-10 Air Oil Separator Installation Reply with quote
Did you also install the 'Anti-Splat' vacuum valve and exhaust port drain tube?
Warm regards
Patrick
WA0SYV
http://forums.matronics.com/viewtopic.php?p=422819#422819
http://forums.matronics.com//files/img_2864_154.jpg
bill.peyton
PostPosted: Tue May 06, 2014 4:26 am    Post subject: Re: RV-10 Air Oil Separator Installation Reply with quote
Yes, I installed the NAPA valve in the exhaust .
WA0SYV
