AeroElectric-List Digest: 1 Msgs - 04/16/14
PostPosted: Thu Apr 17, 2014 7:19 am    Post subject: AeroElectric-List Digest: 1 Msgs - 04/16/14 Reply with quote
At 09:06 AM 4/17/2014, you wrote:
Not sure if this will go through what with the server outage and
all, but today I am integrating a diode into the aux alternator
power 22 awg wire and I need Bob's comic book on integrating
homeless components. If someone hears this, please respond.
Hope this works.
The list's are supported by separate hardware that
deals with e-mail so your posting is not going into
a black hole . . .
What kind of diode and where are you wanting to wire
it in and what purpose does it serve? If it's a little
plastic or glass wire lead diode then you can trim off
the diode leads to about 3/8", lap solder the wires to
each end and cover with a couple layers of heatshrink.
See attached . . .
AeroElectric_Connection_-_Integrating_Homeless_Components_into_Airframe_Wiring.pdf
 Filename:  AeroElectric_Connection_-_Integrating_Homeless_Components_into_Airframe_Wiring.pdf
 Filesize:  772.92 KB
 Downloaded:  220 Time(s)
