whodja
Joined: 27 Jan 2014 Posts: 50 Location: Apex NC (near Raleigh)
Posted: Mon Apr 07, 2014 4:06 am Post subject: Planning to order the QB fuselage and wings at AirVenture |
Can anyone tell me about what is included in the QB finishing kit? When I finish my tail kit and order the wing and fuselage QB kits, how much lead time and in what order will I need to plan on my avionics and engine?
Thank you,
Tal Holloway
Apex, NC
Bob Turner
Posted: Mon Apr 07, 2014 9:03 am Post subject: Re: Planning to order the QB fuselage and wings at AirVentur |
Hi Tal,
As Carl said, order avionics last. They change so fast that anything you buy today will be obsolete before you fly. Also - contrary to everything else - they are becoming less expensive or more capable (your choice).
As he noted, you may save a few dollars shipping if you order the finish kit (same kit, slow or quick build) with the QB wings and fuselage. But you will need storage space for it. In the past (2008) the QB fuselage and wings could have backlogs as long as 4 months. Call Vans and ask for the current status (I think it's on their web site but may not be the latest info). Finally, the engine. What is your plan? If you were hoping to find a good used one they are rare, you just have to watch constantly. If an overhaul, ask your overhauler about lead times and time to find a useable core. If factory new, you have a choice. These things have been inflating faster than the stock market, so you may consider buying it and the prop (Vans offers a $1K discount if you buy both at the same time) during this year's OSH/AirVenture. They usually have a special, like free shipping and free long term preservation oil. Otherwise, engine lead times are a few months.
_________________ Bob Turner
RV-10 QB |
jack(at)bedfordlandings.c Guest
Posted: Mon Apr 07, 2014 11:57 am Post subject: Planning to order the QB fuselage and wings at AirVenture |
Tal,
I would suggest you keep an eye out for a good deal on an engine (unless you
are planning on buying a new engine). I was able to find a very good deal
on an O-540-A1D5 from a Piper Aztec on eBay a couple of years ago. The
engine has 60 hours SMOH and I got it, the logs, and the entire firewall
forward assembly from the Aztec (including alterhator, starter and vacuum
pump) for $13,000.
I had planned to buy a core of an IO-540 for about $12K and then put $15K in
new parts in it, overhauling it myself. Even though I wasn't sure what I
was getting with this eBay purchase, I felt it was worth it for the money
just to have as a core. I was surprised and pleased to see that it was
better than advertized, with new Millenium Cylinders, new Slick mags and
good shops used for the overhaul. So good deals are out there - you just
need to look for them
Now I just need to get back to work on the project.
Jack Phillips
#40610
Smith Mountain Lake, Virginia
Wings and Tail done. Need to buy the Fuselage Kit.
michaelrorth
Posted: Mon Apr 07, 2014 12:39 pm Post subject: Planning to order the QB fuselage and wings at AirVenture |
FOR SALE
3 ENGINES & 1 PROP
ENGINE #1-RIGHT
CONTINENTAL 10-470L
S/N 91968-5-L
TTSO 1489.8
COMPLETE ENGINE & PROPELLER PITCH CONTROL.
COMPLETE LOGS.
REMOVED FROM BEECHCRAFT BARON THAT LANDED GEAR-UP. INCIDENT HAS NOT BEEN ENTERED INTO ENGINE LOG.
OIL DRAINED AND SHOWED NO SIGN OF CONTAMINATION.
OIL-PAN DROPPED AND VISUAL INSPECTION SHOWED NO SIGN OF DAMAGE.
MY FEELING IS THAT THIS ENGINE DID NOT SUFFER ANY DAMAGE AS THE RESULT OF THE ACCIDENT.
COULD BE USED IN A/C, AIRBOAT, OR HOVERCRAFT.
PRICE $5,000 USD; YOU PAY SHIPPING.
ENGINE #2-LEFT
CONTINENTAL 10-470L
S/N 91945-5-L
TTSO 1457.8
COMPLETE LOGS
ENGINE #3
LYCOMING IO-540 G1D5
S/N L-9927-48
TTSO 5.43
COMPLETE LOGS
PROP #1
HARTZELL HC-92WK-1DW
TTSO 2.12
S/N S/N AC-206
PRICE-ENGINE & PROP $18,000 USD. YOU PAY SHIPPING.
THIS IS HOW THE ENGINE WAS DESCRIBED TO ME:
“…. purchased the engine and prop from Westair International Company, Monument, CO 80132 Jim Cullen is the owner. (719) 481-2286 He sold a number of these engines and was recommended to me by Murphy. They thought this was a perfect engine for their plane. I called a fellow who bought one from him to check up on his transaction. He was very pleased with Jim and the engine and prop. (His name is John Knutson, Chicago, (312) 642 0335 home (312) 383 1300 x 104 work) I believe he was putting it into his homebuilt. I haven't talked to him in ten years so I don't know if the numbers are still good. The engine arrived as promised and is complete with magnetos, harness, fuel pump, Bendix injection system, alternator and starter. It is preserved, and includes platinum spark plugs (not installed--the plug holes have the things in them that absorb moisture--I can't remember what they are called!) There are three tech manuals also. It is still in the shipping crate which has always been in my heated shop. I looked in it today and it looks good. The IO-540 G1D5 engine serial number is L-9927-48. It is rated as 290 HP, max rpm 2575. The Hartzell Propeller Model HC-92WK-1DW S/N AC-206 The engine has a total of 799.22 hours since new. It has 5.43 hours since overhaul. The propeller has a total of 731.12 with 2.12 since overhaul. There are two complete log books for the engine and one for the propeller.
My concern before buying was that they came out of an IAR 823 airplane which was a plane used by the Romanian Air Force! (I Googled it and it looks like a Mooney to me.) I checked with several engine building people (including the company that overhauled my Cessna engine) who told me the overhaul facility in Romania is noted for quality services. (BOAC had them do all their engine maintenance.) A fellow on the Murphy group, George Coy (who now sells M14P radials and was building a Moose--put this IO-540 in his plane. I asked him why not use one of his radials and he said he was going to put it on floats in Vermont and could not have any oil dripping into their pristine lakes. I guess coffee cans wired under the jugs does not meet environmental standards for catching 100% of the oil!
The log books are all in Romanian but I had someone go over them with me (they spoke Romanian) and they are very detailed and complete. I was going to sit down with this person and rewrite each entry but haven't yet. I got a new English engine log from Jim Cullen--I'm not sure it is really necessary to translate the old ones. I feel comfortable with the accuracy of the logs and the work that has been done. A mechanic where I get my Cessna serviced was interested in using the engine for his tow plane--checked out the engine and logs, said it looked good but then found his mounts or something were different and it wouldn't fit. He offered my $20,000 for it! (I should have paid for his new mounts!) Hope this is the info you needed--I think it is the right motor for the Murphy. I've watched a friend mess with a M14 radial in his Moose but his struggles with the cowl, oil leaks, air start, parts, mounts and extra fuel burn, etc. etc. convinced me a good old 290 HP Lycoming was what I felt most comfortable with.”
Michael Orth
Beaver Valley, British Columbia, Canada
mosurf(at)xplornet.com
(250) 243-0013
