Posted: Mon Jun 19, 2006 7:19 am Post subject: FireFly Wing Swivel Joint Repair |
FireFlyer's,
After 200+ hours the FireFly rear wing spar swivel joints started to sound
like tinny sleigh bells. Earlier I had shimmed them with thin brass shim
stock. Some of the shims stayed in place and others did not. As a result,
all the shaking and quaking at the rear of the fuselage slowly wore the pin
OD's and the mating hole ID's.
I purchased some inexpensive Oilite flanged sleeve bushings from McMaster
Carr, drilled out the holes, inserted the bearings, and new slightly longer
pins and removed all the play from the swivel joints. Also, I bushed the
stud that passes through the cage clevis. I used a washer and two nested
"O" rings so that I could put the joint into compression but still let it
pivot.
Before the repair, the trailing edge of the wing would move over an eight of
an inch. After the repair, there is no movement. The nice thing about this
repair is that if play shows up again, all one has to do is replace the
bushings. There should be little to no wear on the steel surfaces.
If you would like to see how it was done, it can be seen at:
http://www.thirdshift.com/jack/firefly/firefly128.html
Jack B. Hart FF004
Winchester, IN
jeepacro(at)cox.net Guest
Posted: Mon Jun 19, 2006 8:04 am Post subject: FireFly Wing Swivel Joint Repair |
I can't seem to open up the pictures of the repair of swivel joint. Can you send me some pictures? Thanks in advance
Rob.
---- "Jack B. Hart" <jbhart(at)onlyinternet.net> wrote:
Quote: |
FireFlyer's,
pivot.
Jack B. Hart FF004
Winchester, IN
Posted: Mon Jun 19, 2006 10:04 am Post subject: FireFly Wing Swivel Joint Repair |
to sound
shim
result,
the pin
McMaster
longer
bushed the
nested
let it
| pivot.
eight of
about this
the
| Jack B. Hart FF004
| Winchester, IN
_________________ John Hauck
Titus, Alabama |
planecrazzzy Guest
Posted: Mon Jun 19, 2006 12:55 pm Post subject: Re: FireFly Wing Swivel Joint Repair |
Hi Jack,
Nice work and nice illustrations...
Question....Aren't you supposed to have Bolts on those ears instead of
Pins....?
Gotta Fly...
Mike in MN
Posted: Mon Jun 19, 2006 1:17 pm Post subject: FireFly Wing Swivel Joint Repair |
At 01:55 PM 6/19/06 -0700, you wrote:
Quote: |
Hi Jack,
Pins....?
Gotta Fly...
Mike in MN
Mike,
The loads are pure shear loads so there is no need for bolts. Pins for
a given holding distance are lighter than bolts.
Jack B. Hart FF004
Winchester, IN
Gene Ledbetter
Joined: 10 Jan 2006 Posts: 20 Location: Cincinnati, OH
Posted: Tue Jun 20, 2006 6:34 pm Post subject: Re: FireFly Wing Swivel Joint Repair |
Jack,
I checked my Firefly Wing Swivel Joints today and after 328 hours can report that there is minimum wing movement. I have always used bolts for the swivel joint connections and although that may not be significant, it has allowed the joints to be tightened to the point that the bolts have never been loose to move or shake.
Gene
_________________ Gene D.
2000 Firefly
330 Hours
New 447
Brakes, Ivo |
Posted: Tue Jun 20, 2006 7:47 pm Post subject: FireFly Wing Swivel Joint Repair |
mating hole ID's.
McMaster
longer
bushed the
nested
let it
| pivot.
| Jack B. Hart FF004
Jack:
Looks like you have drastically deviated from Kolb plans and
instructions on how to attach the wing fold universal joint and
attachment to the cage.
After more than 2,500 hours flight time, I have not had a requirement
to change out the bolts in the wing fold universal joint, nor adjust
the tension on the attachment hardware to the cage. These parts of my
mkIII remain snug, safe, and secure.
Don't believe bronze bushings are the remedy to your problem. Quite
possibly, had you used bolts washer and nyloc nuts as prescribed by
the plans and instructions, you would not have wear on your "clevis
pins" and holes in the universal joints.
Reference the attachment at the cage, two "O" rings are not going to
keep that piece of hardware from moving on the ground and in flight,
when the wings are loading and unloading. A combination of thick and
thin AN washers will give you the appropriate snugness required at
this point with castellated nut and cotter pin.
If the bolts are snugged up tight after the wings are repositioned
from storage to flight position, wear on these bolts and holes will
certainly be discouraged. If I had to fold my airplane after each
flying session, I would insure the bolts in the universal joints were
loose during the flight prep process, snugging them up tight prior to
flight. When time came to fold the airplane, a second or two to
loosen these bolts prior to folding the wings.
NOTE: Jack can configure his FF any way he wants to, as anyone else
can do likewise. However, let it be noted that his procedure for
taking slack out of the wing fold universal joint and wing attachment
to the fuselage is certainly not a "normal, safe, recommended" method
of maintenance.
"Nuther NOTE: This is in no way a personal attack on Jack Hart.
Titus, Alabama |
Eugene Zimmerman
Posted: Tue Jun 20, 2006 8:24 pm Post subject: FireFly Wing Swivel Joint Repair |
Huh ? What? Is the list funky, or are you shooting blanks?
On Jun 19, 2006, at 2:03 PM, John Hauck wrote:
to sound
shim
result,
the pin
McMaster
longer
bushed the
nested
let it
| pivot.
eight of
about this
the
| Jack B. Hart FF004
| Winchester, IN
Posted: Tue Jun 20, 2006 8:39 pm Post subject: FireFly Wing Swivel Joint Repair |
Eugene Zimmerman <etzim62(at)earthlink.net>
Shoot'n blanks.............
PS: A msg I posted yesterday afternoon came strolling across my
monitor late tonight. Always better the second time around. Maybe it
was a shadow.
Titus, Alabama |
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Tue Jun 20, 2006 9:16 pm Post subject: Re: FireFly Wing Swivel Joint Repair |
Jack:
You are scaring me, Jack. In theory the pins are in pure shear loading. The shear load is not what will bite you. If the ears of the piece closest to the cage try to spread the clip on the pin will be sheared off and we may be reading unwelcome stories of your early demise. Another failure mode: the vibration that forced the repair in the first place may weaken the clip or safety ring as it rattles in the pin hole. Safety pins and rings are made in China more often then not these days, even when purchased from a reputable source. In my mind, a weight savings of less than an ounce doesn't justify the added risk.
The bushings look nice, but those pins scare the puddin' out of me. Those are "Oh Sh-t" bolts you are playing with.
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
Eugene Zimmerman
Posted: Wed Jun 21, 2006 3:46 am Post subject: FireFly Wing Swivel Joint Repair |
John / Kolb Folks,
I also believe that Jack Hart's swivel joint repair is not one of his
characteristically good ideas.
In my humble opinion removing metal to install bushings and o-rings
in the swivel joint is NOT a GOOD idea or actual improvement.
Finding and correcting the cause and replacing the worn parts would
much better.
Worn swivel joints is not a common problem on Kolb planes.
Could it be possible that some of Jack's other modifications
contributed to the unusual wear of these parts?
His engine/redrive may well have a different vibration profile than
the standard 447 Rotax.
was a shadow.
Posted: Wed Jun 21, 2006 5:47 am Post subject: FireFly Wing Swivel Joint Repair |
At 07:43 AM 6/21/06 -0400, you wrote:
Eugene and Kolbers,
First of all, I apologize to all who I have offended, BUT what is wrong with
providing a bearing material in a rotating joint? Since a rotating joint of
similar material is always going to show greater wear than if one surface is
made of a bearing material, why not change it? For less than four dollars,
I have the equivalent of a new and improved swivel joint.
As for strength, I sent the following to another Kolber:
"I know it looks bad but we are fortunate that Homer and/or Dennis gave us a
very robust design in this area. The steel is 0.125 inches thick.
....................................... To check out the worst case, the
tangs for the clevis that attaches to the wing attachment point is only
0.875 inches wide. By drilling the 5/16 inch ID out to 7/16 of an inch you
have a cross sectional area to support tension or compression of 7/16 times
1/8. Or the equivalent of 0.055 square inches. Unhardened 4130 has a yield
stress of 95,000 psi, so each tang will support (95,000 x -.055) 5,195
pounds or the modified clevis will support over five tons before yielding."
Jack B. Hart FF004
Winchester, IN
Thom Riddle
Posted: Wed Jun 21, 2006 8:28 am Post subject: FireFly Wing Swivel Joint Repair |
Jack,
As a fellow retired mechanical engineer and machine designer, I don't
see a thing wrong with your use of hi-strength close tolerance pins and
oilite bushings. I can't count the number of times I've used oilite
bushings and hi-strength pins in machine designs subject to extreme
vibration and impact loads in shear with no failures ever. Not sure I
would have put o-rings there because they will compress, as you stated,
but since the longitudinal loads on these pins are minimal, probably
not much of an issue.
Thom in Buffalo
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Eugene Zimmerman
Posted: Wed Jun 21, 2006 8:52 am Post subject: FireFly Wing Swivel Joint Repair |
Jack,
The main concern I have is your ,,,,, "If I had it to do over again,
I would try this approach on the cage pivot stud." ,,, web page diagram.
Why do you think that would be an improvement?
Eugene and Kolbers,
wrong with
joint of
surface is
dollars,
gave us a
........................................ To check out the worst
case, the
only
inch you
7/16 times
a yield
yielding."
Jack B. Hart FF004
Winchester, IN
Posted: Wed Jun 21, 2006 10:51 am Post subject: FireFly Wing Swivel Joint Repair |
At 12:52 PM 6/21/06 -0400, you wrote:
Quote: |
Jack,
Eugene,
I have used this method to get all of the play out of the aileron control up
next to the stick. The reason, I believe, it would be better is that it is
simpler than what I have done. The trick is to make the chamfer just large
enough so that when the nut is compressed up to the plate the "O" ring is
completely contained in the chamfer space. This gives some compliance for
the "O" ring to keep the clevis centered on the stud, but does not keep the
clevis from being rotated. And better yet, as the mating surface between
the clevis and the cage wear, the "O" ring acts as a compressive spring and
maintains joint tightness. Also, if the "O" ring keeps the stud from
touching the hole ID, there can be no wear between the stud and the clevis
hole.
The thing to remember is that during flight these two vertical surfaces are
in compression (drag force) and most of the lifting force is handled by the
main spar connector and the struts, so it takes very little compressive "O"
ring force to keep the rear spar centered/located.
Jack B. Hart FF004
Winchester, IN
Posted: Wed Jun 21, 2006 11:05 am Post subject: FireFly Wing Swivel Joint Repair |
John,
Page 15 of the FireFly assembly instruction manual, it shows the Wing
Folding Mechanism, and it states "Do not overtighten AN5-16A bolts as
they must be free to rotate."
Jack B. Hart FF004
Winchester, IN
n79rt(at)kilocharlie.us Guest
Posted: Wed Jun 21, 2006 11:36 am Post subject: FireFly Wing Swivel Joint Repair |
Jack,
Got to take issue with the O-rings. (Don't like the pins either, no
worries on the strength issue just risk of breaking a cotter pin during
fold/unfold seems unnecessary considering the minuscule weight
savings...)
In Bruhn's "Analysis and design of Flight Vehicle structures" he has an
excellent example of a wing drag strut where he demonstrates that under
quite normal flight loads (high angle of attack) the drag strut will
actually be in TENSION not compression. The forward component (in
relation to the airplane centerline)of the lift force (perpendicular to
the ground) greatly exceeds the drag component (relative to the
airplane centerline). So the wing is actually pulling forward (i.e. drag
strut in tension) So your o-rings are being further compressed from
actual flight loads, not just from the nut. IF/WHEN they ever break and
fall out you will have much movement in that joint.
Jeremy
Posted: Wed Jun 21, 2006 11:38 am Post subject: FireFly Wing Swivel Joint Repair |
were
to
| John,
Wing
as
| Jack B. Hart FF004
| Winchester, IN
Jack:
Please reread what I wrote above.
If I was a wing folder, i.e., had to fold and unfold my Kolb to fly
each time, I would:
-Loosen the two bolts in each universal joint during the folding and
unfolding process. However, I would snug them up tight once the wings
are in position. This will preclude the bolts and holes from wearing
and enlarging. Time to fold it back up. Loosen the bolts again.
-The clevis fitting on the cage can be adjusted properly with use of
thin and thick AN washers as required.
I can assure you, the trailing edge of the wing and the universal
joints and clevis attachment get a work out in flight, during
acceleration, deceleration, operation of ailerons/flaps, and when
flying in turbulence. Probably the most load and wear will come from
ground ops.
Another thing to think about is wear from vibration. Loose fittings
tend to encourage accelerated wear.
A few things that we did to prevent this wear, based on a lot more
than 200 hours flight time, were:
Welded steel bushings in the lift struts to fit snug in the lift strut
attachments. Then bolted tight to prevent wear.
No clevis pins in the wings and controls. All bolts and nuts.
200 hours is mighty early to experience the problems you are
experiencing with your Kolb.
One thing I have learned from building and flying these little Kolb
airplanes, is to listen "carefully" to what others have to say, digest
it, then either use it, store it, or throw it away. I have learned an
awful lot from those that have gone before me and those that have come
after me. I still have a lot to learn about these little Kolb
airplanes I build, fly, and maintain. I especially learn a lot about
Kolbs from reading your posts.
Keep it simple.
Titus, Alabama |
Posted: Wed Jun 21, 2006 3:25 pm Post subject: FireFly Wing Swivel Joint Repair |
On my MkIII I have an aluminum shim at the universal joint/cabin
interface to correct a slight sweep inaccuracy (left wing only). Last
year I noticed
a slight wiggle during preflight and in the spring removed it for
inspection, dabbed in a touch of anti-seize and snugged it back down.
The trick, at least on the mKIII, is to get a happy medium on tightness
due to the cotter pin hole. The aluminum had conformed a bit to
the mating surfaces and needed a little correction. Paint/epoxy on
the same surfaces will do the same thing. Crank it down
pretty good and back it off to the hole and you will be fine.
I have a few hours on it since and all looks and feels well.
I don't intend to be doing a seasonal loosening/tightening exercise
with one fold per season.
-BB
were
to
| John,
Wing
as
| Jack B. Hart FF004
| Winchester, IN
Jack:
each time, I would:
ground ops.
Keep it simple.
Posted: Wed Jun 21, 2006 4:47 pm Post subject: FireFly Wing Swivel Joint Repair |
At 02:40 PM 6/21/06 -0500, you wrote:
All I am trying to do is improve the swivel joint so that it will not
experience significant wear in the way I believe Homer and/or Dennis
intended the joint to be used. It may take another 200 or more hours to
determine if I have indeed made an improvement or not.
In spite of your good luck at hard bolting, I am not comfortable with the
concept. If things are not matched up perfectly, it is possible to induce
hidden stress by hard bolting. I will remain with pins at all wing and
strut attachment points. I believe the added compliance will reduce stress
levels in the wings, struts, and the cage. I may have some wear problems
but a few dollars of bushings and "O" rings will make it as good as new, and
I can fold the wing without using a wrench.
Jack B. Hart FF004
Winchester, IN
