rv8ch
Posted: Sun Jun 18, 2006 10:06 pm Post subject: Z-16 OV simplification ? |
| Quote: | A buddy homebuilder, who does research in electricity, finds the OV
protection in figure Z-16 somewhat complex, and advocates using a simple
component similar to a Zener to prevent overvoltage.
Any comment or opinion on the pros and cons, or hidden issues ?
Eric sells a device for this purpose:
http://www.periheliondesign.com/suppressors.htm
I've got one, but I also have OV protection to
try to cut off the alternator so it doesn't just
keep putting out energy.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Posted: Mon Jun 19, 2006 1:26 am Post subject: Z-16 OV simplification ? |
Hi Mickey,
What are the advantages of one over the other ?
And what is the point of having both ?
Gilles
http://contrails.free.fr
khorton01(at)rogers.com Guest
Posted: Mon Jun 19, 2006 2:10 am Post subject: Z-16 OV simplification ? |
On 18 Jun 2006, at 21:07, Gilles Thesee wrote:
<Gilles.Thesee(at)ac-grenoble.fr>
Hi Bob and all,
simple component similar to a Zener to prevent overvoltage.
The zener would need to be sized to handle a lot of watts, as it
would have to dissapate the amperage of the alternator at whatever
set point the zener had. How many amps could a 60 amp alternator
produce, if the voltage regulator failed? 80a? 80a times 16v = 1280
watts. How big and expensive is a 16v zener rated for 1280w,
continuously? The ones I've found only seem to be rated to handle
that power level for a very short period. They don't look beefy
enough to handle it continuously.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Mon Jun 19, 2006 3:03 am Post subject: Z-16 OV simplification ? |
Kevin,
Thank you for your message.
The zener would need to be sized to handle a lot of watts, as it would
have to dissapate the amperage of the alternator at whatever set point
the zener had. How many amps could a 60 amp alternator produce, if
the voltage regulator failed? 80a? 80a times 16v = 1280 watts. How
big and expensive is a 16v zener rated for 1280w, continuously? The
ones I've found only seem to be rated to handle that power level for a
very short period. They don't look beefy enough to handle it
continuously.
I should have mentionned that the figure Z16 concerns the Rotax PM
alternator. The rated output is in the vicinity of 20 amps.
That's about 300 W for the Zener or whatever takes its place.
Does it look like a more manageable power ?
By the way, it just occurs to me that if you rely on this component only
to tackle with an OV event, you need some means of alerting the crew of
the OV condition.
nuckollsr(at)cox.net Guest
Posted: Mon Jun 19, 2006 7:36 am Post subject: Z-16 OV simplification ? |
At 03:07 AM 6/19/2006 +0200, you wrote:
Hi Bob and all,
A company called Pelican Aviation proposed this many years ago.
There's a member of this list who called me one evening to report
that he'd experienced a problem with the first running of his
electrical system . . . seems the system suffered an ov event.
After we discussed the means for deducing and correcting root cause,
he noted in passing that the "little plastic thing on the back
of the alternator disappeared". Seems the Pelican supplied zener
diode from b-lead to ground simply exploded leaving a couple
of bare wires.
Yes, if you have a zener diode rated to soak up ALL the excess
energy available from a runaway alternator, it would be required
to dissipate say 16v at 60 amps or 960 watts in some aircraft;
and 16v at 20A (320 watts) in a Rotax system described in Z-16.
That's a real boss-hog zener. Further, adding such a zener would
only keep the voltage from rising, it would not SHUT OFF or DISCONNECT
the offending system.
Posted: Tue Jun 20, 2006 2:22 pm Post subject: Z-16 OV simplification ? |
| Quote: | 16v at 20A (320 watts) in a Rotax system described in Z-16.
Bob,
Thank you.
Is the problem the same with a transil ?
Gilles
Posted: Tue Jun 20, 2006 7:47 pm Post subject: Z-16 OV simplification ? |
At 12:11 AM 6/21/2006 +0200, you wrote:
Bob,
Thank you.
Yes. TVS, Transorbs, Transil, etc are all cousins of the
zener diode. They're designed to avalanche (break down)
when reverse biased and at reasonably calibrated voltages.
Instead of designing for accuracy and stability as voltage
regulators, transient catchers are optimized for power and
speed . . . but they're still linear mode gizmos. So while
a 1500 watt Transorb is barely larger physically than a
1N5400 series diode that's rated to dissipate 3A at 0.7 volts
indefinitely, that's just over two watts.
Guess what? A 1.5KE series transient suppressor is rated
for 1500 watts . . . for milliseconds. See:
http://www.aeroelectric.com/Mfgr_Data/Semiconductors/15ke.pdf
The operative word for using these devices is "transient" meaning
relatively short (tens of milliseconds) events. A runaway alternator
is an all-day event until you get it turned off . . . linear
voltage clamping devices tied to the output of alternators are
not OV protection devices.
They might mitigate load dumps but folks on the list have reported
problematic results in tests where load dump events trashed
a Transorb.
OV protection needs to be discriminating (not to nuisance
trip on true transient conditions) but they also need
to have absolute control over the alternator in terms of
shutting it off.
< with experiment. >
< --Lawrence M. Krauss >
Posted: Wed Jun 21, 2006 2:26 pm Post subject: Z-16 OV simplification ? |
shutting it off.
Bob,
Thanks again.
Gilles
