Contactor recommendation
rdu.hari(at)gmail.com
PostPosted: Mon Feb 17, 2014 9:32 am    Post subject: Contactor recommendation Reply with quote
Hello group
Wondering if I can use a 28V cutler hammer 6041 series contactor in a 12V system?
New Type II contactors are way too expensive and exploring good condition used ones.
Question is, is it better to use a new inexpensive Type I contactor or a used Type II.
Are there recommendations for good quality Type I?
TIA
Hari
dee.whittington(at)gmail.
PostPosted: Mon Feb 17, 2014 5:19 pm    Post subject: Contactor recommendation Reply with quote
Hari, we bought our contactors for our Subaru Eggenfellner 3.6L from B&C. Doug, our electrical guru, said they were not expensive.
Dee
DeWitt (Dee) WhittingtonRichmond, VA
804-677-4849 iPhone
804-358-4333 Home
On Mon, Feb 17, 2014 at 12:30 PM, Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)> wrote:
[quote] Hello group
TIA
Hari
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
PostPosted: Tue Feb 18, 2014 6:00 am    Post subject: Contactor recommendation Reply with quote
At 11:30 AM 2/17/2014, you wrote:
Hello group
I'll suggest you update yourself on the
contactor discussions here on the List.
In particular, this thread in the archives . . .
http://tinyurl.com/kdkbhk7
"Good quality" is not a quantified term.
One might infer that the speaker's concerns
are for "reliability" in the sense that the
part has an attractively low demonstrated failure rate.
Or the speaker may be referring to service life
wherein the demonstrated effects of wear-and-
tear are not so great as to necessitate unduly
frequent replacement. But then, both gross
failure and wear-out will drive a remove and
replace event . . . so perhaps there is little
value in differentiating the root cause for
the replacement.
Contactor failure rooted in any cause is of
little safety concern for the failure tolerant
design (see chapter 17) . . . it should be only
a cost-of-ownership issue.
The beer-barrel contactors from White-Rogers/
Stancore and Cole-Hersee . . .
http://tinyurl.com/lomgmle
. . . have been around for a very long time. They
demonstrate low remove/replace rates and
are quite economical. One may embrace any
number of ideas for 'upgrading' a contactor
but in the final analysis, a positive return
on investment is exceedingly hard to demonstrate.
If it were my airplane . . .
[img]cid:.0[/img]
. . . these can be purchased from a variety
of sources.
 Filesize:  20.05 KB
 Viewed:  3038 Time(s)
