deej(at)deej.net Guest
Posted: Sat Jan 04, 2014 3:23 pm Post subject: Proposed new Z diagram? |
I'd like to start off by saying please be gentle. I'm not an expert and
this could be completely boneheaded.
I've been looking through the various Z diagrams, and although there are
parts of some that I like, I could not find one that is exactly what I
am (or think I am) looking for.
From being on this list for a decade or more, I know that Bob's first
question will be along the lines of "What are you looking for" followed
by "What elements do you want that aren't addressed by the current
diagrams". It is hard to put into words, but I'm going to try.
My aircraft will have an electrically dependent engine (electronic
ignition, gravity feed so no fuel pump) and an electrically dependent
panel (GRT HX EFIS and EIS). It will be used for IFR.
I know recently that we have been talking about how statistically
reliable alternators and batteries are, and have been considering a Z-7
based on a single alt and battery. Physics and statistics aside, I am
just not comfortable with this, and I want a dual battery
configuration. This is a personal choice. That led me to Z-19.
What I do not like about Z-19 is that it has two always hot power
buses. I want a system that when the contactor is off, the battery is
isolated except for the wires going to the contactor. Again, physics
and logic aside, this what I "want".
What I like about Z-19 is the redundancy providing power to the ECU and
Fuel Pump, and that it is an automatic redundancy. Both power buses are
providing power to the ECU at the same time from independent sources.
This led me to realize that I really do not care about having an
"endurance" bus, but what I really care about is having a "redundant"
bus, in other words there are a few devices in my setup that I want to
have the same automatic redundant power as offered by the engine part of
Z-19.
Taking parts of Z-19 that I like, and leaving parts out, I've attempted
to create a "redundant bus" diagram. It also incorporates an
"alternator only" operation simply by the fact of isolating the two
charging circuits and having the alternator on its own switch, although
I can't picture running in this mode.
Please excuse the crudeness of the drawing. I did it by hand, and just
took a picture of the paper afterwards.
Some parts I am not even sure are feasible, such as the diodes that
separate the two charging circuits (located just above the primary bus
in the drawing). I don't even know if diodes exist that will be able to
handle those loads, but I am sure that some sort of electro-whizzy would
probably do it.
Some notes:
I will be using a Fly EFII electronic ignition. Manufacturer
recommendation is a 10 amp CB/fuse for the coil charging circuit, and 5
amp for the ECU. I am told that overall the ignition draws 1.2 amps on
average for power usage purposes, but the coil charging currents can be
up to 10 amps. This current only flows for a few milliseconds.
Gravity feed for the fuel, so no fuel pump.
The GRT HX EFIS and the GRT EIS have multiple, internal diode isolated
power feeds built in which is why there are Pow "A" and Pow "B" feeds
for each of these devices.
This is a first pass, but I am thinking that I want GPS, NAV, COM, and
the Intercom to also have redundant power. I want enough to make an
instrument approach if needed, so usage and/or recommendations may
change this list.
Everything else is wired to the primary bus only (no access to the
secondary bus).
Not completely sure yet, but I anticipate the Aux battery to be smaller,
and mounted under the panel. It will be sized appropriately to offer at
least an hour of battery-only operation for items on the redundant bus
and to support the ignition. The main battery will be larger and
mounted in the tail for CG purposes.
Please critique, but be nice!
Small version: http://deej.net/glastar/pics/electrical/redundant.jpg
Larger picture: http://deej.net/glastar/pics/electrical/redundant-large.jpg
-Dj
Dj Merrill - N1JOV - VP EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
Posted: Sat Jan 04, 2014 4:03 pm Post subject: Proposed new Z diagram? |
How is the engine dependent? Ignition? Fuel Injection?
Do you have the energy requirement numbers?
Z-7 based on a single alt and battery. Physics and statistics
aside, I am just not comfortable with this, and I want a dual
battery configuration. This is a personal choice. That led me to Z-19.
One can ALWAYS add a second battery. Our builders
have been doing this for decades and the techniques
have been discussed at length on the List.
is isolated except for the wires going to the contactor. Again,
physics and logic aside, this what I "want".
Any always hot busses are battery busses and they're
part and parcel of a considered FEMA and meeting
design goals. It's my wish that we can assist with
the crafting of your design goals based more on
understanding and planning and not so much on worries
that drive your discomfort.
and Fuel Pump, and that it is an automatic redundancy. Both power
buses are providing power to the ECU at the same time from
to have the same automatic redundant power as offered by the engine
part of Z-19.
Redundant to meet what failure event. There's nothing
that prevents one from having as many batteries, alternators,
busses and switches as their creativity and physical space
allows . . . but in the TC aircraft world, the first goal
is to minimize weight, parts count, system complexity
and cost of ownership. At the same time, risk assessment
must necessarily drive all the above goals in the wrong
direction. The elegant design adds just enough but no more.
attempted to create a "redundant bus" diagram. It also incorporates
an "alternator only" operation simply by the fact of isolating the
two charging circuits and having the alternator on its own switch,
although I can't picture running in this mode.
just took a picture of the paper afterwards.
bus in the drawing). I don't even know if diodes exist that will be
able to handle those loads, but I am sure that some sort of
electro-whizzy would probably do it.
Some notes:
5 amp for the ECU. I am told that overall the ignition draws 1.2
amps on average for power usage purposes, but the coil charging
currents can be up to 10 amps. This current only flows for a few milliseconds.
So have you arrived at a ball-park number
for total electrical system energy requirements?
You speak to a 60 minute battery-only ops goal
but can/should it be longer?
isolated power feeds built in which is why there are Pow "A" and Pow
"B" feeds for each of these devices.
and the Intercom to also have redundant power. I want enough to make
an instrument approach if needed, so usage and/or recommendations may
change this list.
secondary bus).
smaller, and mounted under the panel. It will be sized appropriately
to offer at least an hour of battery-only operation for items on the
redundant bus and to support the ignition. The main battery will be
larger and mounted in the tail for CG purposes.
You have described adjustments to an architecture
but it's not clear as to the reasoning behind those
moves. It seems as if you don't want any single failure
to cause to you drop to an energy efficient, endurance
mode . . . are you trying to keep everything lit up
no matter what?
You speak of a large main battery and a smaller
auxiliary battery. What's the physics behind these
sizing decisions?
Z-7 elects to drive a single engine bus
through diodes from two power paths. What in
your knowledge or experience suggests that
charging batteries through diodes offers
more attractive options?
Posted: Sat Jan 04, 2014 8:03 pm Post subject: Proposed new Z diagram? |
Hi Bob,
Thank you for your comments. Based on your response and questions
asked, I think you may have missed some points that I presented in my
initial post. I will try to elaborate and present my thoughts more clearly.
You ask several questions concerning the "why". As I mentioned,
ultimately, it is because I "want", not solely based on any particular
design based on physics, simple ideas, or statistical likelihood of any
component failing. When building or modifying an OBAM aircraft, "want"
is an important factor. This is why most of us build/fly experimental
aircraft versus spam cans, and as with most experimental aircraft, one
size does not necessarily fit all.
I want dual batteries and am not comfortable with just one. This is
not physics, these are those messy human "wants" and "feelings", which
can't be quantified easily, if at all.
I do not want an always hot power bus. I want a system that when
the contactor is off, the battery is isolated except for the wires going
to the contactor.
I want automatic redundancy to certain devices similar to that
offered in the engine section of Z-19.
Essentially, the "why" of the above doesn't really matter. These
are things that I "want" in my aircraft, and I'm trying to figure out
the best way to accomplish these goals safely. I am hoping that you and
others on the list are willing to help me to achieve this. The diagram
I presented is my first draft towards this goal, and is my first ever
attempt at an electrical design. It might be total felgercarb, which is
why I am asking for help.
I do have a few guidellines in my thinking. One is that from
others' experience, we know that in a one battery situation, the EFIS
and EIS can "brown out" and reboot when cranking the engine. I desire to
have the EFIS and EIS up and running before cranking the engine, thus a
second power source is required at least for these two items, which is
one small part of the design goals.
As mentioned, the engine is electrically dependent upon the
ignition system, comprised of the ECU and coil circuits. There is no
fuel pump (and no fuel injection). In particular, it is a Lycoming
O-320 in a Glastar, using gravity for fuel feed into a Rotec TBI
(Throttle Body Injector), which uses no electrical power. As outlined
in the initial post, the energy requirements are 1.2 amps to keep the
ignition running, but simply keeping the engine running is only part of
the goal.
I have no desire or need for an always hot battery bus. When power
is turned off, I do not wish to have any parasitic load that can drain
the battery between flights, and I do not want to have any live buses.
These are design goals that I consider important for my electrical
system, but I fully agree that others may not share these same goals.
That's okay.
All that is true, however, the most elegant design from an
engineering perspective may not be the most desired design from a user
perspective. I've stated up front that parts of the design are based on
what I "want", not just what is the most practical design based on
physics or simple ideas. As long as the engineering can support it,
including the "wants" can be just as important in meeting a design goal
as "elegance".
I am sitting here with Z-19 in one hand, and my proposed drawing in
the other, and to me my drawing looks much simpler than Z-19 with less
parts count, and in my mind seems to offer similar yet slightly
different functionality to incorporate my "wants" versus the Z-19
boilerplate. As I said, this is my first attempt ever at a design, so I
might be way off on this, and please, do not take this as an attack on
Z-19. I am simply using it as a comparison to your comment about parts
count and system complexity, especially since my diagram was based off
Z-19 initially.
The hour was picked as my personal comfort level. An hour should
be adequate to get the plane safely on the ground even in IFR
conditions. I do not have the exact numbers on all of the installed
equipment in the entire airplane, however, the total load on the
redundant bus is about 6 amps including the electronic ignition (COM not
transmitting). Unless I am missing something, I don't believe that
having those exact numbers at this time will change the basic design of
the electrical system. It will have an impact on the size of the
batteries chosen, and the values of fuses/CBs, though. Would you agree,
or have I misunderstood something?
Bear in mind that if the alternator fails, I have two separate
batteries that can provide power, so the total time should actually be
much longer than an hour especially if I turn off "extra" loads on the
main bus, but should be at least an hour from the aux battery if I don't
turn off anything. If one or the other battery or associated wiring and
circuitry should fail, the alternator and single battery remaining
should be able to run everything until the completion of the flight,
although more than likely I would make a precautionary landing in the
event of any type of problem.
no matter what?
I thought I described this clearly, but apparently I've not
communicated well. I'm trying to keep everything on the redundant bus
lit up as those are what I consider the critical items, and I mentioned
that this list of items may change as I use the system and/or receive
recommendations from others. In particular, in my initial email I
listed the electronic ignition, GPS, NAV, COM, and the Intercom to have
redundant power. At the moment, these are what I would consider minimum
to get the airplane safely on the ground in IFR conditions.
sizing decisions?
Partly because I am rewiring an existing electrical system on an
already flying airplane. The main battery is located just behind the
baggage area, and I do not desire to relocate this.
The aux battery only needs to be large enough to run the redundant
bus for an hour, and will be mounted under the panel for CG reasons, so
it is helpful to have it be as small as practical from a physical
perspective.
As stated earlier, the electrical sizing of the batteries will be
made after all of the electrical loads are calculated, and are located
on either the main or redundant buses. Again, I'm not sure how the size
of the batteries will have any impact on the basic design of the
electrical system. Will selecting a 10ah versus a 12ah battery for the
aux, for example, have any effect at all on the basic electrical design
as depicted in the diagram?
None, which is why I indicated diodes in the initial design. As I
stated, "I don't even know if diodes exist that will be able to handle
those loads". If they will, excellent, I chose correctly the first time
and I really have learned some things from following this list for the
past decade or so. If not, I was sure someone on here would point that
out and offer an alternative. Bear in mind that I'm still learning...
So we've gone through a couple of pages of questions and answers, but I
feel like I haven't really gotten any feedback at all on the diagram
itself as presented.
Will it work?
Are there any obvious or not so obvious flaws?
What are your concerns, if any, in the diagram as presented?
Have I communicated the basic design goals clearly enough to follow,
taking in to account the end-user "wants" in addition to ensuring that
the basic design will function properly?
-Dj
Posted: Sun Jan 05, 2014 10:34 am Post subject: Proposed new Z diagram? |
I feel like I haven't really gotten any feedback at all on the
diagram itself as presented.
Clearly, your design goals are substantially different than
those which drive the z-figures . . . which is not a bad
thing . . . just different.
Will it work?
I've never encountered an alternative approach that did
not function as intended . . . where function is defined
as, "flip that switch and expect this action to follow."
You can easily confirm functionality with some judicious
ground tests. Get an ac mains power supply to emulate
the alternator and do the electrical system 'Walter Mitty'
thing with the wheels on the ground.
The z-figures are evolutionary . . . they form a
kind of pyramid that spans the simplest to most
complex, each tailored to a combination of aircraft/
mission/pilot. When useful 'tweaks' were identified
the figures evolved independently as well.
As with any new adventure in design, some 'gotchas' may
be discovered by analysis and comparison with lessons
learned . . . others may not bubble up until the system
is operated either as laboratory mock up (which we do
in TC aircraft) or fly on the test-bed aircraft (like
Burt Rutan does it).
Those-who-know-more-about-airplanes-than-we-do are
fond of the 75-hour test stand runs for engines
and 40-hour fly-offs for airframes. But BOTH protocols
presume that the person conducting the test isn't
just along for the ride but is also getting answers
to questions.
The risks associated with discovery of glitches are low.
Only a the smallest fraction of sad days in aviation
have roots in failure of a component of the electrical
system. Your development process will be refined on
the flying test-bed . . . so flight into marginal
environment for the first hundred hours or so is
discouraged . . . with experiments conducted to
validate every design goal.
The highest risks will arise not from design and
selection of components but from craftsmanship
. . . as illustrated by numerous NTSB narratives
on unhappy events. These were not based on the massaging
of a 'z-figure' but more for lack of understanding of
processes.
that the basic design will function properly?
Based on inspection of your work-product and review of
your design goals I have no particular concerns with
respect to either risk or functionality.
You've embarked on a new "z-figure" with a design philosophy
based not so much on economies of energy, weight, functionality
and risk but on decisions and desires personal to you. This
makes your project more a one-of-a-kind work of art as
opposed to a competitively merchantable collection of
ideas. There is nothing 'golden' about either . . .
they just need to satisfy the end-user's perceptions for
return on investment.
As with any such endeavor, cautious and introspective
experimentation is the key to your success.
jluckey(at)pacbell.net Guest
Posted: Sun Jan 05, 2014 3:03 pm Post subject: Proposed new Z diagram? |
... cautious and introspective experimentation is the key to your success...
sounds like something you'd find in a fortune cookie, grasshopper
Sent: Sunday, January 5, 2014 10:33 AM
Subject: Re: Proposed new Z diagram?
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
So we've gone through a couple of pages of questions and answers, but I feel like I haven't really gotten any feedback at all on the diagram itself as presented.
Will it work?
to questions.
processes.
Have I communicated the basic design goals clearly enough to follow, taking in to account the end-user "wants" in addition to ensuring that the basic design will function properly?
experimentation is thep; * AeroElectric www.buildersbnbsp; * My Pilot Store www.mrrace.com</ &nbsd much .com/Navigator?AeroElectric-List" target="_blank">http://www.matronics.co======
Posted: Sun Jan 05, 2014 3:15 pm Post subject: Proposed new Z diagram? |
At 04:59 PM 1/5/2014, you wrote:
Quote: | ... cautious and introspective experimentation is the key to your success...
That would be a good one for the cookie . . . but
in fact a simple reality taught and practiced by
every competent practitioner of both the arts and
sciences. It's the hammer-n-tongs for implementation of
spontaneous order, a concept that has been around
for better than 2300 years . . .
Posted: Sun Jan 05, 2014 5:56 pm Post subject: Proposed new Z diagram? |
When I decided to post my draft diagram on the list, my hope was to
get a peer review from others, and an independent verification that the
circuit design would function properly and as desired. In a basic
sense, I would really like to have someone with far more experience than
I to go over the diagram, and reply with a clear "YES, it will work as
you expect", or "NO, you missed (blah), or you will smoke the circuit
because of (blah)." I believe I have learned a lot on this list over
the years, enough to feel confident to post a circuit diagram, but I am
far from an expert and am still learning. A "look over the shoulder"
from a guru now and then is a great help to a student to tell if they
are on the right track, or not, much the same as constructing a wing or
installing critical flight controls. In other words, I am pleading for
a technical review if there are people out there willing to do so.
Bob, I've read through your recent response several times, and it
is not clear to me if you did a review of the circuit diagram, or are
simply telling me in a sense, "good luck" in far more elegant and
lengthy prose (which I do appreciate! ). Based on one sentence, I
think you have looked it over, ie "Based on inspection of your
work-product and review of your design goals I have no particular
concerns with respect to either risk or functionality." I think what
you are saying here is that yes, the circuit should work as desired, but
I'm not certain (You could simply be saying that you have no concerns
about it working, which is not quite the same thing). Would you be
willing to answer the question with a simple "yes" or "no", will this
circuit diagram work properly and as desired given the guidelines and
design goals that we've talked about over the past few messages?
An interesting and unexpected side effect - I've received emails
direct from others that say they are also interested in this type of
architecture, specifically the automatic "redundant" bus feature for
critical devices to get power from either the primary or secondary power
buses. Since this appears to have an interest going beyond my personal
implementation, I'd be honored if you would consider pursuing this
further, and possibly entertaining the idea of including something like
this as a Z diagram in a future version of the Connection.
Thank you,
-Dj
Will it work?
to questions.
processes.
Bob McC
Posted: Sun Jan 05, 2014 7:08 pm Post subject: Proposed new Z diagram? |
First; it would appear that what you have drawn will function.
Is that function what you intend?? Or expect?? I'm not sure. It will power
the components you mention from either of two sources redundantly, but is it
what you want?? My second point below may be the gotcha you're alluding to
and may not have considered but I don't know.
Second; turning off either the primary or secondary power (master?) switch,
as the circuit is drawn, will not turn off the respective primary or
secondary buss so long as the alternator is functioning. The alternator will
support the buss directly without benefit of the corresponding battery. The
master switches only serve to disconnect the batteries not turn off the
buss. If this is your desired goal then it will work.
This is not necessarily any sort of functional problem, just that you may
turn off one of these two master switches expecting the corresponding buss
to shut down and it won't. As long as you know that this is "normal" for the
way you've wired the circuit and are expecting this result then all is well.
Is there any conceivable instance when you would wish to shut down a buss
utilizing the corresponding master switch?? I so, then you need to be aware
that for this to happen you must also shut down the alternator.
The down side is that in the case (heaven forbid) of a "crash" or "accident"
turning off the master switches does not "kill all power" as the electrical
system is still kept alive by the alternator if it is functioning and the
engine is turning. (even wind milling). Your wiring requires the
manipulation of three switches to fully shut down electrical power.
Bob McC
[quote] --
_________________ Bob McC
Falco #908
(just starting) |
Posted: Sun Jan 05, 2014 10:01 pm Post subject: Proposed new Z diagram? |
it is not clear to me if you did a review of the circuit diagram, or
are simply telling me in a sense, "good luck" in far more elegant and
I think you have looked it over, ie "Based on inspection of your
DJ, what you ask is not unlike somebody laying a recipe
in front of an experienced chef and asking, will this
accomplish what I want? But without articulating exactly
what it is you want and why.
When we produced system designs for the military we
first offered a proposal . . . followed by a preliminary
design review . . . followed by a critical design
review. I had to stand in front of a team of sharp reviewers
and defend my work product twice.
I think what you are saying here is that yes, the circuit should
work as desired, but I'm not certain (You could simply be saying that
you have no concerns about it working, which is not quite the same
thing). Would you be willing to answer the question with a simple
"yes" or "no", will this circuit diagram work properly and as desired
given the guidelines and design goals that we've talked about over
Define "properly" . . . I believe your drawing accurately
illustrates the goals you've cited .
I'm looking at your drawing without benefit of knowing
the foundation for your design goals which becomes
a task not unlike reverse-engineering . . . attempt
to deduce original intent from a document . . . we
can all sit around and talk about it, like visitors
to an art gallery and hypothesize about the mind-set,
tools and techniques of the artist . . . who has
probably been dead for a few hundred years.
You've said you don't want any always hot busses . . .
in spite of the fact that a quarter million airplanes
were built with the benefit of always hot busses.
Okay, defend the design goal. You've got some power
diodes for which I can deduce no value . . . defend
the decision to put them in. Trade off the pros and cons
of your proposal with the features of other proven
philosophies, mine or anyone else.
Do you have a reason to be different or just want
to be different?
power buses. Since this appears to have an interest going beyond my
personal implementation, I'd be honored if you would consider
pursuing this further, and possibly entertaining the idea of
including something like this as a Z diagram in a future version of
the Connection.
I had a builder reject a proposal for a
system on his proposed light jet because "it
didn't have a big enough circuit breaker panel."
I was a bit stunned . . . the most I could offer
was the idea that he could make the panel as
large as he wanted, nobody would demand that
all the breakers were hooked up to do anything.
He got p(at)#$Sd off and fired me . . . for which
I was thankful. If others are finding value
in your proposal, then perhaps they can defend
its features . . . or perhaps they are captivated
by colors and brush strokes . . . I don't know.
We're not producing works of art or recipes
for gourmet meals . . . I'm always interested
in ideas that advance the state of our art and
science but it shouldn't be just one more page
in a 1000-page cookbook.
Posted: Mon Jan 06, 2014 6:02 am Post subject: Proposed new Z diagram? |
Quote: | An interesting and unexpected side effect - I've received
emails direct from others that say they are also interested in this
type of architecture, specifically the automatic "redundant" bus
feature for critical devices to get power from either the primary
or secondary power buses.
Not sure what the term "automatic redundant" feature is all
about . . . for what kind of failure is there value in
offering an 'automatic' response?
Let's try another tack . . .
You said you wanted dual batteries and no always
hot busses. Okay. Consider this variant on the
Z07 work-in-process . . .
http://tinyurl.com/mevf3n8
What failures in this architecture pose any
unacceptable/unmanageable risks? In what way
are your design goals yet to be realized?
Posted: Mon Jan 06, 2014 9:16 am Post subject: Proposed new Z diagram? |
Hi Bob McC,
Thank you for looking things over and offering feedback. You make a
very good point, and I'll have to think about this for a bit. The
original intent was to have a system that could run specific critical
equipment from either of two completely redundant power buses and
battery power sources, and that both batteries would be charging when
the alternator is enabled. Recently on the list we've been talking
about running in an alternator-only mode, and I thought it a nice
feature that my proposed architecture would allow this. However, I
missed the fact that in doing so I now had no way to disable each of the
separate buses if the alternator were running. Thank you for
highlighting that!
Bob M offered a new dual battery Z-7 diagram this morning that offers
more food for thought. I haven't had time to look at it with any
detail, but I look forward to doing so later. If I am reading it
correctly, at first glance it also seems to share a similar
characteristic whereas both the main power bus and the endurance bus are
always powered if the alternator is powered, with no way to individually
remove power from each bus separately. A difference is that there is a
single switch that controls the alternator and main battery contactor,
and is wired such that the alternator will always be turned off first
before the main battery contactor is turned off (ie, no alternator-only
mode). With either the aux or main contactors on, both power buses will
be enabled and there is no independent control to turn each bus off
individually.
Dual-Bat Z-7 requires two switches to shut down all power, and mine
requires three, as you indicate. I could replace the alternator and
main switches with a combined switch similar to Z-7, removing the
alternator-only mode, which may be a good thing to do and simplifies the
user experience, as well as allowing for each power bus to be separated
and powered independently. I think the chances of both batteries
failing and requiring an alternator-only mode are so remote that it is
not worth worrying about.
Thank you!
-Dj
Bob McC
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
Posted: Mon Jan 06, 2014 5:16 pm Post subject: Re: Proposed new Z diagram? |
Attached is one more recipe to help fill the 1000 page cookbook of electrical architectures.
To keep it simple, this schematic has only one bus which is fed from both ends. The failure of any one wire or terminal or switch or relay will not interrupt power to the bus. In the event of low voltage, the pilot should shut off master switch #1. Doing so will shut off power to the alternator field and master contactor coil, thus conserving battery energy. It is up to the pilot to shut off any other unnecessary loads.
Although this architecture is intended for a simple aircraft, the single bus could supply power to an IFR instrument panel or to an electrically dependent engine without danger of power loss due to the failure of any one component.
Joe
Description: |
 Download |
Filename: |
Simple Elect System.pdf |
Filesize: |
60.31 KB |
Downloaded: |
1140 Time(s) |
_________________ Joe Gores |
Posted: Mon Jan 06, 2014 7:01 pm Post subject: Proposed new Z diagram? |
individually.
Assuming that the Viking engine with the as-
proposed alternator does run gracefully in
an alternator only mode, then the whole inter-linked
switch philsosopy for battery and alternator is
moot. This figure illustrates the opptions for
being relieved of that constraint . . .
http://tinyurl.com/mhblorq
Quote: | Dual-Bat Z-7 requires two switches to shut down all power, and mine
How does a battery fail? If such a failure occurs
in flight, how do you know it has happened? What
light comes on to say, "Battery X Fail"?
You have articulated some goals for addressing
a constellation of failures as yet not clearly
defined.
When conducting an FMEA on a system or product
the following questions are posed and answers
sought:
How might this part fail?
How will I know that it failed? Can the effects
of the failure be immediately known and
dealt with in a simple, prescribed manner?
Is the failure pre-flight detectable? If not can
it be made detectable. I that's not possible/
practical . . . what sort of testing is called
for and at what intervals?
How does any particular failure impact probability
of comfortable termination of a flight?
(a) Will any identified failure produce an immediate
risk to ship's systems?
(b) Will any identified failure over-tax my abilities
to manage the event while maintaining competent
control of the airplane?
I have split the DC POWER MASTER into two switches
which increases the number of power management controls
to a total of 6. That gives you 36 possible combinations
of switch positions some small number of which will
result in the engine stopping . . . so those are
easy to eliminate. Of the remaining combinations,
what are the criteria for selecting/rejecting any
combination that keeps the engine running and at least
some stuff lit on the panel?
At some point, after all the colors are laid down
with the favorite brush strokes, you need to craft
the pilot's operating handbook for how the switches
are used. Do all those options serve a predictable,
useful purpose?
It's one thing to have so many options and control
over those options . . . consider that each option
should be deduced and prescribed in advance. Lots
of options can work against you should one become reduced
to a game of "flipping switches until things work better"
while distracting concentration from your duties as a
pilot.
Posted: Tue Jan 07, 2014 6:49 am Post subject: Proposed new Z diagram? |
At 09:01 PM 1/6/2014, you wrote:
While considering the size and utilization
of batteries, add the following into your
deliberations:
If the batteries are of different size, will
the smaller be capable of cranking the engine?
I.e. 17 a.h. or larger? If so, then you can
alternate between batteries for starting the
engine. This philosophy offers a pre-flight test
of battery health and integrity of associated
wiring (contactors etc.)
If it's never used to crank the engine, then
consider the philosophy for assurance of continued
airworthiness.
If the batteries are the same size, then one has
the option of simply rotating a new battery into
the more strenuous/critical slot (probably supporting
the motive power bus) and moving the original battery
into the other slot. This alleviates any need to
accomplish more introspective testing. All you need
is to craft a change-out philosophy tailored for
the most economical outcome.
Perhaps a yearly rotation of a low cost battery
as opposed to a premium device.
I noticed a suggestion in the Viking drawings
for using lithium batteries. Obviously NOT
low cost and probably not candidates for periodic
rotation . . . now you'll need a more introspective
protocol for assuring continued air worthiness.
If rotation is not a viable option, then periodic
inspection for quantifying capacity is indicated.
System reliability and failure tolerance is built
on KNOWING limits . . .
Something to factor into crafting and implementing
the grand-plan . . .
Posted: Tue Jan 07, 2014 11:45 am Post subject: Proposed new Z diagram? |
Discussions about the Viking installation have
raised heretofore unconsidered questions. Since
the earliest days of the change-over from generators
to alternators, the GENERAL consensus and design
philosophies have held that alternators should be
only operated with a battery on line.
There have been the odd exception . . . Bonanzas
and Barons have always offered alternator operation
independently of batteries . . . there may be others
about which I have no knowledge.
If Viking has officially asserted that their product
will function alternator-only, then there are
interesting questions to be explored for crafting
a new design philosophy.
Obviously, the engine driven power source is at
the foundation of energy pyramid. IF the current
generation of alternators and system loads
are amenable to alternator-only operations, then
the legacy design goal for taking an alternator
off line before the battery (split rocker philosophy)
forces a waste of a potentially valuable resource.
I'm going to noodle out some experiments to be
conducted, probably at B&C on their test stand,
to gather data on the quality and integrity
of energy available from an alternator running
barefoot. No doubt inquiring minds would like
to KNOW . . .
In the mean time, you Viking customers have
solid justification for asking the supplier,
"Are alternator-only operations 'approved' under
your design goals? Are there risks to alternator-
only operations. If I hit the system with a
hydraulic pump motor or 250 watt landing light,
can the alternator be stalled? What tests have
been conducted to support your assertions?"
Tundra10
Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
Posted: Tue Jan 07, 2014 1:06 pm Post subject: Proposed new Z diagram? |
I did have a car-sized battery in my boat explode once. It was happy
with the current draw to tilt the motor, but the starter current draw
did something to it. It had responded normally to the battery charger
and had normal voltage before I put it in the boat in the spring. It
was a heck of a mess to clean up. A fully enclosed battery box is
recommended !
I agree the switches will be complex to operate in the air when a
failure occurs. For my design, I had to write out the checklist
sequence for various scenarios before I greatly simplified my design
(not electrically dependent engine).
For this proposed Z diagram, I suggest considering using a progressive
switch to combine the main battery and alternator into a single
switch. In the event of a fire, shutting off the two battery switches
will take away all power from the main bus.
The engine switches are not symmetrical in operation. That is, the
Normal switch works without the main battery switch on. The Aux
switch does not provide power to the engine unless the Aux Battery
switch is also on. This could be confusing while handling a failure
in flight. Although a diode could be connected to the Endurance bus,
my preference would be to have the Aux engine independent of the
Endurance bus switch as well, which means adding another relay.
Jeff Page
Dream Aircraft Tundra #10
> individually.
defined.
sought:
useful purpose?
pilot.
teblejw
Posted: Wed Jan 08, 2014 5:59 am Post subject: Proposed new Z diagram? |
The split of the "master" switch also allows the engine to be operated from the aux battery and alternator. Why would you? I can imagine my battery monitor on the main battery indicating very high charging current and low voltage. I would interpret this as something wrong with the main and switch to the aux.
Because the alternator for the Viking is an internally regulated ND, I would use a contactor with a "crow bar" for a disconnect, in the event of an o.v. runaway. I would also connect the alternator sense wire without a switch to the "motive" bus, so it can't be accidentally shut down while the engine is running and destroy the permanent-magnet alternator. I would still be able to pull the alternator CB in the event of an emergency.
Hope these make sense.
Tom
Quote: | On Jan 6, 2014, at 8:01 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
> individually.
defined.
sought:
useful purpose?
pilot.
Posted: Wed Jan 08, 2014 6:13 am Post subject: Proposed new Z diagram? |
At 07:57 AM 1/8/2014, you wrote:
Quote: |
<tomblejwas(at)yahoo.com>
I'm not suggesting ANY particular mode of operation
. . . yet. DJ has proposed an architecture for which
he requested a considered critical review.
My input to this discussion goes toward understanding
the rationale for each proposed feature that states,
"when this happens, do this." At the same time, there is
idea that alternator-only ops MIGHT be a good thing
to review. Our current paradigm is rooted in the 1960's.
The drill for crafting any system is to do the FMEA
and then add/adjust features to minimize workloads
and risks for the catalog of failures.
Without such debate, we can only assess DJ's
efforts from the standpoint of being a work of
art or a photograph that is pleasant to look at . . .
but of unknown value for a pilot that is wrestling
with what could become a bad day in the cockpit.
Posted: Wed Jan 08, 2014 6:19 am Post subject: Proposed new Z diagram? |
Joe
Joe Gores
What you have offered my friend is certainly appropriate
to say Figure Z-0 . . . a base line from which
our systems have evolved since the first battery/
generator system was installed in an airplane.
A boat-load of airplanes were successfully flown
for millions of hours with this architecture which
was unchanged until that pesky germanium transistor
showed up for work and scared the pants off of
too many system integrators who were happy with
the status quo . . . the avionics master switch
was born and things took off from there.
It has evolved from there in many ways . . . some
good . . . some not so good. But your suggestion
is an excellent reminder of the idea that the
best systems are crafted on a solid foundation
that's 99% golden . . . adding only those features
which address a tiny but risky fraction of the
rest.
Thanks!
Posted: Wed Jan 08, 2014 7:02 am Post subject: Proposed new Z diagram? |
I apologize for not getting back to you on this and your other
questions. This thing called "work" keeps getting in the way...
I will work on refining and clarifying my "feature" list and we can
definitely discuss!
-Dj
