Plans?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List
macquistan(at)mac.com
PostPosted: Sat Dec 21, 2013 4:50 am    Post subject: Plans? Reply with quote
Hello, All,
Does anyone have a set of plans for the Harmon Rocket that they would be willing to sell?
Thanks much,
Dylan
- The Matronics Rocket-List Email Forum -
http://www.matronics.com/Navigator?Rocket-List
olivercoolidge(at)gmail.c
PostPosted: Sat Dec 21, 2013 6:36 am    Post subject: Plans? Reply with quote
Where are you located? Have you asked John Harmon?
Oliver
Typing with my thumbs
On Dec 21, 2013, at 4:48 AM, Dylan Caldwell <macquistan(at)mac.com> wrote:
Hello, All,
Thanks much,
Dylan
smokyray(at)rocketmail.co
PostPosted: Sat Dec 21, 2013 7:21 am    Post subject: Plans? Reply with quote
Wow, a Rocket list message! Even better, someone wanting to build one? Yeah!
Merry Christmas Y"all!
Smokey
On Dec 21, 2013, at 7:48, Dylan Caldwell <macquistan(at)mac.com> wrote:
Hello, All,
Thanks much,
Dylan
PostPosted: Sat Dec 21, 2013 8:08 am    Post subject: Plans? Reply with quote
Smokey,
Have you built one???
Oliver
Smokey
> Hello, All,
> Thanks much,
> Dylan
nrsage86(at)comcast.net
PostPosted: Sat Dec 21, 2013 8:14 am    Post subject: Plans? Reply with quote
Smokey, Merry Christmas! Still getting my Rocket up to speed; plan to
actually fly it shortly after the new year. I have been meaning to ask you
about aerobatics in the Rocket---especially spins. Do you have any words to
the wise?
Tailwinds and blue skies,
Randy
PostPosted: Sat Dec 21, 2013 9:33 am    Post subject: Plans? Reply with quote
Hi Randy!
Yes sir, I've spun my HR2 many times.
Depending on configuration and fuel load, most Harmon Rockets I have flown are nose heavy, compared to a light nose RV4 or my RVX. Therefore spin entry and characteristics are very straightforward. My normal entry consisted of a level flight slow reduction in power while simultaneously increasing pitch back pressure where idle power was reached just above clean wing stall speed. (My Rocket has a very heavy nose approaching stall requiring full aft stick with the stock RV4 Emp to maintain a level pitch.) Full stall is characterized by a light tail /wing buffet and nose pitching down slightly. You can actually apply full power at this point and hold full aft stick and it will buck and pitch but hold altitude in the stall! The cylinders and oil temp will eventually heat up but an amazing capability, very similar to the F16.
Spin entry requires idle power, full aft stick and full rudder deflection at stall which causes a fairly nose low entry followed by rotation, approx 1.5 turns/sec. Aileron into the direction of spin greatly increases the spin rotation speed. Recovery is also very straightforward. Neutralize aft stick to slightly pitch down while simultaneously applying opposite rudder will stop rotation in approximate 1-2 turns. Other Rocket aerobatics are equally energetic and straightforward.
Fun!
Email me offline anytime:
Smokyray(at)rocketmail.com
Merry Christmas!
Smokey
PS: If I still owned it I would have lightened the nose and airframe significantly with a Catto FP 3 blade, minimal avionics and accessories out front, light sump, starter and accessory case alternator, like my RVX!
[quote] On Dec 21, 2013, at 11:14, "Nancy and Randy" <nrsage86(at)comcast.net> wrote:
Smokey, Merry Christmas! Still getting my Rocket up to speed; plan to actually fly it shortly after the new year. I have been meaning to ask you about aerobatics in the Rocket---especially spins. Do you have any words to the wise?
Randy
PostPosted: Sat Dec 21, 2013 9:34 am    Post subject: Plans? Reply with quote
No sir, I built an RV4 and my current RVX.
I rebuilt my HR2 Smile
Smokey
On Dec 21, 2013, at 11:08, Oliver Coolidge <olivercoolidge(at)gmail.com> wrote:
Smokey,
Oliver
> Smokey
> Sent from my iPhone
>> Hello, All,
>> Thanks much,
>> Dylan
PostPosted: Sat Dec 21, 2013 1:22 pm    Post subject: Plans? Reply with quote
Is an RVX an RV-10?
I'm negotiating on a Harmon kit, haven't heard of an RVX.
Oliver
On Dec 21, 2013, at 11:32 AM, Rob Ray <smokyray(at)rocketmail.com> wrote:
Hi Randy!
Fun!
Merry Christmas!
Smokey
> Thanks,
> Randy
PostPosted: Sat Dec 21, 2013 4:09 pm    Post subject: Plans? Reply with quote
Hey Oliver,
I built a one of a kind airplane from 2 projects. RV4 wings/tail, Rv6 fuselage. Rocket plans used to mate wings.
Flies great...
Smokey
[quote] On Dec 21, 2013, at 16:21, Oliver Coolidge <olivercoolidge(at)gmail.com> wrote:
Is an RVX an RV-10?
Oliver
> Hi Randy!
> Fun!
> Merry Christmas!
> Smokey
> Sent from my iPhone
>> Thanks,
>> Randy
hr2pilot(at)aol.com
PostPosted: Mon Dec 23, 2013 8:25 am    Post subject: Plans? Reply with quote
Dylan,
I can sale you plans. They are $125.00 plus shipping per set. Would you like
the Harmon Rocket II or the Harmon Rocket III. Please advise with shipping
address.
Thank you,
Shelly Wood
Harmon Rocket, LLC
2201 Coy Ave
Bakerfield, CA 93307
661-396-3570
661-396-3574 Fax
www.harmonrocket.com
harmonrocket(at)aol.com
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Rocket-List All times are GMT - 8 Hours
