bob88
Posted: Sun Dec 15, 2013 5:25 pm Post subject: Fiberfrax on the firewall |
Has anyone out there used a product called FYREWRAP to insulate their firewall? It is a fiberfrax-like product with stainless steel foil on one side. Regardless of the product, is it better to insulate on the engine side or the cabin side (or not insulate at all?)
Kellym
Joined: 10 Jan 2006 Posts: 1705 Location: Sun Lakes AZ
Posted: Sun Dec 15, 2013 6:38 pm Post subject: Fiberfrax on the firewall |
Probably approaches primer in various opinions. I used fiberfrax on the
cabin side of firewall. I prefer having engine side of firewall smooth,
so that oil and dirt can be easily cleaned. Others will wax poetic about
advantages of engine side of firewall.
On 12/15/2013 6:25 PM, bob88 wrote:
http://forums.matronics.com/viewtopic.php?p=415631#415631
KCHD |
Posted: Sun Dec 15, 2013 6:48 pm Post subject: Fiberfrax on the firewall |
Cabin side. That way the grease and grime does not get into the insulation.
I used this for the whole plane (the double sided version):
http://www.aircraftspruce.com/pages/cs/insulation/insulator3.php
And this tape to hold it all in:
http://www.aircraftspruce.com/pages/cs/insulation/insultape.php
If you want to do the minimalistic approach then just do the inside of the
firewall and the tunnel floor. I did all the hidden areas between the
floorboards, under the seats and the where the hull has a double wall.
Carl
Tim Olson
Posted: Mon Dec 16, 2013 6:32 am Post subject: Fiberfrax on the firewall |
Carl,
I used almost exactly the same thing. At the time I think it was called
Foss Thermozite Plus. But the stuff I got (the "plus") was silver on 2
sides. You didn't run across that anywhere, did you? I will probably use
it again on the RV-14. I used red RTV to stick it to the side walls
and firewall, and it hasn't loosened up at all....that was the benefit
to me of the silver on 2 sides. The tape would work too of course, but
if I can find the "plus" stuff easily I'll do that.
Carl
schmoboy
Posted: Mon Dec 16, 2013 6:45 am Post subject: Fiberfrax on the firewall |
Carl, link below has an option to buy it with foil on both sides.
-Sean #40303 (struggling to complete the last 90%)
Quote: | Tim Olson <mailto:Tim(at)MyRV10.com>
December 16, 2013 at 8:31 AM
Carl,
use
Posted: Mon Dec 16, 2013 6:51 am Post subject: Fiberfrax on the firewall |
ACS has both the single and double side aluminum versions. They are listed
as different part numbers (09-06016 for double sided). The double side
makes the most sense as it provides a barrier to getting "stuff" into the
insulation material.
Carl
Tim Olson
Posted: Mon Dec 16, 2013 6:58 am Post subject: Fiberfrax on the firewall |
I guess it's Monday...I looked right at it and didn't see. Thanks Carl!
Carl
Kelly McMullen
Posted: Mon Dec 16, 2013 7:02 am Post subject: Fiberfrax on the firewall |
I didn't see a link. I did look at the Foss Thermozite product just now. I am concerned that the fiber between the foil layers is polyester, from shredded plastic bottles. I wonder how well that stands up to heat compared to ceramic materials like fiberfrax. If I could find genuine fiberfrax sandwiched in foil I would love to add that to the fiberfrax I already installed.
On Mon, Dec 16, 2013 at 7:45 AM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
Quote: | --> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
Carl,
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
johngoodman
Posted: Mon Dec 16, 2013 7:23 am Post subject: Re: Fiberfrax on the firewall |
I used a product from Aircraft Spruce called Firewall 2000 Ceramic Blanket:
http://www.aircraftspruce.com/catalog/appages/firewall2000.php
I used a special adhesive to attach it - still holding strong after 2.5 years of flying. The hardest part is not cutting yourself with the stainless steel foil side.
On the cockpit side I used Soundex.
rv10flyer
Posted: Mon Dec 16, 2013 1:28 pm Post subject: Re: Fiberfrax on the firewall |
I used 1/8" bare fiberfrax on cabin side of fw, tunnel bottom and tunnel fwd. I used the recommended 2000F glue from ACS. No problems with it coming loose or tunnel heat. I burn tested a sample and was not overwelmed with outgassing. I installed an adjustable snap switch limit set to 230F near cowl outlet. It has went off once cruising at 16,500', full gross, LOP, 6 deg pos pitch(normally 2-3). Assuming thin air heated up more passing cylinders. Knowing you have a fire should be top priority. Along with switch/led, I have set my fuel flow limit to 26 gph. Normal on takeoff is 25.6
No matter how insulated your stainless steel firewall is, the fuel or oil will go down and aft along with the cooling air igniting on exhaust pipes, burning through your .040" aluminum bottom skin then your brake lines. Using the correct materials, assembled properly, inspected and leak tested will prevent many problems. In flight, early detection, confirm with increased fuel flow, 360 deg turn to look for smoke, then a fast descent if needed.
_________________ Wayne G.
bill.peyton
