email(at)jaredyates.com Guest
Posted: Fri Dec 13, 2013 8:47 pm Post subject: Strobe Noise |
Hello Bob, I've just recently started flying my Z13/8 Bearhawk, which has a steel tube fuselage and aluminum wings. I'm getting a little bit of noise in the headsets from the Aeroflash strobes. I wonder if you or the other list readers can help me narrow down where to look for the source. The system that I installed uses a power pack in each wingtip. The part of the strobe that flashes is in a combination unit that has incandescent position lights, both red/green and aft-facing white. I've replaced the incandescent bulbs with LEDs. I routed power to the strobes from the main bus, via an unshielded conductor, in a bundle out to each wingtip. They are grounded to the airframe locally at the tips. My audio and mic jacks are isolated from the aircraft ground and in shielded cables. The noise that I get is the same regardless of the volume position on the Flightcom 403 intercom or the Garmin 430. It sounds a little bit like a capacitor charging, sort of a "twe-tweeee" of increasing pitch that comes with every flash. It's faint enough that I can hear it on the ground and while taxiing, but once I get up to cruise speed and power it is drowned out. As such, it's not the end of the world if I can't get rid of it, but I thought it was worth looking into. Thanks in advance for any tips you might have.
klehman(at)albedo.net Guest
Posted: Sat Dec 14, 2013 4:19 am Post subject: Strobe Noise |
Jared
I had to install a $4. filter from a automotive audio supplier in line
with the power to the strobes for the same issue. I can still faintly
hear it with the engine off which confirms they are flashing.
Ken
On 13/12/2013 9:36 PM, Jared Yates wrote:
Quote: |
Hello Bob, I've just recently started flying my Z13/8 Bearhawk, which has a steel tube fuselage and aluminum wings. I'm getting a little bit of noise in the headsets from the Aeroflash strobes. I wonder if you or the other list readers can help me narrow down where to look for the source. The system that I installed uses a power pack in each wingtip. The part of the strobe that flashes is in a combination unit that has incandescent position lights, both red/green and aft-facing white. I've replaced the incandescent bulbs with LEDs. I routed power to the strobes from the main bus, via an unshielded conductor, in a bundle out to each wingtip. They are grounded to the airframe locally at the tips. My audio and mic jacks are isolated from the aircraft ground and in shielded cables. The noise that I get is the same regardless of the volume position on the Flightcom 403 intercom or the Garmin 430. It sounds a little bit like a capacitor charging, sort of a "twe-tweeee"!
o!
Quote: | f increasing pitch that comes with every flash. It's faint enough that I can hear it on the ground and while taxiing, but once I get up to cruise speed and power it is drowned out. As such, it's not the end of the world if I can't get rid of it, but I thought it was worth looking into. Thanks in advance for any tips you might have.
Posted: Sat Dec 14, 2013 5:45 am Post subject: Strobe Noise |
Thanks Ken, do you remember anything about how you selected the filter, such as what it would be used in or where you got it from?
On Sat, Dec 14, 2013 at 7:18 AM, Ken <klehman(at)albedo.net (klehman(at)albedo.net)> wrote:
[quote]--> AeroElectric-List message posted by: Ken <klehman(at)albedo.net (klehman(at)albedo.net)>
Jared
I had to install a $4. filter from a automotive audio supplier in line with the power to the strobes for the same issue. I can still faintly hear it with the engine off which confirms they are flashing.
Ken
Posted: Sat Dec 14, 2013 9:38 am Post subject: Strobe Noise |
Jared
The filter was intended for car radios. A black plastic cylinder with 3
leads - IN, OUT, Ground. There are several on ebay for around $6. but I
suspect they are easy to find at automotive suppliers especially if they
do radio installs. Here's one:
http://www.ebay.ca/itm/12V-NOISE-FILTER-HUM-KILLER-ENGINE-SUPRESSOR-POWER-WIRE-/260741326774?pt=LH_DefaultDomain_0&hash=item3cb564e7b6&vxp=mtr
Ken
On 14/12/2013 8:44 AM, Jared Yates wrote:
Quote: | Thanks Ken, do you remember anything about how you selected the filter,
Jared
Ken
