ronko(at)att.net Guest
Posted: Wed Dec 11, 2013 7:47 am Post subject: Thermostat Rotax 582 |
Pulsar friends,
Well its winter and with temperatures below freezing and air density way up, the air speed is up as well.
But, here I am again, duct tape over half of the 2 radiators to get the coolant temperature up to normal. What I don't understand or need confirmation on my theory is, the thermostat definitely stays closed at cold start up, then it opens somewhere between 140-150 degrees, then it seems to just stay open and if I didn't block so much of the radiators, the gauge would show coolant down near 100-110 degrees. Why doesn't the thermostat pinch off the flow to keep it around 140-150 degrees which seems to be its norm, once it starts flow through the radiators? Note, I am well aware of the dangers of shock cooling in a 582 and whether it is summer of winter, I never take off until I know the thermostat is open.
I assume that the thermostat does not operate well as a regulator, but works more like an on/off switch. In addition to acting like a switch, I believe that it takes an extreme drop in coolant temperature before it closes again. Comments?
It would be nice to find some way to control this better, but maybe there are reasons, this is the way these things work.
Best regards,
Ronko
kulpa(at)att.net Guest
Posted: Wed Dec 11, 2013 7:57 am Post subject: Thermostat Rotax 582 |
Ron,
The Thermostat has built in hysteresis so that it doesn't chatter (lack
of a better word). This means that it opens at 140-150° and closes at
some lower temperature, probably around 100°. The higher the open temp
the higher the close temp so you might look at replacing your existing
with a higher temp thermostat, something around 180°.
Best Regards, Bill
On 12/11/2013 9:46 AM, Ron Koval wrote:
| Quote: | Pulsar friends,
Best regards,
Ronko
kdpalmer(at)mweb.co.za Guest
Posted: Wed Dec 11, 2013 8:29 am Post subject: Thermostat Rotax 582 |
Ron,
You should check which side the heat sender unit is, in relation to
the thermostat, which could cause this big variation of temp ?
K'd
RPE - Skunkworx
ccoulter(at)wavecable.com Guest
Posted: Wed Dec 11, 2013 11:18 am Post subject: Thermostat Rotax 582 |
My 912 does not have a thermostat.
Clarke
On Wed, 11 Dec 2013 07:46:55 -0800 (PST)
again. Comments?
these things work.
Best regards,
Ronko
Posted: Wed Dec 11, 2013 12:15 pm Post subject: Thermostat Rotax 582 |
Bill,
I would like to try a 10 degree hotter thermostat, but don't know how to find one that would fit. I don't know if it would be as simple as pulling the thermostat out of my blue head 582, taking it to the Napa Auto Parts warehouse store, and seeing if they can find one the same physical size but 150 or 160 degree.
Thanks for your the feedback.
Ron
Sent: Wednesday, December 11, 2013 9:56 AM
Subject: Re: Thermostat Rotax 582
--> Pulsar-List message posted by: Bill Kulpa <kulpa(at)att.net (kulpa(at)att.net)>
Ron,
The Thermostat has built in hysteresis so that it doesn't chatter (lack of a better word). This means that it opens at 140-150° and closes at some lower temperature, probably around 100°. The higher the open temp the higher the close temp so you might look at replacing your existing with a higher temp thermostat, something around 180°.
Best Regards, Bill
Best regards,
Ronko
; * The Builder's Bookstore htref="http://www.mypilotstore.com/" ace Consulting http://wwnbsp; ==============
Posted: Wed Dec 11, 2013 12:28 pm Post subject: Thermostat Rotax 582 |
Keith,
My heat sender unit is in the middle of the blue head, centered right between the 2 cylinders, adjacent to the thermostat, which I believe flow wise, is heading out to the hoses, either to the hose heading back to the pump if the thermostat is closed or shared with the radiators if the thermostat is open. Therefore, I would think the coolant temperature reading is close to the hottest temperature of the system (not the temperature of return at the pump.
Should the temperature sender unit be somewhere else?
Ron
Sent: Wednesday, December 11, 2013 10:29 AM
Subject: RE: Thermostat Rotax 582
--> Pulsar-List message posted by: "Keith Palmer" <kdpalmer(at)mweb.co.za (kdpalmer(at)mweb.co.za)>
Ron,
K'd
RPE - Skunkworx
