Need a generator
rcdettmer(at)charter.net
PostPosted: Mon Dec 09, 2013 11:55 am    Post subject: Need a generator Reply with quote
Hello fellow Commander Fans,
I am in need of a generator for my 680F – Model #30059-000, Manuf – Jack & Heintz. Engines are Lyc IGSO540 – B1A. If anyone has a lead on a used generator that is serviceble, please let me know. Thanks very much.
Randy Dettmer, AIA, NCARB
680F / N6253X
Dettmer Architecture
663 Hill Street
San Luis Obispo, CA 93405
805 541 4864 / fax 805 541 4865
www.dettmerarchitecture.com
 Filesize:  2.9 KB
 Viewed:  4105 Time(s)
moe-rosspistons(at)hotmai
PostPosted: Mon Dec 09, 2013 3:03 pm    Post subject: Need a generator Reply with quote
Randy,
How many amps & do you have a rebuildable core?
Moe Mills
N680RR
680F(p)
Subject: Need a generator
Date: Mon, 9 Dec 2013 11:54:47 -0800
680F / N6253X
663 Hill Street
 Filesize:  2.9 KB
 Viewed:  4104 Time(s)
PostPosted: Mon Dec 09, 2013 4:52 pm    Post subject: Need a generator Reply with quote
Hi Moe,
The shaft has sheared in the generator. The rest of the generator is undamaged. Don’t know the amps. The electrical system is 28 volts.
Randy
663 Hill Street
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Moe Mills
Sent: Monday, December 09, 2013 3:03 PM
To: commander list
Subject: RE: Need a generator
Randy,
Moe Mills
N680RR
680F(p)
From: rcdettmer(at)charter.net (rcdettmer(at)charter.net)
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
680F / N6253X
663 Hill Street
 Filesize:  2.9 KB
 Viewed:  4103 Time(s)
PostPosted: Mon Dec 09, 2013 8:17 pm    Post subject: Need a generator Reply with quote
Randy,It appears that the Commander part number is 3610275.  I will be at the airport tomorrow...will see what I have (don't get your hopes up too much).
Moe
Subject: RE: Commander-List: Need a generator
Date: Mon, 9 Dec 2013 16:51:54 -0800
Hi Moe,
Randy
663 Hill Street
To: commander list
Randy,
Moe Mills
N680RR
680F(p)
680F / N6253X
[img]http://image001.gif(at)01CEF4FE.D8B0D0A0[/img]
663 Hill Street
 Filesize:  2.9 KB
PostPosted: Wed Dec 11, 2013 8:57 pm    Post subject: Need a generator Reply with quote
Randy,
I went to the airport, and do not have a generator for you.  In a bazaar event after departing FMN the right generator on my 680F(p) failed the same day.  Hope that my problem is not as serious as yours.
Moe Mills
N680RR
680F(p)
680F / N6253X
663 Hill Street
 Filesize:  2.9 KB
 Viewed:  4100 Time(s)
PostPosted: Thu Dec 12, 2013 6:50 am    Post subject: Need a generator Reply with quote
Thanks for the effort Moe. I have located a used / rebuilt generator, and am still looking at options. Good luck with your right generator. Thanks again and Happy Holidays..!!
Randy
663 Hill Street
Sent: Wednesday, December 11, 2013 8:57 PM
To: commander list
Randy,
Moe Mills
N680RR
680F(p)
680F / N6253X
663 Hill Street
 Filesize:  2.9 KB
 Viewed:  4099 Time(s)
